[petsc-users] How to construct DMPlex of cells with different topological dimension?
袁煕
yuanxi at advancesoft.jp
Sun Oct 31 20:01:58 CDT 2021
| Yuan: can you add a fake Hex over the hanging shell here? Give them zero
stiffness and constrain the hanging nodes that the fake elements create.
I don't think it is a good idea although it would work theoretically. It
would be a disaster when you try to do calculations over several tens of
millions of elements this way. Maybe I should give up automatic
interpolation but call DMPlexDistribute directly after setting up Dofs upon
each node. Is it possible?
Yuan
2021年11月1日(月) 5:01 Mark Adams <mfadams at lbl.gov>:
>>> Is there anything wrong in my above consideration? Any suggestions?
>>> / | / | cell 0: Hex
>>> | | | | cell 1: Quad
>>> cell 2: line
>>> Much thanks for your help.
>> If you are solving something where everything is embedded in a volumetric
>> mesh, then there is no problem. However, if you really have
>> the mesh above, where lower dimensional pieces are sticking out of the
>> mesh, then Plex can represent the mesh, but automatic interpolation
>> (creation of edges and faces) will not work.
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211101/fa70c663/attachment.html>
