[petsc-users] SLEPc: smallest eigenvalues
Varun Hiremath varunhiremath at gmail.com
Wed Sep 22 12:38:27 CDT 2021
Hi Jose,
Thank you, that explains it and my example code works now without
specifying "-eps_target 0" in the command line.
However, both the Krylov inexact shift-invert and JD solvers are struggling
to converge for some of my actual problems. The issue seems to be related
to non-symmetric general matrices. I have extracted one such matrix
attached here as MatA.gz (size 100k), and have also included a short
program that loads this matrix and then computes the smallest eigenvalues
as I described earlier.
For this matrix, if I compute the eigenvalues directly (without using the
shell matrix) using shift-and-invert (as below) then it converges in less
than a minute.
$ ./acoustic_matrix_test.o -shell 0 -st_type sinvert -deflate 1
However, if I use the shell matrix and use any of the preconditioned
solvers JD or Krylov shift-invert (as shown below) with the same matrix as
the preconditioner, then they struggle to converge.
$ ./acoustic_matrix_test.o -usejd 1 -deflate 1
$ ./acoustic_matrix_test.o -sinvert 1 -deflate 1
Could you please check the attached code and suggest any changes in
settings that might help with convergence for these kinds of matrices? I
appreciate your help!
Varun
On Tue, Sep 21, 2021 at 11:14 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> I will have a look at your code when I have more time. Meanwhile, I am
> answering 3) below...
> > El 21 sept 2021, a las 0:23, Varun Hiremath <varunhiremath at gmail.com>
> escribió:
> > Hi Jose,
> > Sorry, it took me a while to test these settings in the new builds. I am
> getting good improvement in performance using the preconditioned solvers,
> so thanks for the suggestions! But I have some questions related to the
> usage.
> > We are using SLEPc to solve the acoustic modal eigenvalue problem.
> Attached is a simple standalone program that computes acoustic modes in a
> simple rectangular box. This program illustrates the general setup I am
> using, though here the shell matrix and the preconditioner matrix are the
> same, while in my actual program the shell matrix computes A*x without
> explicitly forming A, and the preconditioner is a 0th order approximation
> of A.
> > In the attached program I have tested both
> > 1) the Krylov-Schur with inexact shift-and-invert (implemented under the
> option sinvert);
> > 2) the JD solver with preconditioner (implemented under the option usejd)
> > Both the solvers seem to work decently, compared to no preconditioning.
> This is how I run the two solvers (for a mesh size of 1600x400):
> > $ ./acoustic_box_test.o -nx 1600 -ny 400 -usejd 1 -deflate 1 -eps_target
> 0
> > $ ./acoustic_box_test.o -nx 1600 -ny 400 -sinvert 1 -deflate 1
> -eps_target 0
> > Both finish in about ~10 minutes on my system in serial. JD seems to be
> slightly faster and more accurate (for the imaginary part of eigenvalue).
> > The program also runs in parallel using mpiexec. I use complex builds,
> as in my main program the matrix can be complex.
> > Now here are my questions:
> > 1) For this particular problem type, could you please check if these are
> the best settings that one could use? I have tried different combinations
> of KSP/PC types e.g. GMRES, GAMG, etc, but BCGSL + BJACOBI seems to work
> the best in serial and parallel.
> > 2) When I tested these settings in my main program, for some reason the
> JD solver was not converging. After further testing, I found the issue was
> related to the setting of "-eps_target 0". I have included
> "EPSSetTarget(eps,0.0);" in the program and I assumed this is equivalent to
> passing "-eps_target 0" from the command line, but that doesn't seem to be
> the case. For instance, if I run the attached program without "-eps_target
> 0" in the command line then it doesn't converge.
> 0
> >  the above finishes in about 10 minutes
> >  the above doesn't converge even though "EPSSetTarget(eps,0.0);" is
> included in the code
> > This only seems to affect the JD solver, not the Krylov shift-and-invert
> (-sinvert 1) option. So is there any difference between passing
> "-eps_target 0" from the command line vs using "EPSSetTarget(eps,0.0);" in
> the code? I cannot pass any command line arguments in my actual program, so
> need to set everything internally.
> > 3) Also, another minor related issue. While using the inexact
> shift-and-invert option, I was running into the following error:
> > Missing or incorrect user input
> > Shift-and-invert requires a target 'which' (see EPSSetWhichEigenpairs),
> for instance -st_type sinvert -eps_target 0 -eps_target_magnitude
> > I already have the below two lines in the code:
> > EPSSetWhichEigenpairs(eps,EPS_SMALLEST_MAGNITUDE);
> > so shouldn't these be enough? If I comment out the first line
> "EPSSetWhichEigenpairs", then the code works fine.
> You should either do
> without shift-and-invert or
> EPSSetWhichEigenpairs(eps,EPS_TARGET_MAGNITUDE);
> with shift-and-invert. The latter can also be used without
> shift-and-invert (e.g. in JD).
> I have to check, but a possible explanation why in your comment above (2)
> the command-line option -eps_target 0 works differently is that it also
> sets -eps_target_magnitude if omitted, so to be equivalent in source code
> you have to call both
> Jose
> > I have some more questions regarding setting the preconditioner for a
> quadratic eigenvalue problem, which I will ask in a follow-up email.
> > Thanks for your help!
> > -Varun
> > On Thu, Jul 1, 2021 at 5:01 AM Varun Hiremath <varunhiremath at gmail.com>
> wrote:
> > Thank you very much for these suggestions! We are currently using
> version 3.12, so I'll try to update to the latest version and try your
> suggestions. Let me get back to you, thanks!
> > On Thu, Jul 1, 2021, 4:45 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> > Then I would try Davidson methods https://doi.org/10.1145/2543696
> > You can also try Krylov-Schur with "inexact" shift-and-invert, for
> instance, with preconditioned BiCGStab or GMRES, see section 3.4.1 of the
> users manual.
> > In both cases, you have to pass matrix A in the call to
> EPSSetOperators() and the preconditioner matrix via
> STSetPreconditionerMat() - note this function was introduced in version
> 3.15.
> > Jose
> > > El 1 jul 2021, a las 13:36, Varun Hiremath <varunhiremath at gmail.com>
> escribió:
> > > Thanks. I actually do have a 1st order approximation of matrix A, that
> I can explicitly compute and also invert. Can I use that matrix as
> preconditioner to speed things up? Is there some example that explains how
> to setup and call SLEPc for this scenario?
> > > On Thu, Jul 1, 2021, 4:29 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
> > > For smallest real parts one could adapt ex34.c, but it is going to be
> costly
> https://slepc.upv.es/documentation/current/src/eps/tutorials/ex36.c.html
> > > Also, if eigenvalues are clustered around the origin, convergence may
> still be very slow.
> > > It is a tough problem, unless you are able to compute a good
> preconditioner of A (no need to compute the exact inverse).
> > > Jose
> > > > El 1 jul 2021, a las 13:23, Varun Hiremath <varunhiremath at gmail.com>
> escribió:
> > > > I'm solving for the smallest eigenvalues in magnitude. Though is it
> cheaper to solve smallest in real part, as that might also work in my case?
> Thanks for your help.
> > > > On Thu, Jul 1, 2021, 4:08 AM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > > > Smallest eigenvalue in magnitude or real part?
> > > > > El 1 jul 2021, a las 11:58, Varun Hiremath <
> varunhiremath at gmail.com> escribió:
> > > > > Sorry, no both A and B are general sparse matrices
> (non-hermitian). So is there anything else I could try?
> > > > > On Thu, Jul 1, 2021 at 2:43 AM Jose E. Roman <jroman at dsic.upv.es>
> wrote:
> > > > > Is the problem symmetric (GHEP)? In that case, you can try LOBPCG
> on the pair (A,B). But this will likely be slow as well, unless you can
> provide a good preconditioner.
> > > > > Jose
> > > > > > El 1 jul 2021, a las 11:37, Varun Hiremath <
> > > > > > Hi All,
> > > > > > I am trying to compute the smallest eigenvalues of a generalized
> system A*x= lambda*B*x. I don't explicitly know the matrix A (so I am using
> a shell matrix with a custom matmult function) however, the matrix B is
> explicitly known so I compute inv(B)*A within the shell matrix and solve
> inv(B)*A*x = lambda*x.
> > > > > > To compute the smallest eigenvalues it is recommended to solve
> the inverted system, but since matrix A is not explicitly known I can't
> invert the system. Moreover, the size of the system can be really big, and
> with the default Krylov solver, it is extremely slow. So is there a better
> way for me to compute the smallest eigenvalues of this system?
> > > > > > Thanks,
> > > > > > Varun
> > <acoustic_box_test.cpp>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210922/820b353c/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210922/820b353c/attachment-0001.obj>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210922/820b353c/attachment-0001.gz>
