[petsc-users] Matrix exponential
Jose E. Roman jroman at dsic.upv.es
Fri Sep 3 13:13:18 CDT 2021
You should either create the FN object and then
E.setFN(F)
or extract the FN object and assign to a variable
F = E.getFN()
You can see an example in $SLEPC_DIR/src/binding/slepc4py/demo/ex6.py
Jose
> El 3 sept 2021, a las 19:53, Paul, Sanku <paulsank at msu.edu> escribió:
> Dear Sir/Ma'am,
>    I am trying to use SLEPc to calculate matrix exponential in my python code but I am not getting the correct result. I have attached the code. Could you let me know what I am doing wrong. This is my first time using SLEPc. So, I would like to ask you if you could send me a tutorial on matrix exponential using SLEPc in python code.
> Best,
> Sanku
> <ex2.py>
