[petsc-users] [External] Re: MatVec on GPUs
Junchao Zhang
junchao.zhang at gmail.com
Mon Oct 18 23:28:46 CDT 2021
On Mon, Oct 18, 2021 at 10:56 PM Swarnava Ghosh <swarnava89 at gmail.com>
wrote:
> I am trying the port parts of the following function on GPUs. Essentially,
> the lines of codes between the two "TODO..." comments should be executed on
> the device. Here is the function:
> PetscScalar CalculateSpectralNodesAndWeights(LSDFT_OBJ *pLsdft, int p, int
> LIp)
> PetscInt N_qp;
> N_qp = pLsdft->N_qp;
> int k;
> PetscScalar *a, *b;
> k=0;
> PetscMalloc(sizeof(PetscScalar)*(N_qp+1), &a);
> PetscMalloc(sizeof(PetscScalar)*(N_qp+1), &b);
> * TODO: COPY a, b, pLsdft->Vk, pLsdft->Vkm1, pLsdft->Vkp1,
> pLsdft->LapPlusVeffOprloc, k,p,N_qp from HOST to DEVICE
> * DO THE FOLLOWING OPERATIONS ON DEVICE
> //zero out vectors
> VecZeroEntries(pLsdft->Vk);
> VecZeroEntries(pLsdft->Vkm1);
> VecZeroEntries(pLsdft->Vkp1);
> VecSetValue(pLsdft->Vkm1, p, 1.0, INSERT_VALUES);
> MatMult(pLsdft->LapPlusVeffOprloc,pLsdft->Vkm1,pLsdft->Vk);
> VecDot(pLsdft->Vkm1, pLsdft->Vk, &a[0]);
> VecAXPY(pLsdft->Vk, -a[0], pLsdft->Vkm1);
> VecNorm(pLsdft->Vk, NORM_2, &b[0]);
> VecScale(pLsdft->Vk, 1.0 / b[0]);
> for (k = 0; k < N_qp; k++) {
> MatMult(pLsdft->LapPlusVeffOprloc,pLsdft->Vk,pLsdft->Vkp1);
> VecDot(pLsdft->Vk, pLsdft->Vkp1, &a[k + 1]);
> VecAXPY(pLsdft->Vkp1, -a[k + 1], pLsdft->Vk);
> VecAXPY(pLsdft->Vkp1, -b[k], pLsdft->Vkm1);
> VecCopy(pLsdft->Vk, pLsdft->Vkm1);
> VecNorm(pLsdft->Vkp1, NORM_2, &b[k + 1]);
> VecCopy(pLsdft->Vkp1, pLsdft->Vk);
> VecScale(pLsdft->Vk, 1.0 / b[k + 1]);
> * TODO: Copy back a, b, pLsdft->Vk, pLsdft->Vkm1, pLsdft->Vkp1,
> pLsdft->LapPlusVeffOprloc, k,p,N_qp from DEVICE to HOST
> * Some operation with a, and b on HOST
> TridiagEigenVecSolve_NodesAndWeights(pLsdft, a, b, N_qp, LIp); //
> operation on the host
> // free a,b
> PetscFree(a);
> PetscFree(b);
> return 0;
> If I just use the command line options to set vectors Vk,Vkp1 and Vkm1 as
> cuda vectors and the matrix LapPlusVeffOprloc as aijcusparse, will the
> lines of code between the two "TODO" comments be entirely executed on the
> device?
yes, except VecSetValue(pLsdft->Vkm1, p, 1.0, INSERT_VALUES); which is
done on CPU, by pulling down vector data from GPU to CPU and setting the
value. Subsequent vector operations will push the updated vector data to
GPU again.
> Sincerely,
> Swarnava
> On Mon, Oct 18, 2021 at 10:13 PM Swarnava Ghosh <swarnava89 at gmail.com>
> wrote:
>> Thanks for the clarification, Junchao.
>> Sincerely,
>> Swarnava
>> On Mon, Oct 18, 2021 at 10:08 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> On Mon, Oct 18, 2021 at 8:47 PM Swarnava Ghosh <swarnava89 at gmail.com>
>>> wrote:
>>>> Hi Junchao,
>>>> If I want to pass command line options as -mymat_mat_type aijcusparse,
>>>> should it be MatSetOptionsPrefix(A,"mymat"); or
>>>> MatSetOptionsPrefix(A,"mymat_"); ? Could you please clarify?
>>> my fault, it should be MatSetOptionsPrefix(A,"mymat_"), as seen in
>>> mat/tests/ex62.c
>>> Thanks
>>>> Sincerely,
>>>> Swarnava
>>>> On Mon, Oct 18, 2021 at 9:23 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>>> VecSetOptionsPrefix(v,"myvec")
>>>>> --Junchao Zhang
>>>>> On Mon, Oct 18, 2021 at 8:04 PM Chang Liu <cliu at pppl.gov> wrote:
>>>>>> Hi Junchao,
>>>>>> Thank you for your answer. I tried MatConvert and it works. I didn't
>>>>>> make it before because I forgot to convert a vector from mpi to
>>>>>> mpicuda
>>>>>> previously.
>>>>>> For vector, there is no VecConvert to use, so I have to do
>>>>>> VecDuplicate,
>>>>>> VecSetType and VecCopy. Is there an easier option?
>>>>> As Matt suggested, you could single out the matrix and vector with
>>>>> options prefix and set their type on command line
>>>>> VecSetOptionsPrefix(v,"myvec");
>>>>> Then, -mymat_mat_type aijcusparse -myvec_vec_type cuda
>>>>> A simpler code is to have the vector type automatically set by
>>>>> MatCreateVecs(A,&v,NULL)
>>>>>> Chang
>>>>>> On 10/18/21 5:23 PM, Junchao Zhang wrote:
>>>>>> > On Mon, Oct 18, 2021 at 3:42 PM Chang Liu via petsc-users
>>>>>> > <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>>>>>> > Hi Matt,
>>>>>> > I have a related question. In my code I have many matrices and
>>>>>> I only
>>>>>> > want to have one living on GPU, the others still staying on CPU
>>>>>> mem.
>>>>>> > I wonder if there is an easier way to copy a mpiaij matrix to
>>>>>> > mpiaijcusparse (in other words, copy data to GPUs). I can think
>>>>>> of
>>>>>> > creating a new mpiaijcusparse matrix, and copying the data line
>>>>>> by
>>>>>> > line.
>>>>>> > But I wonder if there is a better option.
>>>>>> > I have tried MatCopy and MatConvert but neither work.
>>>>>> > Did you use MatConvert(mat,matype,MAT_INPLACE_MATRIX,&mat)?
>>>>>> > Chang
>>>>>> > On 10/17/21 7:50 PM, Matthew Knepley wrote:
>>>>>> > > On Sun, Oct 17, 2021 at 7:12 PM Swarnava Ghosh
>>>>>> > <swarnava89 at gmail.com <mailto:swarnava89 at gmail.com>
>>>>>> > > <mailto:swarnava89 at gmail.com <mailto:swarnava89 at gmail.com>>>
>>>>>> wrote:
>>>>>> > > Do I need convert the MATSEQBAIJ to a cuda matrix in
>>>>>> code?
>>>>>> > > You would need a call to MatSetFromOptions() to take that
>>>>>> type
>>>>>> > from the
>>>>>> > > command line, and not have
>>>>>> > > the type hard-coded in your application. It is generally a
>>>>>> bad
>>>>>> > idea to
>>>>>> > > hard code the implementation type.
>>>>>> > > If I do it from command line, then are the other MatVec
>>>>>> calls are
>>>>>> > > ported onto CUDA? I have many MatVec calls in my code,
>>>>>> but I
>>>>>> > > specifically want to port just one call.
>>>>>> > > You can give that one matrix an options prefix to isolate it.
>>>>>> > > Thanks,
>>>>>> > > Matt
>>>>>> > > Sincerely,
>>>>>> > > Swarnava
>>>>>> > > On Sun, Oct 17, 2021 at 7:07 PM Junchao Zhang
>>>>>> > > <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com
>>>>>> > <mailto:junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com
>>>>>> > wrote:
>>>>>> > > You can do that with command line options -mat_type
>>>>>> > aijcusparse
>>>>>> > > -vec_type cuda
>>>>>> > > On Sun, Oct 17, 2021, 5:32 PM Swarnava Ghosh
>>>>>> wrote:
>>>>>> > > Dear Petsc team,
>>>>>> > > I had a query regarding using CUDA to accelerate
>>>>>> a matrix
>>>>>> > > vector product.
>>>>>> > > I have a sequential sparse matrix
>>>>>> (MATSEQBAIJ type).
>>>>>> > I want
>>>>>> > > to port a MatVec call onto GPUs. Is there any
>>>>>> > code/example I
>>>>>> > > can look at?
>>>>>> > > Sincerely,
>>>>>> > > SG
>>>>>> > > What most experimenters take for granted before they begin
>>>>>> their
>>>>>> > > experiments is infinitely more interesting than any results
>>>>>> to which
>>>>>> > > their experiments lead.
>>>>>> > > -- Norbert Wiener
>>>>>> > > https://www.cse.buffalo.edu/~knepley/
>>>>>> > <https://www.cse.buffalo.edu/~knepley/>
>>>>>> > <http://www.cse.buffalo.edu/~knepley/
>>>>>> > <http://www.cse.buffalo.edu/~knepley/>>
>>>>>> > Chang Liu
>>>>>> > Staff Research Physicist
>>>>>> > +1 609 243 3438
>>>>>> > cliu at pppl.gov <mailto:cliu at pppl.gov>
>>>>>> > Princeton Plasma Physics Laboratory
>>>>>> > 100 Stellarator Rd, Princeton NJ 08540, USA
>>>>>> Chang Liu
>>>>>> +1 609 243 3438
>>>>>> cliu at pppl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211018/9cebf1a9/attachment.html>
