[petsc-users] Redirecting petsc output
Barry Smith
bsmith at petsc.dev
Wed Sep 8 10:16:27 CDT 2021
Philip,
There a variety of techniques. Some of the command line options take an optional viewer name where the output can be redirected. For example
-ts_monitor ascii:filename or -ts_view ascii:filename see https://petsc.org/release/docs/manualpages/Viewer/PetscOptionsGetViewer.html <https://petsc.org/release/docs/manualpages/Viewer/PetscOptionsGetViewer.html> for more details
It is also possible to change all stdout from PETSc to a different file by setting PETSC_STDOUT = fopen(...)
Barry
> On Sep 8, 2021, at 10:59 AM, Fackler, Philip via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Is there a way to customize how petsc writes information? Instead of writing to stdout (for example: 0 TS dt 0.1 time 0.), what if we want to log that message to a file other output from Xolotl? I'm assuming there are multiple ways of getting this result. What's common practice with petsc folks?
> Thanks,
> Philip Fackler
> Research Software Engineer, Application Engineering Group
> Advanced Computing Systems Research Section
> Computer Science and Mathematics Division
> Oak Ridge National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210908/25b2964c/attachment-0001.html>
