[petsc-users] Is this a bug? MatMultAdd_SeqBAIJ_11
Daniel Stone
daniel.stone at opengosim.com
Tue Sep 21 08:51:47 CDT 2021
I seem to have confirmed that making the change suggested by Lawrence fixes
things in our
case. Some alternate runs by a colleague that result in a blocksize 12
matrix also work
fine - I think in that case MAtMultAdd_SeqBAIJ_N must be being used as I
can't find
a blocksize 12 analogue.
Is there by any chance a setting somewhere that can tell petsc to override
the use of
blocksize specific routines like this and always go to, e.g.,
MatMultAdd_SeqBAIJ_N
etc? Might be useful as a short term fix.
Daniel
On Tue, Sep 21, 2021 at 11:50 AM Lawrence Mitchell <wence at gmx.li> wrote:
> Hi Daniel,
> > On 21 Sep 2021, at 11:19, Daniel Stone <daniel.stone at opengosim.com>
> wrote:
> > Hello,
> > If we look at lines 2330-2331 in file baij2.c, it looks like there are
> some
> > mistakes in assigning the `sum..` variables to the z array, causing
> > the function MatMultAdd_SeqBAIJ_11() to not produce the correct
> > answer.
> > I don't have a good example program to demonstrate this yet - it's
> > currently causing problems in a dev branch of pflotan_ogs that
> > can produce blocksize 11 matrices. When in parallel, a standard
> > matrix-vector multiplication calls MatMultAdd for the off-proc
> > contributions, and the result is wrong when this is redirected
> > to MatMultAdd_SeqBAIJ_11. Seems to be the root cause of
> > several solvers failing such as fgmres.
> > Can anyone confirm that these two lines seem incorrect?
> Looks wrong to me, I guess this patch is correct?
> diff --git a/src/mat/impls/baij/seq/baij2.c
> b/src/mat/impls/baij/seq/baij2.c
> index 2849ef9051..65513c8989 100644
> --- a/src/mat/impls/baij/seq/baij2.c
> +++ b/src/mat/impls/baij/seq/baij2.c
> @@ -2328,7 +2328,7 @@ PetscErrorCode MatMultAdd_SeqBAIJ_11(Mat A,Vec
> xx,Vec yy,Vec zz)
> v += 121;
> z[0] = sum1; z[1] = sum2; z[2] = sum3; z[3] = sum4; z[4] = sum5; z[5]
> = sum6; z[6] = sum7;
> - z[7] = sum6; z[8] = sum7; z[9] = sum8; z[10] = sum9; z[11] = sum10;
> + z[7] = sum8; z[8] = sum9; z[9] = sum10; z[10] = sum11;
> if (!usecprow) {
> z += 11; y += 11;
> Lawrence
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210921/19e00445/attachment.html>
