[petsc-users] Is this a bug? MatMultAdd_SeqBAIJ_11
Daniel Stone daniel.stone at opengosim.com
Tue Sep 21 05:19:37 CDT 2021
Hello,
If we look at lines 2330-2331 in file baij2.c, it looks like there are some
mistakes in assigning the `sum..` variables to the z array, causing
the function MatMultAdd_SeqBAIJ_11() to not produce the correct
answer.
I don't have a good example program to demonstrate this yet - it's
currently causing problems in a dev branch of pflotan_ogs that
can produce blocksize 11 matrices. When in parallel, a standard
matrix-vector multiplication calls MatMultAdd for the off-proc
contributions, and the result is wrong when this is redirected
to MatMultAdd_SeqBAIJ_11. Seems to be the root cause of
several solvers failing such as fgmres.
Can anyone confirm that these two lines seem incorrect?
Daniel
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210921/64ec8015/attachment.html>
