[petsc-users] Tutorials test case cannot run in parallel
Mark Adams mfadams at lbl.gov
Sat Oct 30 18:20:54 CDT 2021
Do we have a policy on this? I know some tests say they are serial.
Maybe just say that tests are only supported for the parameters in the test.
Yuan: at the bottom of all tests and tutorials are example input arguments
and parallel run configurations.
This tutorial is very rudimentary as you can see by:
!/*TEST
!   test:
!      suffix: 0
!TEST*/
If you are looking for a parallel test, find one that has something like
this:
    test:
      suffix: mesh_2
*      nsize: 2*      requires: exodusii
      args: -dm_distribute -petscpartitioner_type simple -dm_plex_filename
${wPETSC_DIR}/share/petsc/datafiles/meshes/sevenside-quad-15.exo
-orth_qual_atol 0.95
TEST*/
On Sat, Oct 30, 2021 at 12:17 PM Matthew Knepley <knepley at gmail.com> wrote:
> Yes, it is a serial test.
>   Thanks,
>     Matt
> On Sat, Oct 30, 2021 at 9:38 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
>> Thank you for your reply.
>> I have solved the problem by modifying
>> call DMPlexCreateFromDAG(dm, depth, numPoints, coneSize,
>> cones,coneOrientations, vertexCoords, ierr);CHKERRA(ierr)
>> into
>> numPoints1 = [0, 0, 0, 0]
>> if (rank == 0) then
>>  else
>>     call DMPlexCreateFromDAG(dm, 3, numPoints1, PETSC_NULL_INTEGER,
>> PETSC_NULL_INTEGER,PETSC_NULL_INTEGER, PETSC_NULL_REAL, ierr)
>> endif
>> The result obtained as follows
>> DM Object: testplex 2 MPI processes
>>   type: plex
>> testplex in 3 dimensions:
>>   0-cells: 12 0
>>   1-cells: 20 0
>>   2-cells: 11 0
>>   3-cells: 2 0
>> Labels:
>>   celltype: 4 strata with value/size (0 (12), 7 (2), 4 (11), 1 (20))
>>   depth: 4 strata with value/size (0 (12), 1 (20), 2 (11), 3 (2))
>> cell:  0 volume:   0.5000 centroid:  -0.2500   0.5000   0.5000
>> cell:  1 volume:   0.5000 centroid:   0.2500   0.5000   0.5000
>> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>> =   RANK 0 PID 15428 RUNNING AT DESKTOP-9ITFSBM
>> =   KILLED BY SIGNAL: 9 (Killed)
>> There is still problem left. I like it relevent
>> 2021年10月30日(土) 21:51 Mark Adams <mfadams at lbl.gov>:
>>> Ah, I can reproduce this error with debugging turned on.
>>> This test is not a parallel test, but it does not say that serial is a
>>> requirement.
>>> So there is a problem here.
>>> Anyone?
>>> On Sat, Oct 30, 2021 at 8:29 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> 08:27 adams/pcksp-batch-kokkos *=
>>>> summit:/gpfs/alpine/csc314/scratch/adams/petsc/src/dm/impls/plex/tutorials$
>>>> make PETSC_ARCH=arch-summit-opt-gnu-kokkos-cuda ex3f90
>>>> mpifort -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g
>>>> -O   -fPIC -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g -O
>>>>  -I/gpfs/alpine/csc314/scratch/adams/petsc/include
>>>> -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-cuda/include
>>>> -I/sw/summit/spack-envs/base/opt/linux-rhel8-ppc64le/gcc-9.1.0/hdf5-1.10.7-yxvwkhm4nhgezbl2mwzdruwoaiblt6q2/include
>>>> -I/sw/summit/cuda/11.0.3/include     ex3f90.F90
>>>>  -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-cuda/lib
>>>> -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-cuda/lib
>>>> -L/sw/summit/spack-envs/base/opt/linux-rhel8-ppc64le/gcc-9.1.0/netlib-lapack-3.9.1-t2a6tcso5tkezcjmfrqvqi2cpary7kgx/lib64
>>>> -Wl,-rpath,/sw/summit/spack-envs/base/opt/linux-rhel8-ppc64le/gcc-9.1.0/hdf5-1.10.7-yxvwkhm4nhgezbl2mwzdruwoaiblt6q2/lib
>>>> -L/sw/summit/spack-envs/base/opt/linux-rhel8-ppc64le/gcc-9.1.0/hdf5-1.10.7-yxvwkhm4nhgezbl2mwzdruwoaiblt6q2/lib
>>>> -Wl,-rpath,/sw/summit/cuda/11.0.3/lib64 -L/sw/summit/cuda/11.0.3/lib64
>>>> -L/sw/summit/cuda/11.0.3/lib64/stubs
>>>> -Wl,-rpath,/sw/summit/spack-envs/base/opt/linux-rhel8-ppc64le/gcc-9.1.0/spectrum-mpi-10.4.0.3-20210112-6jbupg3thjwhsabgevk6xmwhd2bbyxdc/lib
>>>> -L/sw/summit/spack-envs/base/opt/linux-rhel8-ppc64le/gcc-9.1.0/spectrum-mpi-10.4.0.3-20210112-6jbupg3thjwhsabgevk6xmwhd2bbyxdc/lib
>>>> -Wl,-rpath,/autofs/nccs-svm1_sw/summit/gcc/9.1.0-alpha+20190716/lib/gcc/powerpc64le-unknown-linux-gnu/9.1.0
>>>> -L/autofs/nccs-svm1_sw/summit/gcc/9.1.0-alpha+20190716/lib/gcc/powerpc64le-unknown-linux-gnu/9.1.0
>>>> -Wl,-rpath,/sw/summit/spack-envs/base/opt/linux-rhel8-ppc64le/gcc-9.1.0/netlib-lapack-3.9.1-t2a6tcso5tkezcjmfrqvqi2cpary7kgx/lib64
>>>> -Wl,-rpath,/autofs/nccs-svm1_sw/summit/gcc/9.1.0-alpha+20190716/lib64
>>>> -L/autofs/nccs-svm1_sw/summit/gcc/9.1.0-alpha+20190716/lib64
>>>> -Wl,-rpath,/sw/summit/spack-envs/base/opt/linux-rhel8-ppc64le/gcc-8.3.1/darshan-runtime-3.3.0-mu6tnxlhxfplrq3srkkgi5dvly6wenwy/lib
>>>> -L/sw/summit/spack-envs/base/opt/linux-rhel8-ppc64le/gcc-8.3.1/darshan-runtime-3.3.0-mu6tnxlhxfplrq3srkkgi5dvly6wenwy/lib
>>>> -L/autofs/nccs-svm1_sw/summit/gcc/9.1.0-alpha+20190716/lib -lpetsc
>>>> -lkokkoskernels -lkokkoscontainers -lkokkoscore -lp4est -lsc -lblas
>>>> -llapack -lhdf5_hl -lhdf5 -lm -lz -lcudart -lcufft -lcublas -lcusparse
>>>> -lcusolver -lcurand -lcuda -lstdc++ -ldl -lmpiprofilesupport
>>>> -lmpi_ibm_usempif08 -lmpi_ibm_usempi_ignore_tkr -lmpi_ibm_mpifh -lmpi_ibm
>>>> -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lquadmath
>>>> -lstdc++ -ldl -o ex3f90
>>>> jsrun -n 2 -g 1 ./ex3f90
>>>>   type: plex
>>>>   0-cells: 12 12
>>>>   1-cells: 20 20
>>>>   2-cells: 11 11
>>>>   3-cells: 2 2
>>>> Labels:
>>>> 08:28 adams/pcksp-batch-kokkos *=
>>>> On Fri, Oct 29, 2021 at 10:41 PM 袁煕 <yuanxi at advancesoft.jp> wrote:
>>>>> Thanks,  Mark.
>>>>> I do what you suggested but nothing changes. Besides, from your
>>>>> compile history and result,
>>>>> -  you use gfortran with no MPI library, not mpif90
>>>>> -  two CPUs gives exactly the same result
>>>>> -  The first line of the DMView output should be "DM Object: testplex
>>>>> 2 MPI processes", not "DM Object: testplex 1 MPI processes", when you use
>>>>> 2CPUs
>>>>> It seems like you did not use MPI but just two CPUs do exactly
>>>>> the same thing..
>>>>> Best regards,
>>>>> Yuan
>>>>> 2021年10月29日(金) 20:22 Mark Adams <mfadams at lbl.gov>:
>>>>>> This works for me (appended) using an up to date version of PETSc.
>>>>>> I would delete the architecture director and reconfigure, and make
>>>>>> all, and try again.
>>>>>> Next, you seem to be using git. Use the 'main' branch and try again.
>>>>>> Mark
>>>>>> (base) 07:09 adams/swarm-omp-pc *= ~/Codes/petsc$ cd
>>>>>> src/dm/impls/plex/tutorials/
>>>>>> (base) 07:16 adams/swarm-omp-pc *=
>>>>>> ~/Codes/petsc/src/dm/impls/plex/tutorials$    make
>>>>>> PETSC_DIR=/Users/markadams/Codes/petsc PETSC_ARCH=arch-macosx-gnu-g ex3f90
>>>>>> gfortran-11 -Wl,-bind_at_load -Wl,-multiply_defined,suppress
>>>>>> -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs
>>>>>> -Wl,-search_paths_first -Wl,-no_compact_unwind  -fPIC -Wall
>>>>>> -ffree-line-length-0 -Wno-unused-dummy-argument -g -O   -fPIC -Wall
>>>>>>  -I/Users/markadams/Codes/petsc/include
>>>>>> -I/Users/markadams/Codes/petsc/arch-macosx-gnu-g/include     ex3f90.F90
>>>>>>  -Wl,-rpath,/Users/markadams/Codes/petsc/arch-macosx-gnu-g/lib
>>>>>> -L/Users/markadams/Codes/petsc/arch-macosx-gnu-g/lib
>>>>>> -Wl,-rpath,/usr/local/Cellar/gcc/11.2.0/lib/gcc/11/gcc/x86_64-apple-darwin20/11.2.0
>>>>>> -L/usr/local/Cellar/gcc/11.2.0/lib/gcc/11/gcc/x86_64-apple-darwin20/11.2.0
>>>>>> -L/usr/local/Cellar/gcc/11.2.0/lib/gcc/11 -lpetsc -lp4est -lsc -llapack
>>>>>> -lblas -lhdf5_hl -lhdf5 -lmetis -lz -lstdc++ -ldl -lgcc_s.1 -lgfortran
>>>>>> -lquadmath -lm -lquadmath -lstdc++ -ldl -lgcc_s.1 -o ex3f90
>>>>>> ~/Codes/petsc/src/dm/impls/plex/tutorials$ mpirun -np 2 ./ex3f90
>>>>>>   type: plex
>>>>>>   0-cells: 12
>>>>>>   1-cells: 20
>>>>>>   2-cells: 11
>>>>>>   3-cells: 2
>>>>>> Labels:
>>>>>>   type: plex
>>>>>>   0-cells: 12
>>>>>>   1-cells: 20
>>>>>>   2-cells: 11
>>>>>>   3-cells: 2
>>>>>> Labels:
>>>>>> On Fri, Oct 29, 2021 at 6:11 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
>>>>>>> Hi,
>>>>>>> I have tried the test case ex3f90 in the folder
>>>>>>> \src\dm\impls\plex\tutorials to run in parallel but found it fails. When I
>>>>>>> run it in 1 CPU by
>>>>>>> -  mpirun -np 1 ./ex3f90
>>>>>>> Everything seems OK. But when run it in 2 CPU by
>>>>>>> -  mpirun -np 2 ./ex3f90
>>>>>>> I got the following error message
>>>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>>>> [0]PETSC ERROR: Object is in wrong state
>>>>>>> [0]PETSC ERROR: This DMPlex is distributed but its PointSF has no
>>>>>>> graph set
>>>>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble
>>>>>>> shooting.
>>>>>>> [0]PETSC ERROR: Petsc Development GIT revision:
>>>>>>> v3.16.0-248-ge617e6467c  GIT Date: 2021-10-19 23:11:25 -0500
>>>>>>> [0]PETSC ERROR: ./ex3f90 on a  named pc-010-088 by  Fri Oct 29
>>>>>>> 18:48:54 2021
>>>>>>> [0]PETSC ERROR: Configure options --with-cc=mpicc --with-cxx=mpicxx
>>>>>>> --with-fc=mpiifort --with-fortran-bindings=1 --with-debugging=0
>>>>>>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.4.0
>>>>>>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.4.0 --download-metis=1
>>>>>>> --download-parmetis=1 --download-cmake --force --download-superlu_dist=1
>>>>>>> --download-mumps=1 --download-scalapack=1 --download-hypre=1
>>>>>>> --download-ml=1 --with-debugging=yes --prefix=/home/yuanxi
>>>>>>> [0]PETSC ERROR: #1 DMPlexCheckPointSF() at
>>>>>>> /home/yuanxi/myprograms/petsc/src/dm/impls/plex/plex.c:8626
>>>>>>> [0]PETSC ERROR: #2 DMPlexOrientInterface_Internal() at
>>>>>>> /home/yuanxi/myprograms/petsc/src/dm/impls/plex/plexinterpolate.c:595
>>>>>>> [0]PETSC ERROR: #3 DMPlexInterpolate() at
>>>>>>> /home/yuanxi/myprograms/petsc/src/dm/impls/plex/plexinterpolate.c:1357
>>>>>>> [0]PETSC ERROR: #4 User provided function() at User file:0
>>>>>>> Abort(73) on node 0 (rank 0 in comm 16): application called
>>>>>>> MPI_Abort(MPI_COMM_SELF, 73) - process 0
>>>>>>> It fails in calling DMPlexInterpolate. Maybe this program is not
>>>>>>> considered to be run in parallel. But if I wish to do so, how should I
>>>>>>> modify it to let it run on multiple CPUs?
>>>>>>> Much thanks for your help
>>>>>>> Yuan
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211030/e51d92d0/attachment.html>
