[petsc-users] Petsc with Visual Studio
Satish Balay
balay at mcs.anl.gov
Fri Sep 10 11:02:22 CDT 2021
At some point we had some un-maintainable cmake code [that didn't work well on windows anyway and also relied on cygwin build env] - and it was removed.
build of PETSc with either Intel or MS compiler is the same process [using cygwin env]
Satish
On Fri, 10 Sep 2021, Hamid wrote:
> Hi everybody,
> I already compiled Petsc (without MUMPS) with Intel compilers under cygwin env, it was a real pain.
> I recently tried to compile petsc with Visual using the native compiler.
> First of all, i compiled METIS, MUMPS (with Metis only cause Scotch compilation is tricky for me) and OpenBLAS.
> When it comes to Petsc, the compilation process is quite hard, the configuration stage does a lot of things… Do you possible to cmake the project ?
> Is there someone who already did stuff in that way ?
> Best regards.
> Envoyé à partir de Courrier pour Windows
> [icon-envelope-tick-round-orange-animated-no-repeat-v1.gif]
> Garanti sans virus. www.avast.com
