[petsc-users] Tutorials test case cannot run in parallel
袁煕
yuanxi at advancesoft.jp
Fri Oct 29 21:41:30 CDT 2021
Thanks, Mark.
I do what you suggested but nothing changes. Besides, from your compile
history and result,
- you use gfortran with no MPI library, not mpif90
- two CPUs gives exactly the same result
- The first line of the DMView output should be "DM Object: testplex 2 MPI
processes", not "DM Object: testplex 1 MPI processes", when you use 2CPUs
It seems like you did not use MPI but just two CPUs do exactly the same
thing..
Best regards,
Yuan
2021年10月29日(金) 20:22 Mark Adams <mfadams at lbl.gov>:
> This works for me (appended) using an up to date version of PETSc.
> I would delete the architecture director and reconfigure, and make all,
> and try again.
> Next, you seem to be using git. Use the 'main' branch and try again.
> Mark
> (base) 07:09 adams/swarm-omp-pc *= ~/Codes/petsc$ cd
> src/dm/impls/plex/tutorials/
> (base) 07:16 adams/swarm-omp-pc *=
> ~/Codes/petsc/src/dm/impls/plex/tutorials$ make
> PETSC_DIR=/Users/markadams/Codes/petsc PETSC_ARCH=arch-macosx-gnu-g ex3f90
> gfortran-11 -Wl,-bind_at_load -Wl,-multiply_defined,suppress
> -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs
> -Wl,-search_paths_first -Wl,-no_compact_unwind -fPIC -Wall
> -ffree-line-length-0 -Wno-unused-dummy-argument -g -O -fPIC -Wall
> -I/Users/markadams/Codes/petsc/include
> -I/Users/markadams/Codes/petsc/arch-macosx-gnu-g/include ex3f90.F90
> -Wl,-rpath,/Users/markadams/Codes/petsc/arch-macosx-gnu-g/lib
> -L/Users/markadams/Codes/petsc/arch-macosx-gnu-g/lib
> -Wl,-rpath,/usr/local/Cellar/gcc/11.2.0/lib/gcc/11/gcc/x86_64-apple-darwin20/11.2.0
> -L/usr/local/Cellar/gcc/11.2.0/lib/gcc/11/gcc/x86_64-apple-darwin20/11.2.0
> -L/usr/local/Cellar/gcc/11.2.0/lib/gcc/11 -lpetsc -lp4est -lsc -llapack
> -lblas -lhdf5_hl -lhdf5 -lmetis -lz -lstdc++ -ldl -lgcc_s.1 -lgfortran
> -lquadmath -lm -lquadmath -lstdc++ -ldl -lgcc_s.1 -o ex3f90
> ~/Codes/petsc/src/dm/impls/plex/tutorials$ mpirun -np 2 ./ex3f90
> type: plex
> testplex in 3 dimensions:
> 0-cells: 12
> 1-cells: 20
> 2-cells: 11
> 3-cells: 2
> Labels:
> celltype: 4 strata with value/size (0 (12), 7 (2), 4 (11), 1 (20))
> depth: 4 strata with value/size (0 (12), 1 (20), 2 (11), 3 (2))
> type: plex
> 0-cells: 12
> 1-cells: 20
> 2-cells: 11
> 3-cells: 2
> Labels:
> cell: 0 volume: 0.5000 centroid: -0.2500 0.5000 0.5000
> cell: 1 volume: 0.5000 centroid: 0.2500 0.5000 0.5000
> On Fri, Oct 29, 2021 at 6:11 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
>> Hi,
>> I have tried the test case ex3f90 in the folder
>> \src\dm\impls\plex\tutorials to run in parallel but found it fails. When I
>> run it in 1 CPU by
>> - mpirun -np 1 ./ex3f90
>> Everything seems OK. But when run it in 2 CPU by
>> - mpirun -np 2 ./ex3f90
>> I got the following error message
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Object is in wrong state
>> [0]PETSC ERROR: This DMPlex is distributed but its PointSF has no graph
>> set
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.16.0-248-ge617e6467c
>> GIT Date: 2021-10-19 23:11:25 -0500
>> [0]PETSC ERROR: ./ex3f90 on a named pc-010-088 by Fri Oct 29 18:48:54
>> 2021
>> [0]PETSC ERROR: Configure options --with-cc=mpicc --with-cxx=mpicxx
>> --with-fc=mpiifort --with-fortran-bindings=1 --with-debugging=0
>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.4.0
>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.4.0 --download-metis=1
>> --download-parmetis=1 --download-cmake --force --download-superlu_dist=1
>> --download-mumps=1 --download-scalapack=1 --download-hypre=1
>> --download-ml=1 --with-debugging=yes --prefix=/home/yuanxi
>> [0]PETSC ERROR: #1 DMPlexCheckPointSF() at
>> /home/yuanxi/myprograms/petsc/src/dm/impls/plex/plex.c:8626
>> [0]PETSC ERROR: #2 DMPlexOrientInterface_Internal() at
>> /home/yuanxi/myprograms/petsc/src/dm/impls/plex/plexinterpolate.c:595
>> [0]PETSC ERROR: #3 DMPlexInterpolate() at
>> /home/yuanxi/myprograms/petsc/src/dm/impls/plex/plexinterpolate.c:1357
>> [0]PETSC ERROR: #4 User provided function() at User file:0
>> Abort(73) on node 0 (rank 0 in comm 16): application called
>> MPI_Abort(MPI_COMM_SELF, 73) - process 0
>> It fails in calling DMPlexInterpolate. Maybe this program is not
>> considered to be run in parallel. But if I wish to do so, how should I
>> modify it to let it run on multiple CPUs?
>> Much thanks for your help
>> Yuan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211030/357cdaec/attachment.html>
