[petsc-users] Interaction between petsc4py and application Fortran library
    WUKIE, NATHAN A DR-02 USAF AFMC AFRL/RQVC
    nathan.wukie at us.af.mil
    Mon Sep 27 10:59:03 CDT 2021
How should petsc initialization be handled for a python application utilizing petsc4py and a Fortran library application also using petsc?
The petsc documentation states that PetscInitializeFortran "should be called soon AFTER the call to PetscInitialize<https://petsc.org/release/docs/manualpages/Sys/PetscInitialize.html#PetscInitialize>() if one is using a C main program that calls Fortran routines that in turn call PETSc routines". Does petsc4py.init(...) call PetscInitializeFortran? Is it permissible to call PetscInitializeFortran from the fortran library application itself? Or must PetscInitializeFortran be called from the C main program?
Thank you,
Nathan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210927/d908078c/attachment.html>
