[petsc-users] [External] Re: MatVec on GPUs
Junchao Zhang
junchao.zhang at gmail.com
Mon Oct 18 21:08:03 CDT 2021
On Mon, Oct 18, 2021 at 8:47 PM Swarnava Ghosh <swarnava89 at gmail.com> wrote:
> Hi Junchao,
> If I want to pass command line options as -mymat_mat_type aijcusparse,
> should it be MatSetOptionsPrefix(A,"mymat"); or
> MatSetOptionsPrefix(A,"mymat_"); ? Could you please clarify?
my fault, it should be MatSetOptionsPrefix(A,"mymat_"), as seen in
mat/tests/ex62.c
Thanks
> Sincerely,
> Swarnava
> On Mon, Oct 18, 2021 at 9:23 PM Junchao Zhang <junchao.zhang at gmail.com>
>> VecSetOptionsPrefix(v,"myvec")
>> --Junchao Zhang
>> On Mon, Oct 18, 2021 at 8:04 PM Chang Liu <cliu at pppl.gov> wrote:
>>> Hi Junchao,
>>> Thank you for your answer. I tried MatConvert and it works. I didn't
>>> make it before because I forgot to convert a vector from mpi to mpicuda
>>> previously.
>>> For vector, there is no VecConvert to use, so I have to do VecDuplicate,
>>> VecSetType and VecCopy. Is there an easier option?
>> As Matt suggested, you could single out the matrix and vector with
>> options prefix and set their type on command line
>> VecSetOptionsPrefix(v,"myvec");
>> Then, -mymat_mat_type aijcusparse -myvec_vec_type cuda
>> A simpler code is to have the vector type automatically set by
>> MatCreateVecs(A,&v,NULL)
>>> Chang
>>> On 10/18/21 5:23 PM, Junchao Zhang wrote:
>>> > On Mon, Oct 18, 2021 at 3:42 PM Chang Liu via petsc-users
>>> > <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>>> > Hi Matt,
>>> > I have a related question. In my code I have many matrices and I
>>> only
>>> > want to have one living on GPU, the others still staying on CPU
>>> mem.
>>> > I wonder if there is an easier way to copy a mpiaij matrix to
>>> > mpiaijcusparse (in other words, copy data to GPUs). I can think of
>>> > creating a new mpiaijcusparse matrix, and copying the data line by
>>> > line.
>>> > But I wonder if there is a better option.
>>> > I have tried MatCopy and MatConvert but neither work.
>>> > Did you use MatConvert(mat,matype,MAT_INPLACE_MATRIX,&mat)?
>>> > Chang
>>> > On 10/17/21 7:50 PM, Matthew Knepley wrote:
>>> > > On Sun, Oct 17, 2021 at 7:12 PM Swarnava Ghosh
>>> > <swarnava89 at gmail.com <mailto:swarnava89 at gmail.com>
>>> > > <mailto:swarnava89 at gmail.com <mailto:swarnava89 at gmail.com>>>
>>> wrote:
>>> > > Do I need convert the MATSEQBAIJ to a cuda matrix in code?
>>> > > You would need a call to MatSetFromOptions() to take that type
>>> > from the
>>> > > command line, and not have
>>> > > the type hard-coded in your application. It is generally a bad
>>> > idea to
>>> > > hard code the implementation type.
>>> > > If I do it from command line, then are the other MatVec
>>> calls are
>>> > > ported onto CUDA? I have many MatVec calls in my code, but I
>>> > > specifically want to port just one call.
>>> > > You can give that one matrix an options prefix to isolate it.
>>> > > Thanks,
>>> > > Matt
>>> > > Sincerely,
>>> > > Swarnava
>>> > > On Sun, Oct 17, 2021 at 7:07 PM Junchao Zhang
>>> > > <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>
>>> > <mailto:junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>>>
>>> > wrote:
>>> > > You can do that with command line options -mat_type
>>> > aijcusparse
>>> > > -vec_type cuda
>>> > > On Sun, Oct 17, 2021, 5:32 PM Swarnava Ghosh
>>> wrote:
>>> > > Dear Petsc team,
>>> > > I had a query regarding using CUDA to accelerate a
>>> matrix
>>> > > vector product.
>>> > > I have a sequential sparse matrix (MATSEQBAIJ type).
>>> > I want
>>> > > to port a MatVec call onto GPUs. Is there any
>>> > code/example I
>>> > > can look at?
>>> > > Sincerely,
>>> > > SG
>>> > > What most experimenters take for granted before they begin their
>>> > > experiments is infinitely more interesting than any results to
>>> which
>>> > > their experiments lead.
>>> > > -- Norbert Wiener
>>> > > https://www.cse.buffalo.edu/~knepley/
>>> > <https://www.cse.buffalo.edu/~knepley/>
>>> > <http://www.cse.buffalo.edu/~knepley/
>>> > <http://www.cse.buffalo.edu/~knepley/>>
>>> > Chang Liu
>>> > Staff Research Physicist
>>> > +1 609 243 3438
>>> > cliu at pppl.gov <mailto:cliu at pppl.gov>
>>> > Princeton Plasma Physics Laboratory
>>> > 100 Stellarator Rd, Princeton NJ 08540, USA
>>> Chang Liu
>>> +1 609 243 3438
>>> cliu at pppl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211018/03be8af6/attachment-0001.html>
