[petsc-users] Installation on NEC SX-Aurora TSUBASA
Rafael Monteiro da Silva rafael.m.silva at alumni.usp.br
Thu Oct 28 14:52:29 CDT 2021
Thank you Satish and Stefano for pointing me out how to do this.
Stefano, if I'm interpreting correctly, I could try to add build options I
need to this script. Is that correct?
First, I'll try to install (based on arch-necve.py script) and then, as
Satish suggested, include additional build options.
Rafael.
Em qui., 28 de out. de 2021 às 16:38, Stefano Zampini <
stefano.zampini at gmail.com> escreveu:
> Rafael
> PETSc can be built for NEC vector engines. Here is a sample configure
> script
> https://gitlab.com/petsc/petsc/-/blob/main/config/examples/arch-necve.py
> NEC blas lapack should be automatically used.
> I don’t know if the packages you need will compile and run smoothly. Their
> C/C++ compiler is very buggy, and I had to resort compiling with -O1to get
> almost all PETSc  tests pass.
> PETSc automatically uses this optimization flag if you compile using
> with-debugging=0. Do not use higher optimizations, unless you are willing
> to file bug reports to them
> Stefano
> On Oct 28, 2021, at 10:12 PM, Rafael Monteiro da Silva <
> rafael.m.silva at alumni.usp.br> wrote:
> Hello.
> On my machine, for initial tests, I use the following options to install
> petsc:
> PETSC_DIR=/home/rafael/petsc PETSC_ARCH=optimized-v3.15.5
> --with-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native"
> CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3 -march=native
> -mtune=native" --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> --download-fblaslapack --download-mpich --download-superlu_dist
> --download-metis --download-parmetis --download-mumps --download-scalapack
> --download-hdf5
> I need to test our software in an environment with NEC SX-Aurora
> TSUBASA Vector Engine.
> Is there any resource where I can set up petsc to use Vector Engine?
> Thank you!
> Regards,
> Rafael.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211028/20460a0d/attachment-0001.html>
