[petsc-users] SLEPc: smallest eigenvalues
Varun Hiremath varunhiremath at gmail.com
Sat Sep 25 01:07:55 CDT 2021
Hi Jose,
Thanks for checking my code and providing suggestions.
In my particular case, I don't know the matrix A explicitly, I compute A*x
in a matrix-free way within a shell matrix, so I can't use any of the
direct factorization methods. But just a question regarding your suggestion
to compute a (parallel) LU factorization. In our work, we do use MUMPS to
compute the parallel factorization. For solving the generalized problem,
A*x = lambda*B*x, we are computing inv(B)*A*x within a shell matrix, where
factorization of B is computed using MUMPS. (We don't call MUMPS through
SLEPc as we have our own MPI wrapper and other user settings to handle.)
So for the preconditioning, instead of using the iterative solvers, can I
provide a shell matrix that computes inv(P)*x corrections (where P is the
preconditioner matrix) using MUMPS direct solver?
And yes, thanks, #define PETSC_USE_COMPLEX 1 is not needed, it works
without it.
Varun
On Fri, Sep 24, 2021 at 9:14 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> If you do
> $ ./acoustic_matrix_test.o -shell 0 -st_type sinvert -deflate 1
> then it is using an LU factorization (the default), which is fast.
> Use -eps_view to see which solver settings are you using.
> BiCGStab with block Jacobi does not work for you matrix, it exceeds the
> maximum 10000 iterations. So this is not viable unless you can find a
> better preconditioner for your problem. If not, just using
> EPS_SMALLEST_MAGNITUDE will be faster.
> Computing smallest magnitude eigenvalues is a difficult task. The most
> robust way is to compute a (parallel) LU factorization if you can afford it.
> A side note: don't add this to your source code
> This define is taken from PETSc's include files, you should not mess with
> it. Instead, you probably want to add something like this AFTER #include
> <slepceps.h>:
> #if !defined(PETSC_USE_COMPLEX)
> #error "Requires complex scalars"
> #endif
> Jose
> > El 22 sept 2021, a las 19:38, Varun Hiremath <varunhiremath at gmail.com>
> escribió:
> > Hi Jose,
> > Thank you, that explains it and my example code works now without
> specifying "-eps_target 0" in the command line.
> > However, both the Krylov inexact shift-invert and JD solvers are
> struggling to converge for some of my actual problems. The issue seems to
> be related to non-symmetric general matrices. I have extracted one such
> matrix attached here as MatA.gz (size 100k), and have also included a short
> program that loads this matrix and then computes the smallest eigenvalues
> as I described earlier.
> > For this matrix, if I compute the eigenvalues directly (without using
> the shell matrix) using shift-and-invert (as below) then it converges in
> less than a minute.
> > However, if I use the shell matrix and use any of the preconditioned
> solvers JD or Krylov shift-invert (as shown below) with the same matrix as
> the preconditioner, then they struggle to converge.
> > $ ./acoustic_matrix_test.o -usejd 1 -deflate 1
> > $ ./acoustic_matrix_test.o -sinvert 1 -deflate 1
> > Could you please check the attached code and suggest any changes in
> settings that might help with convergence for these kinds of matrices? I
> appreciate your help!
> > Thanks,
> > Varun
> > On Tue, Sep 21, 2021 at 11:14 AM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > I will have a look at your code when I have more time. Meanwhile, I am
> answering 3) below...
> > > El 21 sept 2021, a las 0:23, Varun Hiremath <varunhiremath at gmail.com>
> escribió:
> > > Hi Jose,
> > > Sorry, it took me a while to test these settings in the new builds. I
> am getting good improvement in performance using the preconditioned
> solvers, so thanks for the suggestions! But I have some questions related
> to the usage.
> > > We are using SLEPc to solve the acoustic modal eigenvalue problem.
> Attached is a simple standalone program that computes acoustic modes in a
> simple rectangular box. This program illustrates the general setup I am
> using, though here the shell matrix and the preconditioner matrix are the
> same, while in my actual program the shell matrix computes A*x without
> explicitly forming A, and the preconditioner is a 0th order approximation
> of A.
> > > In the attached program I have tested both
> > > 1) the Krylov-Schur with inexact shift-and-invert (implemented under
> the option sinvert);
> > > 2) the JD solver with preconditioner (implemented under the option
> usejd)
> > > Both the solvers seem to work decently, compared to no
> preconditioning. This is how I run the two solvers (for a mesh size of
> 1600x400):
> > > $ ./acoustic_box_test.o -nx 1600 -ny 400 -usejd 1 -deflate 1
> -eps_target 0
> > > $ ./acoustic_box_test.o -nx 1600 -ny 400 -sinvert 1 -deflate 1
> -eps_target 0
> > > Both finish in about ~10 minutes on my system in serial. JD seems to
> be slightly faster and more accurate (for the imaginary part of eigenvalue).
> > > The program also runs in parallel using mpiexec. I use complex builds,
> as in my main program the matrix can be complex.
> > > Now here are my questions:
> > > 1) For this particular problem type, could you please check if these
> are the best settings that one could use? I have tried different
> combinations of KSP/PC types e.g. GMRES, GAMG, etc, but BCGSL + BJACOBI
> seems to work the best in serial and parallel.
> > > 2) When I tested these settings in my main program, for some reason
> the JD solver was not converging. After further testing, I found the issue
> was related to the setting of "-eps_target 0". I have included
> "EPSSetTarget(eps,0.0);" in the program and I assumed this is equivalent to
> passing "-eps_target 0" from the command line, but that doesn't seem to be
> the case. For instance, if I run the attached program without "-eps_target
> 0" in the command line then it doesn't converge.
> -eps_target 0
> > >  the above finishes in about 10 minutes
> > >  the above doesn't converge even though "EPSSetTarget(eps,0.0);" is
> included in the code
> > > This only seems to affect the JD solver, not the Krylov
> shift-and-invert (-sinvert 1) option. So is there any difference between
> passing "-eps_target 0" from the command line vs using
> "EPSSetTarget(eps,0.0);" in the code? I cannot pass any command line
> arguments in my actual program, so need to set everything internally.
> > > 3) Also, another minor related issue. While using the inexact
> shift-and-invert option, I was running into the following error:
> > > Missing or incorrect user input
> > > Shift-and-invert requires a target 'which' (see
> EPSSetWhichEigenpairs), for instance -st_type sinvert -eps_target 0
> -eps_target_magnitude
> > > I already have the below two lines in the code:
> > > EPSSetWhichEigenpairs(eps,EPS_SMALLEST_MAGNITUDE);
> > > so shouldn't these be enough? If I comment out the first line
> "EPSSetWhichEigenpairs", then the code works fine.
> > You should either do
> > without shift-and-invert or
> > EPSSetWhichEigenpairs(eps,EPS_TARGET_MAGNITUDE);
> > with shift-and-invert. The latter can also be used without
> shift-and-invert (e.g. in JD).
> > I have to check, but a possible explanation why in your comment above
> (2) the command-line option -eps_target 0 works differently is that it also
> sets -eps_target_magnitude if omitted, so to be equivalent in source code
> you have to call both
> > Jose
> > > I have some more questions regarding setting the preconditioner for a
> quadratic eigenvalue problem, which I will ask in a follow-up email.
> > > Thanks for your help!
> > > -Varun
> > > On Thu, Jul 1, 2021 at 5:01 AM Varun Hiremath <varunhiremath at gmail.com>
> wrote:
> > > Thank you very much for these suggestions! We are currently using
> version 3.12, so I'll try to update to the latest version and try your
> suggestions. Let me get back to you, thanks!
> > > On Thu, Jul 1, 2021, 4:45 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> > > Then I would try Davidson methods https://doi.org/10.1145/2543696
> > > You can also try Krylov-Schur with "inexact" shift-and-invert, for
> instance, with preconditioned BiCGStab or GMRES, see section 3.4.1 of the
> users manual.
> > > In both cases, you have to pass matrix A in the call to
> EPSSetOperators() and the preconditioner matrix via
> STSetPreconditionerMat() - note this function was introduced in version
> 3.15.
> > > Jose
> > > > El 1 jul 2021, a las 13:36, Varun Hiremath <varunhiremath at gmail.com>
> escribió:
> > > > Thanks. I actually do have a 1st order approximation of matrix A,
> that I can explicitly compute and also invert. Can I use that matrix as
> preconditioner to speed things up? Is there some example that explains how
> to setup and call SLEPc for this scenario?
> > > > On Thu, Jul 1, 2021, 4:29 AM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > > > For smallest real parts one could adapt ex34.c, but it is going to
> be costly
> https://slepc.upv.es/documentation/current/src/eps/tutorials/ex36.c.html
> > > > Also, if eigenvalues are clustered around the origin, convergence
> may still be very slow.
> > > > It is a tough problem, unless you are able to compute a good
> preconditioner of A (no need to compute the exact inverse).
> > > > Jose
> > > > > El 1 jul 2021, a las 13:23, Varun Hiremath <
> varunhiremath at gmail.com> escribió:
> > > > > I'm solving for the smallest eigenvalues in magnitude. Though is
> it cheaper to solve smallest in real part, as that might also work in my
> case? Thanks for your help.
> > > > > On Thu, Jul 1, 2021, 4:08 AM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > > > > Smallest eigenvalue in magnitude or real part?
> > > > > > El 1 jul 2021, a las 11:58, Varun Hiremath <
> > > > > > Sorry, no both A and B are general sparse matrices
> (non-hermitian). So is there anything else I could try?
> > > > > > On Thu, Jul 1, 2021 at 2:43 AM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > > > > > Is the problem symmetric (GHEP)? In that case, you can try
> LOBPCG on the pair (A,B). But this will likely be slow as well, unless you
> can provide a good preconditioner.
> > > > > > Jose
> > > > > > > El 1 jul 2021, a las 11:37, Varun Hiremath <
> > > > > > > Hi All,
> > > > > > > I am trying to compute the smallest eigenvalues of a
> generalized system A*x= lambda*B*x. I don't explicitly know the matrix A
> (so I am using a shell matrix with a custom matmult function) however, the
> matrix B is explicitly known so I compute inv(B)*A within the shell matrix
> and solve inv(B)*A*x = lambda*x.
> > > > > > > To compute the smallest eigenvalues it is recommended to solve
> the inverted system, but since matrix A is not explicitly known I can't
> invert the system. Moreover, the size of the system can be really big, and
> with the default Krylov solver, it is extremely slow. So is there a better
> way for me to compute the smallest eigenvalues of this system?
> > > > > > > Thanks,
> > > > > > > Varun
> > > <acoustic_box_test.cpp>
> > <acoustic_matrix_test.cpp><MatA.gz>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210924/816f2ccf/attachment.html>
