[petsc-users] p4est error at NERSC
Barry Smith bsmith at petsc.dev
Sun Sep 12 19:27:56 CDT 2021
  You seem to have too many inconsistent modules loaded at the same time.
  It is picking up /usr/common/software/sles15_cgpu/hpcsdk/20.11/Linux_x86_64/20.11/compilers/lib/libgomp.so  when it started with /usr/common/software/sles15_cgpu/gcc/8.3.0/lib/../lib64/libgomp.so
   Since you are using  --with-mpi-dir=/usr/common/software/sles15_cgpu/openmpi/4.0.3/gcc you should not load the  hpcsdk/20.11   module which contains the PGI compilers.
  Barry
> On Sep 12, 2021, at 3:51 PM, Mark Adams <mfadams at lbl.gov> wrote:
> <configure.log>
