[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Wed Oct 27 13:32:33 CDT 2021
Hi Matthew,
we continued the example. Now it must be our misuse of PETSc that
produced the wrong result.
As stated into the code:
// The call to DMPlexNaturalToGlobalBegin/End does not produce our
expected result...
// In lGlobalVec, we expect to have:
* Process [0]
* 2.
* 4.
* 8.
* 3.
* 9.
* Process [1]
* 1.
* 5.
* 7.
* 0.
* 6.
* but we obtained:
* Process [0]
* 2.
* 4.
* 8.
* 0.
* 0.
* Process [1]
* 0.
* 0.
* 0.
* 0.
* 0.
(see attached ex44.c)
Eric
On 2021-10-27 1:25 p.m., Eric Chamberland wrote:
> Great!
> Thanks Matthew, it is working for me up to that point!
> We are continuing the ex44.c and forward it to you at the next
> blocking point...
> Eric
> On 2021-10-27 11:14 a.m., Matthew Knepley wrote:
>> On Wed, Oct 27, 2021 at 8:29 AM Eric Chamberland
>> <Eric.Chamberland at giref.ulaval.ca
>> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>> Hi Matthew,
>> the smallest mesh which crashes the code is a 2x5 mesh:
>> See the modified ex44.c
>> With smaller meshes(2x2, 2x4, etc), it passes... But it bugs
>> latter when I try to use DMPlexNaturalToGlobalBegin but let's
>> keep that other problem for later...
>> Thanks a lot for helping digging into this! :)
>> I have made a small fix in this branch
>> https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n
>> <https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n>
>> It seems to run for me. Can you check it?
>> Thanks,
>> Matt
>> Eric
>> (sorry if you received this for a 2nd times, I have trouble with
>> my mail)
>> On 2021-10-26 4:35 p.m., Matthew Knepley wrote:
>>> On Tue, Oct 26, 2021 at 1:35 PM Eric Chamberland
>>> Here is a screenshot of the partition I hard coded (top) and
>>> vertices/element numbers (down):
>>> I have not yet modified the ex44.c example to properly
>>> assign the coordinates...
>>> (but I would not have done it like it is in the last version
>>> because the sCoords array is the global array with global
>>> vertices number)
>>> I will have time to do this tomorrow...
>>> Maybe I can first try to reproduce all this with a smaller mesh?
>>> That might make it easier to find a problem.
>>> Thanks!
>>> Matt
>>> Eric
>>> On 2021-10-26 9:46 a.m., Matthew Knepley wrote:
>>>> Okay, I ran it. Something seems off with the mesh. First, I
>>>> cannot simply explain the partition. The number of shared
>>>> vertices and edges
>>>> does not seem to come from a straight cut. Second, the mesh
>>>> look scrambled on output.
>>>> Thanks,
>>>> Matt
>>>> On Sun, Oct 24, 2021 at 11:49 PM Eric Chamberland
>>>> Hi Matthew,
>>>> ok, I started back from your ex44.c example and added
>>>> the global array of coordinates. I just have to code
>>>> the creation of the local coordinates now.
>>>> Eric
>>>> On 2021-10-20 6:55 p.m., Matthew Knepley wrote:
>>>>> On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland
>>>>> Hi Matthew,
>>>>> we tried to reproduce the error in a simple example.
>>>>> The context is the following: We hard coded the
>>>>> mesh and initial partition into the code (see
>>>>> sConnectivity and sInitialPartition) for 2 ranks
>>>>> and try to create a section in order to use the
>>>>> DMPlexNaturalToGlobalBegin function to retreive
>>>>> our initial element numbers.
>>>>> Now the call to DMPlexDistribute give different
>>>>> errors depending on what type of component we ask
>>>>> the field to be created. For our objective, we
>>>>> would like a global field to be created on
>>>>> elements only (like a P0 interpolation).
>>>>> We now have the following error generated:
>>>>> [0]PETSC ERROR: --------------------- Error
>>>>> Message
>>>>> [0]PETSC ERROR: Petsc has generated inconsistent data
>>>>> [0]PETSC ERROR: Inconsistency in indices, 18
>>>>> should be 17
>>>>> [0]PETSC ERROR: See
>>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html
>>>>> <https://www.mcs.anl.gov/petsc/documentation/faq.html>
>>>>> for trouble shooting.
>>>>> [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar
>>>>> 30, 2021
>>>>> [0]PETSC ERROR: ./bug on a named rohan by ericc
>>>>> Wed Oct 20 14:52:36 2021
>>>>> [0]PETSC ERROR: Configure options
>>>>> --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7
>>>>> --with-mpi-compilers=1
>>>>> --with-mpi-dir=/opt/openmpi-4.1.0_gcc7
>>>>> --with-cxx-dialect=C++14 --with-make-np=12
>>>>> --with-shared-libraries=1 --with-debugging=yes
>>>>> --with-memalign=64 --with-visibility=0
>>>>> --with-64-bit-indices=0 --download-ml=yes
>>>>> --download-mumps=yes --download-superlu=yes
>>>>> --download-hpddm=yes --download-slepc=yes
>>>>> --download-superlu_dist=yes
>>>>> --download-parmetis=yes --download-ptscotch=yes
>>>>> --download-metis=yes --download-strumpack=yes
>>>>> --download-suitesparse=yes --download-hypre=yes
>>>>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>>> --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>>> --with-scalapack=1
>>>>> --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
>>>>> --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>>> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>>>>> [0]PETSC ERROR: #1 PetscSFCreateSectionSF() at
>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409
>>>>> [0]PETSC ERROR: #2 DMPlexCreateGlobalToNaturalSF()
>>>>> at
>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184
>>>>> [0]PETSC ERROR: #3 DMPlexDistribute() at
>>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733
>>>>> [0]PETSC ERROR: #4 main() at bug_section.cc:159
>>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>>> [0]PETSC ERROR: ----------------End of Error
>>>>> Message -------send entire error message to
>>>>> petsc-maint at mcs.anl.gov
>>>>> <mailto:petsc-maint at mcs.anl.gov>----------
>>>>> Hope the attached code is self-explaining, note
>>>>> that to make it short, we have not included the
>>>>> final part of it, just the buggy part we are
>>>>> encountering right now...
>>>>> Thanks for your insights,
>>>>> Thanks for making the example. I tweaked it slightly.
>>>>> I put in a test case that just makes a parallel 7 x 10
>>>>> quad mesh. This works
>>>>> fine. Thus I think it must be something connected with
>>>>> the original mesh. It is hard to get a handle on it
>>>>> without the coordinates.
>>>>> Do you think you could put the coordinate array in? I
>>>>> have added the code to load them (see attached file).
>>>>> Thanks,
>>>>> Matt
>>>>> Eric
>>>>> On 2021-10-06 9:23 p.m., Matthew Knepley wrote:
>>>>>> On Wed, Oct 6, 2021 at 5:43 PM Eric Chamberland
>>>>>> Hi Matthew,
>>>>>> we tried to use that. Now, we discovered that:
>>>>>> 1- even if we "ask" for sfNatural creation
>>>>>> with DMSetUseNatural, it is not created
>>>>>> because DMPlexCreateGlobalToNaturalSF looks
>>>>>> for a "section": this is not documented in
>>>>>> DMSetUseNaturalso we are asking ourselfs: "is
>>>>>> this a permanent feature or a temporary
>>>>>> situation?"
>>>>>> I think explaining this will help clear up a lot.
>>>>>> What the Natural2Global map does is permute a
>>>>>> solution vector into the ordering that it would
>>>>>> have had prior to mesh distribution.
>>>>>> Now, in order to do this permutation, I need to
>>>>>> know the original (global) data layout. If it is
>>>>>> not specified _before_ distribution, we
>>>>>> cannot build the permutation. The section
>>>>>> describes the data layout, so I need it before
>>>>>> distribution.
>>>>>> I cannot think of another way that you would
>>>>>> implement this, but if you want something else,
>>>>>> let me know.
>>>>>> 2- We then tried to create a "section" in
>>>>>> different manners: we took the code into the
>>>>>> example petsc/src/dm/impls/plex/tests/ex15.c.
>>>>>> However, we ended up with a segfault:
>>>>>> corrupted size vs. prev_size
>>>>>> [rohan:07297] *** Process received signal ***
>>>>>> [rohan:07297] Signal: Aborted (6)
>>>>>> [rohan:07297] Signal code: (-6)
>>>>>> [rohan:07297] [ 0]
>>>>>> /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80]
>>>>>> [rohan:07297] [ 1]
>>>>>> /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b]
>>>>>> [rohan:07297] [ 2]
>>>>>> /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585]
>>>>>> [rohan:07297] [ 3]
>>>>>> /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7]
>>>>>> [rohan:07297] [ 4]
>>>>>> /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea]
>>>>>> [rohan:07297] [ 5]
>>>>>> /lib64/libc.so.6(+0x86036)[0x7f6f10a03036]
>>>>>> [rohan:07297] [ 6]
>>>>>> /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3]
>>>>>> [rohan:07297] [ 7]
>>>>>> /lib64/libc.so.6(+0x88740)[0x7f6f10a05740]
>>>>>> [rohan:07297] [ 8]
>>>>>> /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8]
>>>>>> [rohan:07297] [ 9]
>>>>>> /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064]
>>>>>> [rohan:07297] [10]
>>>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce]
>>>>>> [rohan:07297] [11]
>>>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0]
>>>>>> [rohan:07297] [12]
>>>>>> /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2]
>>>>>> [rohan:07297] [13]
>>>>>> /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210]
>>>>>> [rohan:07297] [14]
>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed]
>>>>>> [rohan:07297] [15]
>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d]
>>>>>> [rohan:07297] [16]
>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18]
>>>>>> [rohan:07297] [17]
>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602]
>>>>>> [rohan:07297] [18]
>>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21]
>>>>>> I am not sure what happened here, but if you
>>>>>> could send a sample code, I will figure it out.
>>>>>> If we do not create a section, the call to
>>>>>> DMPlexDistribute is successful, but
>>>>>> DMPlexGetGlobalToNaturalSF return a null SF
>>>>>> pointer...
>>>>>> Yes, it just ignores it in this case because it
>>>>>> does not have a global layout.
>>>>>> Here are the operations we are calling ( this
>>>>>> is almost the code we are using, I just
>>>>>> removed verifications and creation of the
>>>>>> connectivity which use our parallel structure
>>>>>> and code):
>>>>>> PetscInt* lCells = 0;
>>>>>> PetscInt lNumCorners = 0;
>>>>>> PetscInt lDimMail = 0;
>>>>>> PetscInt lnumCells = 0;
>>>>>> //At this point we create the cells for
>>>>>> PETSc expected input for
>>>>>> DMPlexBuildFromCellListParallel and set
>>>>>> lNumCorners, lDimMail and lnumCells to
>>>>>> correct values.
>>>>>> DM lDMBete = 0
>>>>>> DMPlexCreate(lMPIComm,&lDMBete);
>>>>>> DMSetDimension(lDMBete, lDimMail);
>>>>>> DMPlexBuildFromCellListParallel(lDMBete,
>>>>>> lnumCells,
>>>>>> PETSC_DECIDE,
>>>>>> pLectureElementsLocaux.reqNbTotalSommets(),
>>>>>> lNumCorners,
>>>>>> lCells,
>>>>>> PETSC_NULL);
>>>>>> DM lDMBeteInterp = 0;
>>>>>> DMPlexInterpolate(lDMBete, &lDMBeteInterp);
>>>>>> DMDestroy(&lDMBete);
>>>>>> lDMBete = lDMBeteInterp;
>>>>>> DMSetUseNatural(lDMBete,PETSC_TRUE);
>>>>>> PetscSF lSFMigrationSansOvl = 0;
>>>>>> PetscSF lSFMigrationOvl = 0;
>>>>>> DM lDMDistribueSansOvl = 0;
>>>>>> DM lDMAvecOverlap = 0;
>>>>>> PetscPartitioner lPart;
>>>>>> DMPlexGetPartitioner(lDMBete, &lPart);
>>>>>> PetscPartitionerSetFromOptions(lPart);
>>>>>> PetscSection section;
>>>>>> PetscInt numFields = 1;
>>>>>> PetscInt numBC = 0;
>>>>>> PetscInt numComp[1] = {1};
>>>>>> PetscInt numDof[4] = {1, 0, 0, 0};
>>>>>> PetscInt bcFields[1] = {0};
>>>>>> IS bcPoints[1] = {NULL};
>>>>>> DMSetNumFields(lDMBete, numFields);
>>>>>> DMPlexCreateSection(lDMBete, NULL, numComp,
>>>>>> numDof, numBC, bcFields, bcPoints, NULL,
>>>>>> NULL, §ion);
>>>>>> DMSetLocalSection(lDMBete, section);
>>>>>> DMPlexDistribute(lDMBete, 0,
>>>>>> &lSFMigrationSansOvl, &lDMDistribueSansOvl);
>>>>>> // segfault!
>>>>>> So we have other question/remarks:
>>>>>> 3- Maybe PETSc expect something specific that
>>>>>> is missing/not verified: for example, we
>>>>>> didn't gave any coordinates since we just
>>>>>> want to partition and compute overlap for the
>>>>>> mesh... and then recover our element numbers
>>>>>> in a "simple way"
>>>>>> 4- We are telling ourselves it is somewhat a
>>>>>> "big price to pay" to have to build an unused
>>>>>> section to have the global to natural
>>>>>> ordering set ? Could this requirement be
>>>>>> avoided?
>>>>>> I don't think so. There would have to be _some_
>>>>>> way of describing your data layout in terms of
>>>>>> mesh points, and I do not see how you could use
>>>>>> less memory doing that.
>>>>>> 5- Are there any improvement towards our
>>>>>> usages in 3.16 release?
>>>>>> Let me try and run the code above.
>>>>>> Thanks,
>>>>>> Matt
>>>>>> Thanks,
>>>>>> Eric
>>>>>> On 2021-09-29 7:39 p.m., Matthew Knepley wrote:
>>>>>>> On Wed, Sep 29, 2021 at 5:18 PM Eric
>>>>>>> Chamberland
>>>>>>> wrote:
>>>>>>> Hi,
>>>>>>> I come back with _almost_ the original
>>>>>>> question:
>>>>>>> I would like to add an integer
>>>>>>> information (*our* original element
>>>>>>> number, not petsc one) on each element
>>>>>>> of the DMPlex I create with
>>>>>>> DMPlexBuildFromCellListParallel.
>>>>>>> I would like this interger to be
>>>>>>> distribruted by or the same way
>>>>>>> DMPlexDistribute distribute the mesh.
>>>>>>> Is it possible to do this?
>>>>>>> I think we already have support for what you
>>>>>>> want. If you call
>>>>>>> https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html
>>>>>>> <https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html>
>>>>>>> before DMPlexDistribute(), it will compute a
>>>>>>> PetscSF encoding the global to natural map. You
>>>>>>> can get it with
>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html
>>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html>
>>>>>>> and use it with
>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html>
>>>>>>> Is this sufficient?
>>>>>>> Thanks,
>>>>>>> Matt
>>>>>>> Thanks,
>>>>>>> Eric
>>>>>>> On 2021-07-14 1:18 p.m., Eric
>>>>>>> Chamberland wrote:
>>>>>>> > Hi,
>>>>>>> > I want to use DMPlexDistribute from
>>>>>>> PETSc for computing overlapping
>>>>>>> > and play with the different
>>>>>>> partitioners supported.
>>>>>>> > However, after calling
>>>>>>> DMPlexDistribute, I noticed the elements
>>>>>>> are
>>>>>>> > renumbered and then the original
>>>>>>> number is lost.
>>>>>>> > What would be the best way to keep
>>>>>>> track of the element renumbering?
>>>>>>> > a) Adding an optional parameter to let
>>>>>>> the user retrieve a vector or
>>>>>>> > "IS" giving the old number?
>>>>>>> > b) Adding a DMLabel (seems a wrong
>>>>>>> good solution)
>>>>>>> > c) Other idea?
>>>>>>> > Of course, I don't want to loose
>>>>>>> performances with the need of this
>>>>>>> > "mapping"...
>>>>>>> > Thanks,
>>>>>>> > Eric
>>>>>>> Eric Chamberland, ing., M. Ing
>>>>>>> Professionnel de recherche
>>>>>>> GIREF/Université Laval
>>>>>>> (418) 656-2131 poste 41 22 42
>>>>>>> What most experimenters take for granted
>>>>>>> before they begin their experiments is
>>>>>>> infinitely more interesting than any results
>>>>>>> to which their experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>> What most experimenters take for granted before
>>>>>> they begin their experiments is infinitely more
>>>>>> interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> What most experimenters take for granted before they
>>>>> begin their experiments is infinitely more interesting
>>>>> than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>> What most experimenters take for granted before they begin
>>>> their experiments is infinitely more interesting than any
>>>> -- Norbert Wiener
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to
>>> -- Norbert Wiener
>> experiments is infinitely more interesting than any results to which
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/7eddfc90/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/7eddfc90/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/7eddfc90/attachment-0003.png>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/7eddfc90/attachment-0001.bin>
