[petsc-users] Questions about matrix operation in petsc4py
Mark Adams
mfadams at lbl.gov
Mon Oct 18 09:29:04 CDT 2021
see this example:
https://github.com/JesseLu/petsc4py-tutorial/blob/master/mat_serial.py
You need to add the assembly calls
On Mon, Oct 18, 2021 at 10:06 AM Guangpu Zhu <zhugp01 at nus.edu.sg> wrote:
> Dear Sir/Madam,
> My name is Guangpu Zhu, I met a problem when I tested the matrix
> operation in petsc4py. As the following code shows, I first set all
> elements of the matrix to 2.0. Then, I try to set the diagonal elements of
> the matrix to 1.0. However, I surprisingly found that the diagonal
> elements are still 2.0. This question has confused me for a few days, so I
> am writing to you for help or suggestions. Attached is the test code I
> used. I would greatly appreciate it if you can kindly reply to me. Thank
> you in ad
> Guangpu Zhu
> Research Associate, Department of Mechanical Engineering
> National University of Singapore
> Personal E-mail: zhugpupc at gmail.com
> Phone: (+65) 87581879
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211018/846b691e/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211018/846b691e/attachment.png>
