[petsc-users] Periodic boundary conditions in DMPlex
Pierre Seize pierre.seize at onera.fr
Mon Oct 18 02:27:05 CDT 2021
On 15/10/21 22:30, Matthew Knepley wrote:
> On Fri, Oct 15, 2021 at 10:16 AM Pierre Seize <pierre.seize at onera.fr
> <mailto:pierre.seize at onera.fr>> wrote:
>     I read everything again, I think I did not understand you at
>     first. The first solution is to modify the DAG, so that the
>     rightmost cell is linked to the leftmost face, right ? To do that,
>     do I have to manually edit the DAG (the mesh is read from a file) ?
> Yes, the DAG would be modified if you want it for some particular mesh
> that we cannot read automatically. For example, we can read periodic
> GMsh meshes.
>     If so, the mesh connectivity is like the one of a torus, then how
>     does it work with the cells/faces coordinates ?
> You let the coordinate field be in a DG space, so that it can have jumps.
I'm not sure I fully understand this, what I'll do is that I will
experiment with a periodic GMSH mesh.
>     Now I think the second method may be more straightforward. What's
>     the idea ? Get the mapping with DMGetLocalToGlobalMapping, then
>     create the mapping corresponding to the periodicity with
>     ISLocalToGlobalMappingCreate, and finally
>     ISLocalToGlobalMappingConcatenate ? I'm not sure this is the way,
>     and I did not find something like DMSetLocalToGlobalMapping to
>     restore the modified mapping.
> It is more complicated. We make the LocalToGlobalMap by looking at the
> PetscSection (essentially if gives function space information)  and
> deciding which unknowns are removed from the global space.
> You would need to decide that unknowns constrained by periodicity are
> not present in the global space. Actually, this is not hard. You just
> mark them as constrained in the PetscSection, and all the layout
> functions will function correctly. However, then the LocalToGlobalMap
> will not be exactly right because the constrained unknowns will not be
> filled in (just like Dirichlet conditions). You would augment the
> map so that it fills those in by looking up their periodic
> counterparts. Jed has argued for this type of periodicity.
I also don't understand. One one side of my mesh I have :   | ghost1 |
cell1 | cell2 | ...  and on the other | cell_n-1 | cell_n | ghost_n |.
Are not the ghosts (from DMPlexConstructGhostCells) already constrained ?
I experimented on that too, I did:
DMGetSectionSF
PetscSFGetGraph
augment the graph by adding the local ghost cells to the leaves, and the
correct remote "true" cells to the roots
PetscSFSetGraph
and it seems to do what I want. Is this what you meant ? Is this a
correct way to use the PETSc objects ? Or is this just hacky and I'm
lucky it works ?
Pierre
> To me, the first kind is much more straightforward, but maybe this is
> because I find the topology code more clear.
>   Thanks,
>       Matt
>     Pierre
>     On 15/10/21 15:33, Pierre Seize wrote:
>>     When I first tried to handle the periodicity, I found the
>>     DMPlexCreateBoxMesh function (I cannot find the cylinder one).
>>     From reading the sources, I understand that we do some work
>>     either in DMPlexCreateCubeMesh_Internal or with DMSetPeriodicity.
>>     I tried to use DMSetPeriodicity before, for example with a 2x2
>>     box on length 10. I did something like:
>>     const PetscReal maxCell[] = {2, 2};
>>     const PetscReal L[] = {10, 10};
>>     const DMBoundaryType bd[] = {DM_BOUNDARY_PERIODIC,
>>     DM_BOUNDARY_PERIODIC};
>>     DMSetPeriodicity(dm, PETSC_TRUE, maxCell, L, bd);
>>     // or:
>>     DMSetPeriodicity(dm, PETSC_TRUE, NULL, L, bd);
>>     but it did not work:
>>     VecSet(X, 1);
>>     DMGetLocalVector(dm, &locX);
>>     VecZeroEntries(locX);
>>     DMGlobalToLocalBegin(dm, X, INSERT_VALUES, locX);
>>     DMGlobalToLocalEnd(dm, X, INSERT_VALUES, locX);
>>     VecView(locX, PETSC_VIEWER_STDOUT_WORLD);
>>     but the ghost cells values are all 0, only the real cells are 1.
>>     So I guess DMSetPeriodicity alone is not sufficient to handle the
>>     periodicity. Is there a way to do what I want ? That is set up my
>>     DMPlex in a way that DMGlobalToLocalBegin/DMGlobalToLocalEnd do
>>     exchange values between procs AND exchange the periodic values?
>>     Thanks for the help
>>     Pierre
>>     On 15/10/21 14:03, Matthew Knepley wrote:
>>>     On Fri, Oct 15, 2021 at 7:31 AM Pierre Seize
>>>     <pierre.seize at onera.fr <mailto:pierre.seize at onera.fr>> wrote:
>>>         It makes sense, thank you. In fact, both ways seems better
>>>         than my way. The first one looks the most straightforward.
>>>         Unfortunately I do not know how to implement either of them.
>>>         Could you please direct me to the corresponding PETSc
>>>         functions ?
>>>     The first way is implemented for example in
>>>     DMPlexCreateBoxMesh() and DMPlexCreateCylinderMesh(). The second
>>>     is not implemented since
>>>     there did not seem to be a general way to do it. I would help if
>>>     you wanted to try coding it up.
>>>       Thanks,
>>>         Matt
>>>         Pierre
>>>         On 15/10/21 13:25, Matthew Knepley wrote:
>>>>         On Fri, Oct 15, 2021 at 7:08 AM Pierre Seize
>>>>             Hi,
>>>>             I'm writing a code using PETSc to solve NS equations
>>>>             with FV on an
>>>>             unstructured mesh. Therefore I use DMPlex.
>>>>             Regarding periodicity, I manage to implement it this way:
>>>>                - for each couple of boundaries that is linked with
>>>>             periodicity, I
>>>>             create a buffer vector with an ISLocalToGlobalMapping
>>>>                - then, when I need to fill the ghost cells
>>>>             periodicity, the i "true" cell of the local vector
>>>>             fills the buffer
>>>>             vector on location i with VecSetValuesBlockedLocal, then
>>>>             VecAssemblyBegin/VecAssemblyEnd ensure each value is
>>>>             send to the correct
>>>>             location thanks to the mapping, then the i "ghost" cell
>>>>             of the local
>>>>             vector reads the vector on location i to get it's value.
>>>>             It works, but it seems to me there is a better way,
>>>>             with maybe PetscSF,
>>>>             VecScatter, or something I don't know yet. Does anyone
>>>>             have any advice ?
>>>>         There are at least two other ways to handle this. First,
>>>>         the method that is advocated in
>>>>         Plex is to actually make a periodic geometry, meaning
>>>>         connect the cells that are meant
>>>>         to be connected. Then, if you partition with overlap = 1,
>>>>         PetscGlobalToLocal() will fill in
>>>>         these cell values automatically.
>>>>         Second, you could use a non-periodic geometry, but alter
>>>>         the LocalToGlobal map such
>>>>         that the cells gets filled in anyway. Many codes use this
>>>>         scheme and it is straightforward
>>>>         with Plex just by augmenting the map it makes automatically.
>>>>         Does this make sense?
>>>>           Thanks,
>>>>              Matt
>>>>             Pierre Seize
>>>>         What most experimenters take for granted before they begin
>>>>         their experiments is infinitely more interesting than any
>>>>         results to which their experiments lead.
>>>>         -- Norbert Wiener
>>>>         https://www.cse.buffalo.edu/~knepley/
>>>>         <http://www.cse.buffalo.edu/%7Eknepley/>
>>>     What most experimenters take for granted before they begin their
>>>     experiments is infinitely more interesting than any results to
>>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211018/53251752/attachment-0001.html>
