[petsc-users] How to construct DMPlex of cells with different topological dimension?
    Matthew Knepley
    knepley at gmail.com
    Thu Oct 28 08:05:14 CDT 2021
On Thu, Oct 28, 2021 at 4:59 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
> Dear Matt,
> Thank you for your quick response.
> I think what you mean is to build DAG from my mesh at first and then call
> DMPlexCreateFromDAG
> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexCreateFromDAG.html#DMPlexCreateFromDAG>()
> to construct DMPlex.
No, I do not mean that.
> A new problem is,  as I know, the function DMPlexInterpolate would
> generate points with different depth. What's the difference  between those
> faces and segment elements generated by  DMPlexInterpolate  with that
> defined by the original mesh, or should we not use DMPlexInterpolate in
> such a case?
> On the other hand, can DMComposite be used in this case by defining DMPlex
> with different topological dimensions at first and then composite them?
You do not need that. I am obviously not understanding your question. My
short answer is that Plex _already_ handles cells of different
dimension automatically without anything extra.
Maybe it would help if you defined a specific problem you have.
      Matt
> Thanks in advance.
> Yuan
> 2021年10月27日(水) 19:27 Matthew Knepley <knepley at gmail.com>:
>> On Wed, Oct 27, 2021 at 4:50 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
>>> Hi,
>>> I am trying to parallelize my serial FEM program using PETSc. This
>>> program calculates structure deformation by using various types of elements
>>> such as solid, shell, beam, and truss. At the very beginning, I found it
>>> was hard for me to put such kinds of elements into DMPlex. Because solid
>>> elements are topologically three dimensional, shell element two, and beam
>>> or truss are topologically one-dimensional elements. After reading chapter
>>> 2.10: "DMPlex: Unstructured Grids in PETSc" of users manual carefully,  I
>>> found the provided functions, such as DMPlexSetCone, cannot declare those
>>> topological differences.
>>> My question is : Is it possible and how to define all those
>>> topologically different elements into a DMPlex struct?
>> Yes. The idea is to program in a dimension-independent way, so that the
>> code can handle cells of any dimension.
>> What you probably want is the "depth" in the DAG representation, which
>> you can think of as the dimension of a cell.
>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetPointDepth.html#DMPlexGetPointDepth
>>   Thanks,
>>      Matt
>>> Thanks in advance!
>>> Best regards,
>>> Yuan.
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211028/eab67dc6/attachment-0001.html>
