[petsc-users] Cuda: Vec and Mat types
Wed Oct 27 15:48:39 CDT 2021
On Wed, Oct 27, 2021 at 4:37 PM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Thank you for your response.
> It tried running ksp/ex2.c using
> ./ex2 -m 9 -n 9 –vec_type cuda -mat_type aijcusparse -ksp_type cg -pc_type
> jacobi -log_view
> but the log file didn’t record any gpu flops.
> Sorry, my next question doesn’t belong to this thread.
> Does DMDA only work on structured grid/mesh and not on unstructured
> grid/mesh?
DMDA means a structured grid. DMPlex is an unstructured grid.
     Matt
> Best,
> Karthik.
> *From: *Junchao Zhang <junchao.zhang at gmail.com>
> *Date: *Wednesday, 27 October 2021 at 21:13
> *To: *"Chockalingam, Karthikeyan (STFC,DL,HC)" <
> *Cc: *"petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Cuda: Vec and Mat types
> On Wed, Oct 27, 2021 at 2:24 PM Karthikeyan Chockalingam - STFC UKRI <
> Hello,
> I hope, I am framing the question currently.
> Are only distributed arrays (DMDA) of -vec_type and -mat_type only
> supported by CUDA?
> I don't understand this question.  Currently, CUDA-capable types include
> VECCUDA, MATAIJCUDA and MATDENSECUDA, either sequential or MPI.
> I am reading the petsc user manual in section 2.4 distributed arrays are
> introduced but at the start of chapter two there are other vector and
> matrix types as well. I wonder if these types (I don’t how they are
> referred by) are also CUDA supported?
> Can you please point me to some tutorial examples in KSP and SNES that can
> run on gpus?
> search "-mat_type aijcusparse" or "-dm_mat_type aijcusparse" in petsc
> tests/tutorials, you will find many.
> At the moment I am testing KSP/ex45.c with different preconditioners on
> cpus and gpus.
> I tried to run KSP/ex2.c with -vec_type cuda and -mat_type aijcuda noticed
> there was no gpu flops recorded in my log file.
> It is -mat_type aijcusparse
> Many thanks,
> Karthik.
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/6fd981f9/attachment-0001.html>
