[petsc-users] Spock link error
Mark Adams
mfadams at lbl.gov
Sun Sep 19 11:58:19 CDT 2021
Yes, I had the hsa lib commented out but that did not help (appended).
I now see that I had this problem in July and Junchao was helping. I was
able to fix it with PrgEnv-gnu.
THe fortran test actually worked.
Oh well, the application does their own linking so maybe that will fix it
up. (They do use OMP).
gmake[3]:
[/gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-opt-cray-new/lib/petsc/conf/rules:301:
ex19.PETSc] Error 2 (ignored)
*******************Error detected during compile or link!*******************
See http://www.mcs.anl.gov/petsc/documentation/faq.html
/gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials ex19
cc *-L/opt/rocm-4.2.0/lib -lhsa-runtime64* -fPIC -Wall -Wwrite-strings
-Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
-Qunused-arguments -fvisibility=hidden -g -O2 -fPIC -Wall -Wwrite-strings
-I/gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-opt-cray-new/include
-I/opt/rocm-4.2.0/include ex19.c
-Wl,-rpath,/gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-opt-cray-new/lib
-L/gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-opt-cray-new/lib
-Wl,-rpath,/opt/rocm-4.2.0/lib -L/opt/rocm-4.2.0/lib
-Wl,-rpath,/opt/cray/pe/gcc/8.1.0/snos/lib64
-L/opt/cray/pe/gcc/8.1.0/snos/lib64 -Wl,-rpath,/opt/cray/pe/libsci/
21.06.1.1/CRAY/9.0/x86_64/lib -L/opt/cray/pe/libsci/
-Wl,-rpath,/opt/cray/pe/mpich/8.1.7/ofi/cray/10.0/lib
-L/opt/cray/pe/mpich/8.1.7/ofi/cray/10.0/lib
-Wl,-rpath,/opt/cray/pe/mpich/default/gtl/lib
-L/opt/cray/pe/mpich/default/gtl/lib
-Wl,-rpath,/opt/cray/pe/dsmml/0.1.5/dsmml/lib
-L/opt/cray/pe/dsmml/0.1.5/dsmml/lib -Wl,-rpath,/opt/cray/pe/pmi/6.0.12/lib
-L/opt/cray/pe/pmi/6.0.12/lib
-Wl,-rpath,/opt/cray/pe/cce/12.0.1/cce/x86_64/lib
-L/opt/cray/pe/cce/12.0.1/cce/x86_64/lib
-Wl,-rpath,/opt/cray/xpmem/2.2.40-2.1_2.44__g3cf3325.shasta/lib64
-L/opt/cray/xpmem/2.2.40-2.1_2.44__g3cf3325.shasta/lib64
-Wl,-rpath,/opt/cray/pe/cce/12.0.1/cce-clang/x86_64/lib/clang/12.0.0/lib/linux
-L/opt/cray/pe/cce/12.0.1/cce-clang/x86_64/lib/clang/12.0.0/lib/linux
-Wl,-rpath,/opt/cray/pe/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0
-L/opt/cray/pe/gcc/8.1.0/snos/lib/gcc/x86_64-suse-linux/8.1.0
-Wl,-rpath,/opt/cray/pe/cce/12.0.1/binutils/x86_64/x86_64-unknown-linux-gnu/lib
-L/opt/cray/pe/cce/12.0.1/binutils/x86_64/x86_64-unknown-linux-gnu/lib
-Wl,-rpath,/opt/cray/pe/cce/12.0.1/binutils/x86_64/x86_64-pc-linux-gnu/..//x86_64-unknown-linux-gnu/lib
-L/opt/cray/pe/cce/12.0.1/binutils/x86_64/x86_64-pc-linux-gnu/..//x86_64-unknown-linux-gnu/lib
-lpetsc -lparmetis -lmetis -lhipsparse -lhipblas -lrocsparse -lrocsolver
-lrocblas -lrocrand -lamdhip64* -lhsa-runtime64 *-lstdc++ -ldl
-lmpifort_cray -lmpi_cray -lmpi_gtl_hsa -ldsmml -lpmi -lxpmem -lpgas-shmem
-lquadmath -lcrayacc_amdgpu -lopenacc -lmodules -lfi -lcraymath -lf -lu
-lcsup -lgfortran -lpthread -lgcc_eh -lm -lclang_rt.craypgo-x86_64
-lclang_rt.builtins-x86_64 -lquadmath -lstdc++ -ldl -o ex19
ld.lld: error:
/gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-opt-cray-new/lib/libpetsc.so:
undefined reference to .omp_offloading.img_start.cray_amdgcn-amd-amdhsa
[--no-allow-shlib-undefined]
ld.lld: error:
undefined reference to .omp_offloading.img_size.cray_amdgcn-amd-amdhsa
ld.lld: error:
undefined reference to .omp_offloading.img_cache.cray_amdgcn-amd-amdhsa
clang-12: error: linker command failed with exit code 1 (use -v to see
invocation)
gmake[4]: *** [<builtin>: ex19] Error 1
On Sun, Sep 19, 2021 at 9:44 AM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> Are you following the user advices here
> https://docs.olcf.ornl.gov/systems/spock_quick_start_guide.html#compiling-with-the-cray-compiler-wrappers-cc-or-cc
> Il giorno dom 19 set 2021 alle ore 16:30 Mark Adams <mfadams at lbl.gov> ha
> scritto:
>> I am getting to see this error. It seems to be suggesting that I turn
>> --no-allow-shlib-undefined off.
>> Any ideas?
>> Thanks,
>> Mark
>> 09:09 main= /gpfs/alpine/csc314/scratch/adams/petsc$ make
>> PETSC_DIR=/gpfs/alpine/phy122/proj-shared/spock/petsc/current/arch-opt-cray-new
>> PETSC_ARCH="" check
>> Running check examples to verify correct installation
>> Using
>> and PETSC_ARCH=
>> gmake[3]:
>> cc -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
>> -fstack-protector -Qunused-arguments -fvisibility=hidden -g -O2 -fPIC
>> -lrocblas -lrocrand -lamdhip64 -lstdc++ -ldl -lmpifort_cray -lmpi_cray
>> -lmpi_gtl_hsa -ldsmml -lpmi -lxpmem -lpgas-shmem -lquadmath
>> -lcrayacc_amdgpu -lopenacc -lmodules -lfi -lcraymath -lf -lu -lcsup
>> *ld.lld: error:
>> [--no-allow-shlib-undefined]ld.lld: error:
>> [--no-allow-shlib-undefined]*
>> invocation)
>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials ex5f
>> ftn -fPIC -g -O2 -fPIC -g -O2
>> -I/opt/rocm-4.2.0/include ex5f.F90
>> -lclang_rt.builtins-x86_64 -lquadmath -lstdc++ -ldl -o ex5f
>> /opt/cray/pe/cce/12.0.1/binutils/x86_64/x86_64-pc-linux-gnu/bin/ld:
>> warning: alignment 128 of symbol
>> `$host_init$$runtime_init_for_iso_c_binding$iso_c_binding_' in
>> /opt/cray/pe/cce/12.0.1/cce/x86_64/lib/libmodules.so is smaller than 256 in
>> /tmp/pe_39617/ex5f_1.o
>> warning: alignment 64 of symbol `$data_init$iso_c_binding_' in
>> Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI
>> process
>> Completed test examples
>> 09:12 main= /gpfs/alpine/csc314/scratch/adams/petsc$ module list
>> Currently Loaded Modules:
>> 1) craype-x86-rome 4) perftools-base/21.05.0
>> 7) cray-pmi-lib/6.0.12 10) cray-dsmml/0.1.5 13) PrgEnv-cray/8.1.0
>> 16) rocm/4.2.0 19) autoconf/2.69
>> 2) libfabric/1.11.0.4.75 5) xpmem/2.2.40-2.1_2.44__g3cf3325.shasta
>> 8) cce/12.0.1 11) cray-mpich/8.1.7 14) DefApps/default
>> 17) emacs/27.2 20) automake/1.16.3
>> 3) craype-network-ofi 6) cray-pmi/6.0.12
>> 9) craype/2.7.8 12) cray-libsci/21.06.1.1 15)
>> craype-accel-amd-gfx908 18) zlib/1.2.11 21) libtool/2.4.6
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210919/3f36ad86/attachment-0001.html>
