[petsc-users] [External] Re: request to add an option similar to use_omp_threads for mumps to cusparse solver
Junchao Zhang
junchao.zhang at gmail.com
Sat Oct 16 20:59:07 CDT 2021
Hi, Chang,
Thanks a lot for the fix. I will create an MR for it.
--Junchao Zhang
On Sat, Oct 16, 2021 at 8:12 PM Chang Liu <cliu at pppl.gov> wrote:
> Hi Barry, Pierre and Junchao,
> I spent some time to find the reason for the error. I think it is caused
> by some compability issues between telescope and cusparse.
> 1. In PCTelescopeMatCreate_default in telescope.c, it calls
> MatCreateMPIMatConcatenateSeqMat to concat seqmat to mpimat, but this
> function is from mpiaij.c and will set the mat type to mpiaij, even if
> the original matrix is mpiaijcusparse.
> 2. Simiar issue exists in PCTelescopeSetUp_default, where the vector is
> set to type mpi rather than mpicuda.
> I have fixed the issue using the following patch. After applying it,
> telescope and cusparse work as expected.
> diff --git a/src/ksp/pc/impls/telescope/telescope.c
> b/src/ksp/pc/impls/telescope/telescope.c
> index 893febb055..d3f687eff9 100644
> --- a/src/ksp/pc/impls/telescope/telescope.c
> +++ b/src/ksp/pc/impls/telescope/telescope.c
> @@ -159,6 +159,7 @@ PetscErrorCode PCTelescopeSetUp_default(PC
> pc,PC_Telescope sred)
> ierr = VecCreate(subcomm,&xred);CHKERRQ(ierr);
> ierr = VecSetSizes(xred,PETSC_DECIDE,M);CHKERRQ(ierr);
> ierr = VecSetBlockSize(xred,bs);CHKERRQ(ierr);
> + ierr = VecSetType(xred,((PetscObject)x)->type_name);CHKERRQ(ierr);
> ierr = VecSetFromOptions(xred);CHKERRQ(ierr);
> ierr = VecGetLocalSize(xred,&m);CHKERRQ(ierr);
> diff --git a/src/mat/impls/aij/mpi/mpiaij.c
> b/src/mat/impls/aij/mpi/mpiaij.c
> index 36077002db..ac374e07eb 100644
> --- a/src/mat/impls/aij/mpi/mpiaij.c
> +++ b/src/mat/impls/aij/mpi/mpiaij.c
> @@ -4486,6 +4486,7 @@ PetscErrorCode
> MatCreateMPIMatConcatenateSeqMat_MPIAIJ(MPI_Comm comm,Mat inmat,P
> PetscInt m,N,i,rstart,nnz,Ii;
> PetscInt *indx;
> PetscScalar *values;
> + PetscBool isseqaijcusparse;
> PetscFunctionBegin;
> ierr = MatGetSize(inmat,&m,&N);CHKERRQ(ierr);
> @@ -4513,7 +4514,12 @@ PetscErrorCode
> ierr =
> MatSetSizes(*outmat,m,n,PETSC_DETERMINE,PETSC_DETERMINE);CHKERRQ(ierr);
> ierr = MatGetBlockSizes(inmat,&bs,&cbs);CHKERRQ(ierr);
> ierr = MatSetBlockSizes(*outmat,bs,cbs);CHKERRQ(ierr);
> - ierr = MatSetType(*outmat,MATAIJ);CHKERRQ(ierr);
> + ierr =
> PetscObjectBaseTypeCompare((PetscObject)inmat,MATSEQAIJCUSPARSE,&isseqaijcusparse);CHKERRQ(ierr);
> + if (isseqaijcusparse) {
> + ierr = MatSetType(*outmat,MATAIJCUSPARSE);CHKERRQ(ierr);
> + } else {
> + ierr = MatSetType(*outmat,MATAIJ);CHKERRQ(ierr);
> ierr = MatSeqAIJSetPreallocation(*outmat,0,dnz);CHKERRQ(ierr);
> ierr = MatMPIAIJSetPreallocation(*outmat,0,dnz,0,onz);CHKERRQ(ierr);
> ierr = MatPreallocateFinalize(dnz,onz);CHKERRQ(ierr);
> Please help view it and merge to master if possible.
> Regards,
> Chang
> On 10/15/21 1:27 PM, Barry Smith wrote:
> > So the only difference is between
> > -sub_telescope_pc_factor_mat_solver_type cusparse and
> > -sub_telescope_pc_factor_mat_solver_type mumps ?
> > Try without the -sub_telescope_pc_factor_mat_solver_type cusparse
> > and then PETSc will just use the CPU solvers, I want to see if that
> > works, it should. If it works then there is perhaps something specific
> > about the PCTELESCOPE and the cusparse solver, for example the right
> > hand side array values may never get to the GPU.
> > Barry
> >> On Oct 14, 2021, at 10:11 PM, Chang Liu <cliu at pppl.gov
> >> <mailto:cliu at pppl.gov>> wrote:
> >> For comparison, here is the output using mumps instead of cusparse
> >> $ mpiexec -n 16 --hostfile hostfile --oversubscribe ./ex7 -m 400
> >> -ksp_view -ksp_monitor_true_residual -pc_type bjacobi
> >> -pc_bjacobi_blocks 4 -ksp_type fgmres -mat_type aijcusparse
> >> -sub_pc_type telescope -sub_ksp_type preonly -sub_telescope_ksp_type
> >> preonly -sub_telescope_pc_type lu
> >> -sub_pc_telescope_reduction_factor 4 -sub_pc_telescope_subcomm_type
> >> contiguous -ksp_max_it 2000 -ksp_rtol 1.e-20 -ksp_atol 1.e-9
> > -ksp_view -ksp_monitor_true_residual -pc_type bjacobi -pc_bjacobi_blocks
> > 4 -ksp_type fgmres -mat_type aijcusparse -sub_pc_type telescope
> > -sub_ksp_type preonly -sub_telescope_ksp_type preonly
> > -sub_telescope_pc_type lu -sub_telescope_pc_factor_mat_solver_type
> > cusparse -sub_pc_telescope_reduction_factor 4
> > -sub_pc_telescope_subcomm_type contiguous -ksp_max_it 2000 -ksp_rtol
> >> 0 KSP unpreconditioned resid norm 4.014971979977e+01 true resid norm
> >> 4.014971979977e+01 ||r(i)||/||b|| 1.000000000000e+00
> >> 1 KSP unpreconditioned resid norm 2.439995191694e+00 true resid norm
> >> 2.439995191694e+00 ||r(i)||/||b|| 6.077240896978e-02
> >> 2 KSP unpreconditioned resid norm 1.280694102588e+00 true resid norm
> >> 1.280694102588e+00 ||r(i)||/||b|| 3.189795866509e-02
> >> 3 KSP unpreconditioned resid norm 1.041100266810e+00 true resid norm
> >> 1.041100266810e+00 ||r(i)||/||b|| 2.593044912896e-02
> >> 4 KSP unpreconditioned resid norm 7.274347137268e-01 true resid norm
> >> 7.274347137268e-01 ||r(i)||/||b|| 1.811805206499e-02
> >> 5 KSP unpreconditioned resid norm 5.429229329787e-01 true resid norm
> >> 5.429229329787e-01 ||r(i)||/||b|| 1.352245882876e-02
> >> 6 KSP unpreconditioned resid norm 4.332970410353e-01 true resid norm
> >> 4.332970410353e-01 ||r(i)||/||b|| 1.079203150598e-02
> >> 7 KSP unpreconditioned resid norm 3.948206050950e-01 true resid norm
> >> 3.948206050950e-01 ||r(i)||/||b|| 9.833707609019e-03
> >> 8 KSP unpreconditioned resid norm 3.379580577269e-01 true resid norm
> >> 3.379580577269e-01 ||r(i)||/||b|| 8.417444988714e-03
> >> 9 KSP unpreconditioned resid norm 2.875593971410e-01 true resid norm
> >> 2.875593971410e-01 ||r(i)||/||b|| 7.162176936105e-03
> >> 10 KSP unpreconditioned resid norm 2.533983363244e-01 true resid norm
> >> 2.533983363244e-01 ||r(i)||/||b|| 6.311335112378e-03
> >> 11 KSP unpreconditioned resid norm 2.389169921094e-01 true resid norm
> >> 2.389169921094e-01 ||r(i)||/||b|| 5.950651543793e-03
> >> 12 KSP unpreconditioned resid norm 2.118961639089e-01 true resid norm
> >> 2.118961639089e-01 ||r(i)||/||b|| 5.277649880637e-03
> >> 13 KSP unpreconditioned resid norm 1.885892030223e-01 true resid norm
> >> 1.885892030223e-01 ||r(i)||/||b|| 4.697148671593e-03
> >> 14 KSP unpreconditioned resid norm 1.763510666948e-01 true resid norm
> >> 1.763510666948e-01 ||r(i)||/||b|| 4.392336175055e-03
> >> 15 KSP unpreconditioned resid norm 1.638219366731e-01 true resid norm
> >> 1.638219366731e-01 ||r(i)||/||b|| 4.080275964317e-03
> >> 16 KSP unpreconditioned resid norm 1.476792766432e-01 true resid norm
> >> 1.476792766432e-01 ||r(i)||/||b|| 3.678214378076e-03
> >> 17 KSP unpreconditioned resid norm 1.349906937321e-01 true resid norm
> >> 1.349906937321e-01 ||r(i)||/||b|| 3.362182710248e-03
> >> 18 KSP unpreconditioned resid norm 1.289673236836e-01 true resid norm
> >> 1.289673236836e-01 ||r(i)||/||b|| 3.212159993314e-03
> >> 19 KSP unpreconditioned resid norm 1.167505658153e-01 true resid norm
> >> 1.167505658153e-01 ||r(i)||/||b|| 2.907879965230e-03
> >> 20 KSP unpreconditioned resid norm 1.046037988999e-01 true resid norm
> >> 1.046037988999e-01 ||r(i)||/||b|| 2.605343185995e-03
> >> 21 KSP unpreconditioned resid norm 9.832660514331e-02 true resid norm
> >> 9.832660514331e-02 ||r(i)||/||b|| 2.448998539309e-03
> >> 22 KSP unpreconditioned resid norm 8.835618950141e-02 true resid norm
> >> 8.835618950142e-02 ||r(i)||/||b|| 2.200667649539e-03
> >> 23 KSP unpreconditioned resid norm 7.563496650115e-02 true resid norm
> >> 7.563496650116e-02 ||r(i)||/||b|| 1.883823022386e-03
> >> 24 KSP unpreconditioned resid norm 6.651291376834e-02 true resid norm
> >> 6.651291376834e-02 ||r(i)||/||b|| 1.656622115921e-03
> >> 25 KSP unpreconditioned resid norm 5.890393227906e-02 true resid norm
> >> 5.890393227906e-02 ||r(i)||/||b|| 1.467106933070e-03
> >> 26 KSP unpreconditioned resid norm 4.661992782780e-02 true resid norm
> >> 4.661992782780e-02 ||r(i)||/||b|| 1.161152009536e-03
> >> 27 KSP unpreconditioned resid norm 3.690705358716e-02 true resid norm
> >> 3.690705358716e-02 ||r(i)||/||b|| 9.192356452602e-04
> >> 28 KSP unpreconditioned resid norm 3.209680460188e-02 true resid norm
> >> 3.209680460188e-02 ||r(i)||/||b|| 7.994278605666e-04
> >> 29 KSP unpreconditioned resid norm 2.354337626000e-02 true resid norm
> >> 2.354337626001e-02 ||r(i)||/||b|| 5.863895533373e-04
> >> 30 KSP unpreconditioned resid norm 1.701296561785e-02 true resid norm
> >> 1.701296561785e-02 ||r(i)||/||b|| 4.237380908932e-04
> >> 31 KSP unpreconditioned resid norm 1.509942937258e-02 true resid norm
> >> 1.509942937258e-02 ||r(i)||/||b|| 3.760780759588e-04
> >> 32 KSP unpreconditioned resid norm 1.258274688515e-02 true resid norm
> >> 1.258274688515e-02 ||r(i)||/||b|| 3.133956338402e-04
> >> 33 KSP unpreconditioned resid norm 9.805748771638e-03 true resid norm
> >> 9.805748771638e-03 ||r(i)||/||b|| 2.442295692359e-04
> >> 34 KSP unpreconditioned resid norm 8.596552678160e-03 true resid norm
> >> 8.596552678160e-03 ||r(i)||/||b|| 2.141123953301e-04
> >> 35 KSP unpreconditioned resid norm 6.936406707500e-03 true resid norm
> >> 6.936406707500e-03 ||r(i)||/||b|| 1.727635147167e-04
> >> 36 KSP unpreconditioned resid norm 5.533741607932e-03 true resid norm
> >> 5.533741607932e-03 ||r(i)||/||b|| 1.378276519869e-04
> >> 37 KSP unpreconditioned resid norm 4.982347757923e-03 true resid norm
> >> 4.982347757923e-03 ||r(i)||/||b|| 1.240942099414e-04
> >> 38 KSP unpreconditioned resid norm 4.309608348059e-03 true resid norm
> >> 4.309608348059e-03 ||r(i)||/||b|| 1.073384414524e-04
> >> 39 KSP unpreconditioned resid norm 3.729408303186e-03 true resid norm
> >> 3.729408303185e-03 ||r(i)||/||b|| 9.288753001974e-05
> >> 40 KSP unpreconditioned resid norm 3.490003351128e-03 true resid norm
> >> 3.490003351128e-03 ||r(i)||/||b|| 8.692472496776e-05
> >> 41 KSP unpreconditioned resid norm 3.069012426454e-03 true resid norm
> >> 3.069012426453e-03 ||r(i)||/||b|| 7.643919912166e-05
> >> 42 KSP unpreconditioned resid norm 2.772928845284e-03 true resid norm
> >> 2.772928845284e-03 ||r(i)||/||b|| 6.906471225983e-05
> >> 43 KSP unpreconditioned resid norm 2.561454192399e-03 true resid norm
> >> 2.561454192398e-03 ||r(i)||/||b|| 6.379756085902e-05
> >> 44 KSP unpreconditioned resid norm 2.253662762802e-03 true resid norm
> >> 2.253662762802e-03 ||r(i)||/||b|| 5.613146926159e-05
> >> 45 KSP unpreconditioned resid norm 2.086800523919e-03 true resid norm
> >> 2.086800523919e-03 ||r(i)||/||b|| 5.197546917701e-05
> >> 46 KSP unpreconditioned resid norm 1.926028182896e-03 true resid norm
> >> 1.926028182896e-03 ||r(i)||/||b|| 4.797114880257e-05
> >> 47 KSP unpreconditioned resid norm 1.769243808622e-03 true resid norm
> >> 1.769243808622e-03 ||r(i)||/||b|| 4.406615581492e-05
> >> 48 KSP unpreconditioned resid norm 1.656654905964e-03 true resid norm
> >> 1.656654905964e-03 ||r(i)||/||b|| 4.126192945371e-05
> >> 49 KSP unpreconditioned resid norm 1.572052627273e-03 true resid norm
> >> 1.572052627273e-03 ||r(i)||/||b|| 3.915475961260e-05
> >> 50 KSP unpreconditioned resid norm 1.454960682355e-03 true resid norm
> >> 1.454960682355e-03 ||r(i)||/||b|| 3.623837699518e-05
> >> 51 KSP unpreconditioned resid norm 1.375985053014e-03 true resid norm
> >> 1.375985053014e-03 ||r(i)||/||b|| 3.427134883820e-05
> >> 52 KSP unpreconditioned resid norm 1.269325501087e-03 true resid norm
> >> 1.269325501087e-03 ||r(i)||/||b|| 3.161480347603e-05
> >> 53 KSP unpreconditioned resid norm 1.184791772965e-03 true resid norm
> >> 1.184791772965e-03 ||r(i)||/||b|| 2.950934100844e-05
> >> 54 KSP unpreconditioned resid norm 1.064535156080e-03 true resid norm
> >> 1.064535156080e-03 ||r(i)||/||b|| 2.651413662135e-05
> >> 55 KSP unpreconditioned resid norm 9.639036688120e-04 true resid norm
> >> 9.639036688117e-04 ||r(i)||/||b|| 2.400773090370e-05
> >> 56 KSP unpreconditioned resid norm 8.632359780260e-04 true resid norm
> >> 8.632359780260e-04 ||r(i)||/||b|| 2.150042347322e-05
> >> 57 KSP unpreconditioned resid norm 7.613605783850e-04 true resid norm
> >> 7.613605783850e-04 ||r(i)||/||b|| 1.896303591113e-05
> >> 58 KSP unpreconditioned resid norm 6.681073248348e-04 true resid norm
> >> 6.681073248349e-04 ||r(i)||/||b|| 1.664039819373e-05
> >> 59 KSP unpreconditioned resid norm 5.656127908544e-04 true resid norm
> >> 5.656127908545e-04 ||r(i)||/||b|| 1.408758999254e-05
> >> 60 KSP unpreconditioned resid norm 4.850863370767e-04 true resid norm
> >> 4.850863370767e-04 ||r(i)||/||b|| 1.208193580169e-05
> >> 61 KSP unpreconditioned resid norm 4.374055762320e-04 true resid norm
> >> 4.374055762316e-04 ||r(i)||/||b|| 1.089436186387e-05
> >> 62 KSP unpreconditioned resid norm 3.874398257079e-04 true resid norm
> >> 3.874398257077e-04 ||r(i)||/||b|| 9.649876204364e-06
> >> 63 KSP unpreconditioned resid norm 3.364908694427e-04 true resid norm
> >> 3.364908694429e-04 ||r(i)||/||b|| 8.380902061609e-06
> >> 64 KSP unpreconditioned resid norm 2.961034697265e-04 true resid norm
> >> 2.961034697268e-04 ||r(i)||/||b|| 7.374982221632e-06
> >> 65 KSP unpreconditioned resid norm 2.640593092764e-04 true resid norm
> >> 2.640593092767e-04 ||r(i)||/||b|| 6.576865557059e-06
> >> 66 KSP unpreconditioned resid norm 2.423231125743e-04 true resid norm
> >> 2.423231125745e-04 ||r(i)||/||b|| 6.035487016671e-06
> >> 67 KSP unpreconditioned resid norm 2.182349471179e-04 true resid norm
> >> 2.182349471179e-04 ||r(i)||/||b|| 5.435528521898e-06
> >> 68 KSP unpreconditioned resid norm 2.008438265031e-04 true resid norm
> >> 2.008438265028e-04 ||r(i)||/||b|| 5.002371809927e-06
> >> 69 KSP unpreconditioned resid norm 1.838732863386e-04 true resid norm
> >> 1.838732863388e-04 ||r(i)||/||b|| 4.579690400226e-06
> >> 70 KSP unpreconditioned resid norm 1.723786027645e-04 true resid norm
> >> 1.723786027645e-04 ||r(i)||/||b|| 4.293394913444e-06
> >> 71 KSP unpreconditioned resid norm 1.580945192204e-04 true resid norm
> >> 1.580945192205e-04 ||r(i)||/||b|| 3.937624471826e-06
> >> 72 KSP unpreconditioned resid norm 1.476687469671e-04 true resid norm
> >> 1.476687469671e-04 ||r(i)||/||b|| 3.677952117812e-06
> >> 73 KSP unpreconditioned resid norm 1.385018526182e-04 true resid norm
> >> 1.385018526184e-04 ||r(i)||/||b|| 3.449634351350e-06
> >> 74 KSP unpreconditioned resid norm 1.279712893541e-04 true resid norm
> >> 1.279712893541e-04 ||r(i)||/||b|| 3.187351991305e-06
> >> 75 KSP unpreconditioned resid norm 1.202010411772e-04 true resid norm
> >> 1.202010411774e-04 ||r(i)||/||b|| 2.993820175504e-06
> >> 76 KSP unpreconditioned resid norm 1.113459414198e-04 true resid norm
> >> 1.113459414200e-04 ||r(i)||/||b|| 2.773268206485e-06
> >> 77 KSP unpreconditioned resid norm 1.042523036036e-04 true resid norm
> >> 1.042523036037e-04 ||r(i)||/||b|| 2.596588572066e-06
> >> 78 KSP unpreconditioned resid norm 9.565176453232e-05 true resid norm
> >> 9.565176453227e-05 ||r(i)||/||b|| 2.382376888539e-06
> >> 79 KSP unpreconditioned resid norm 8.896901670359e-05 true resid norm
> >> 8.896901670365e-05 ||r(i)||/||b|| 2.215931198209e-06
> >> 80 KSP unpreconditioned resid norm 8.119298425803e-05 true resid norm
> >> 8.119298425824e-05 ||r(i)||/||b|| 2.022255314935e-06
> >> 81 KSP unpreconditioned resid norm 7.544528309154e-05 true resid norm
> >> 7.544528309154e-05 ||r(i)||/||b|| 1.879098620558e-06
> >> 82 KSP unpreconditioned resid norm 6.755385041138e-05 true resid norm
> >> 6.755385041176e-05 ||r(i)||/||b|| 1.682548489719e-06
> >> 83 KSP unpreconditioned resid norm 6.158629300870e-05 true resid norm
> >> 6.158629300835e-05 ||r(i)||/||b|| 1.533915885727e-06
> >> 84 KSP unpreconditioned resid norm 5.358756885754e-05 true resid norm
> >> 5.358756885765e-05 ||r(i)||/||b|| 1.334693470462e-06
> >> 85 KSP unpreconditioned resid norm 4.774852370380e-05 true resid norm
> >> 4.774852370387e-05 ||r(i)||/||b|| 1.189261692037e-06
> >> 86 KSP unpreconditioned resid norm 3.919358737908e-05 true resid norm
> >> 3.919358737930e-05 ||r(i)||/||b|| 9.761858258229e-07
> >> 87 KSP unpreconditioned resid norm 3.434042319950e-05 true resid norm
> >> 3.434042319947e-05 ||r(i)||/||b|| 8.553091620745e-07
> >> 88 KSP unpreconditioned resid norm 2.813699436281e-05 true resid norm
> >> 2.813699436302e-05 ||r(i)||/||b|| 7.008017615898e-07
> >> 89 KSP unpreconditioned resid norm 2.462248069068e-05 true resid norm
> >> 2.462248069051e-05 ||r(i)||/||b|| 6.132665635851e-07
> >> 90 KSP unpreconditioned resid norm 2.040558789626e-05 true resid norm
> >> 2.040558789626e-05 ||r(i)||/||b|| 5.082373674841e-07
> >> 91 KSP unpreconditioned resid norm 1.888523204468e-05 true resid norm
> >> 1.888523204470e-05 ||r(i)||/||b|| 4.703702077842e-07
> >> 92 KSP unpreconditioned resid norm 1.707071292484e-05 true resid norm
> >> 1.707071292474e-05 ||r(i)||/||b|| 4.251763900191e-07
> >> 93 KSP unpreconditioned resid norm 1.498636454665e-05 true resid norm
> >> 1.498636454672e-05 ||r(i)||/||b|| 3.732619958859e-07
> >> 94 KSP unpreconditioned resid norm 1.219393542993e-05 true resid norm
> >> 1.219393543006e-05 ||r(i)||/||b|| 3.037115947725e-07
> >> 95 KSP unpreconditioned resid norm 1.059996963300e-05 true resid norm
> >> 1.059996963303e-05 ||r(i)||/||b|| 2.640110487917e-07
> >> 96 KSP unpreconditioned resid norm 9.099659872548e-06 true resid norm
> >> 9.099659873214e-06 ||r(i)||/||b|| 2.266431725699e-07
> >> 97 KSP unpreconditioned resid norm 8.147347587295e-06 true resid norm
> >> 8.147347587584e-06 ||r(i)||/||b|| 2.029241456283e-07
> >> 98 KSP unpreconditioned resid norm 7.167226146744e-06 true resid norm
> >> 7.167226146783e-06 ||r(i)||/||b|| 1.785124823418e-07
> >> 99 KSP unpreconditioned resid norm 6.552540209538e-06 true resid norm
> >> 6.552540209577e-06 ||r(i)||/||b|| 1.632026385802e-07
> >> 100 KSP unpreconditioned resid norm 5.767783600111e-06 true resid norm
> >> 5.767783600320e-06 ||r(i)||/||b|| 1.436568830140e-07
> >> 101 KSP unpreconditioned resid norm 5.261057430584e-06 true resid norm
> >> 5.261057431144e-06 ||r(i)||/||b|| 1.310359688033e-07
> >> 102 KSP unpreconditioned resid norm 4.715498525786e-06 true resid norm
> >> 4.715498525947e-06 ||r(i)||/||b|| 1.174478564100e-07
> >> 103 KSP unpreconditioned resid norm 4.380052669622e-06 true resid norm
> >> 4.380052669825e-06 ||r(i)||/||b|| 1.090929822591e-07
> >> 104 KSP unpreconditioned resid norm 3.911664470060e-06 true resid norm
> >> 3.911664470226e-06 ||r(i)||/||b|| 9.742694319496e-08
> >> 105 KSP unpreconditioned resid norm 3.652211458315e-06 true resid norm
> >> 3.652211458259e-06 ||r(i)||/||b|| 9.096480564430e-08
> >> 106 KSP unpreconditioned resid norm 3.387532128049e-06 true resid norm
> >> 3.387532128358e-06 ||r(i)||/||b|| 8.437249737363e-08
> >> 107 KSP unpreconditioned resid norm 3.234218880987e-06 true resid norm
> >> 3.234218880798e-06 ||r(i)||/||b|| 8.055395895481e-08
> >> 108 KSP unpreconditioned resid norm 3.016905196388e-06 true resid norm
> >> 3.016905196492e-06 ||r(i)||/||b|| 7.514137611763e-08
> >> 109 KSP unpreconditioned resid norm 2.858246441921e-06 true resid norm
> >> 2.858246441975e-06 ||r(i)||/||b|| 7.118969836476e-08
> >> 110 KSP unpreconditioned resid norm 2.637118810847e-06 true resid norm
> >> 2.637118810750e-06 ||r(i)||/||b|| 6.568212241336e-08
> >> 111 KSP unpreconditioned resid norm 2.494976088717e-06 true resid norm
> >> 2.494976088700e-06 ||r(i)||/||b|| 6.214180574966e-08
> >> 112 KSP unpreconditioned resid norm 2.270639574272e-06 true resid norm
> >> 2.270639574200e-06 ||r(i)||/||b|| 5.655430686750e-08
> >> 113 KSP unpreconditioned resid norm 2.104988663813e-06 true resid norm
> >> 2.104988664169e-06 ||r(i)||/||b|| 5.242847707696e-08
> >> 114 KSP unpreconditioned resid norm 1.889361127301e-06 true resid norm
> >> 1.889361127526e-06 ||r(i)||/||b|| 4.705789073868e-08
> >> 115 KSP unpreconditioned resid norm 1.732367008052e-06 true resid norm
> >> 1.732367007971e-06 ||r(i)||/||b|| 4.314767367271e-08
> >> 116 KSP unpreconditioned resid norm 1.509288268391e-06 true resid norm
> >> 1.509288268645e-06 ||r(i)||/||b|| 3.759150191264e-08
> >> 117 KSP unpreconditioned resid norm 1.359169217644e-06 true resid norm
> >> 1.359169217445e-06 ||r(i)||/||b|| 3.385252062089e-08
> >> 118 KSP unpreconditioned resid norm 1.180146337735e-06 true resid norm
> >> 1.180146337908e-06 ||r(i)||/||b|| 2.939363820703e-08
> >> 119 KSP unpreconditioned resid norm 1.067757039683e-06 true resid norm
> >> 1.067757039924e-06 ||r(i)||/||b|| 2.659438335433e-08
> >> 120 KSP unpreconditioned resid norm 9.435833073736e-07 true resid norm
> >> 9.435833073736e-07 ||r(i)||/||b|| 2.350161625235e-08
> >> 121 KSP unpreconditioned resid norm 8.749457237613e-07 true resid norm
> >> 8.749457236791e-07 ||r(i)||/||b|| 2.179207546261e-08
> >> 122 KSP unpreconditioned resid norm 7.945760150897e-07 true resid norm
> >> 7.945760150444e-07 ||r(i)||/||b|| 1.979032528762e-08
> >> 123 KSP unpreconditioned resid norm 7.141240839013e-07 true resid norm
> >> 7.141240838682e-07 ||r(i)||/||b|| 1.778652721438e-08
> >> 124 KSP unpreconditioned resid norm 6.300566936733e-07 true resid norm
> >> 6.300566936607e-07 ||r(i)||/||b|| 1.569267971988e-08
> >> 125 KSP unpreconditioned resid norm 5.628986997544e-07 true resid norm
> >> 5.628986995849e-07 ||r(i)||/||b|| 1.401999073448e-08
> >> 126 KSP unpreconditioned resid norm 5.119018951602e-07 true resid norm
> >> 5.119018951837e-07 ||r(i)||/||b|| 1.274982484900e-08
> >> 127 KSP unpreconditioned resid norm 4.664670343748e-07 true resid norm
> >> 4.664670344042e-07 ||r(i)||/||b|| 1.161818903670e-08
> >> 128 KSP unpreconditioned resid norm 4.253264691112e-07 true resid norm
> >> 4.253264691948e-07 ||r(i)||/||b|| 1.059351027394e-08
> >> 129 KSP unpreconditioned resid norm 3.868921150516e-07 true resid norm
> >> 3.868921150517e-07 ||r(i)||/||b|| 9.636234498800e-09
> >> 130 KSP unpreconditioned resid norm 3.558445658540e-07 true resid norm
> >> 3.558445660061e-07 ||r(i)||/||b|| 8.862940209315e-09
> >> 131 KSP unpreconditioned resid norm 3.268710273840e-07 true resid norm
> >> 3.268710272455e-07 ||r(i)||/||b|| 8.141302825416e-09
> >> 132 KSP unpreconditioned resid norm 3.041273897592e-07 true resid norm
> >> 3.041273896694e-07 ||r(i)||/||b|| 7.574832182794e-09
> >> 133 KSP unpreconditioned resid norm 2.851926677922e-07 true resid norm
> >> 2.851926674248e-07 ||r(i)||/||b|| 7.103229333782e-09
> >> 134 KSP unpreconditioned resid norm 2.694708315072e-07 true resid norm
> >> 2.694708309500e-07 ||r(i)||/||b|| 6.711649104748e-09
> >> 135 KSP unpreconditioned resid norm 2.534825559099e-07 true resid norm
> >> 2.534825557469e-07 ||r(i)||/||b|| 6.313432746507e-09
> >> 136 KSP unpreconditioned resid norm 2.387342352458e-07 true resid norm
> >> 2.387342351804e-07 ||r(i)||/||b|| 5.946099658254e-09
> >> 137 KSP unpreconditioned resid norm 2.200861667617e-07 true resid norm
> >> 2.200861665255e-07 ||r(i)||/||b|| 5.481636425438e-09
> >> 138 KSP unpreconditioned resid norm 2.051415370616e-07 true resid norm
> >> 2.051415370614e-07 ||r(i)||/||b|| 5.109413915824e-09
> >> 139 KSP unpreconditioned resid norm 1.887376429396e-07 true resid norm
> >> 1.887376426682e-07 ||r(i)||/||b|| 4.700845824315e-09
> >> 140 KSP unpreconditioned resid norm 1.729743133005e-07 true resid norm
> >> 1.729743128342e-07 ||r(i)||/||b|| 4.308232129561e-09
> >> 141 KSP unpreconditioned resid norm 1.541021130781e-07 true resid norm
> >> 1.541021128364e-07 ||r(i)||/||b|| 3.838186508023e-09
> >> 142 KSP unpreconditioned resid norm 1.384631628565e-07 true resid norm
> >> 1.384631627735e-07 ||r(i)||/||b|| 3.448670712125e-09
> >> 143 KSP unpreconditioned resid norm 1.223114405626e-07 true resid norm
> >> 1.223114403883e-07 ||r(i)||/||b|| 3.046383411846e-09
> >> 144 KSP unpreconditioned resid norm 1.087313066223e-07 true resid norm
> >> 1.087313065117e-07 ||r(i)||/||b|| 2.708146085550e-09
> >> 145 KSP unpreconditioned resid norm 9.181901998734e-08 true resid norm
> >> 9.181901984268e-08 ||r(i)||/||b|| 2.286915582489e-09
> >> 146 KSP unpreconditioned resid norm 7.885850510808e-08 true resid norm
> >> 7.885850531446e-08 ||r(i)||/||b|| 1.964110975313e-09
> >> 147 KSP unpreconditioned resid norm 6.483393946950e-08 true resid norm
> >> 6.483393931383e-08 ||r(i)||/||b|| 1.614804278515e-09
> >> 148 KSP unpreconditioned resid norm 5.690132597004e-08 true resid norm
> >> 5.690132577518e-08 ||r(i)||/||b|| 1.417228465328e-09
> >> 149 KSP unpreconditioned resid norm 5.023671521579e-08 true resid norm
> >> 5.023671502186e-08 ||r(i)||/||b|| 1.251234511035e-09
> >> 150 KSP unpreconditioned resid norm 4.625371062660e-08 true resid norm
> >> 4.625371062660e-08 ||r(i)||/||b|| 1.152030720445e-09
> >> 151 KSP unpreconditioned resid norm 4.349049084805e-08 true resid norm
> >> 4.349049089337e-08 ||r(i)||/||b|| 1.083207830846e-09
> >> 152 KSP unpreconditioned resid norm 3.932593324498e-08 true resid norm
> >> 3.932593376918e-08 ||r(i)||/||b|| 9.794821474546e-10
> >> 153 KSP unpreconditioned resid norm 3.504167649202e-08 true resid norm
> >> 3.504167638113e-08 ||r(i)||/||b|| 8.727751166356e-10
> >> 154 KSP unpreconditioned resid norm 2.892726347747e-08 true resid norm
> >> 2.892726348583e-08 ||r(i)||/||b|| 7.204848160858e-10
> >> 155 KSP unpreconditioned resid norm 2.477647033202e-08 true resid norm
> >> 2.477647041570e-08 ||r(i)||/||b|| 6.171019508795e-10
> >> 156 KSP unpreconditioned resid norm 2.128504065757e-08 true resid norm
> >> 2.128504067423e-08 ||r(i)||/||b|| 5.301416991298e-10
> >> 157 KSP unpreconditioned resid norm 1.879248809429e-08 true resid norm
> >> 1.879248818928e-08 ||r(i)||/||b|| 4.680602575310e-10
> >> 158 KSP unpreconditioned resid norm 1.673649140073e-08 true resid norm
> >> 1.673649134005e-08 ||r(i)||/||b|| 4.168520085200e-10
> >> 159 KSP unpreconditioned resid norm 1.497123388109e-08 true resid norm
> >> 1.497123365569e-08 ||r(i)||/||b|| 3.728851342016e-10
> >> 160 KSP unpreconditioned resid norm 1.315982130162e-08 true resid norm
> >> 1.315982149329e-08 ||r(i)||/||b|| 3.277687007261e-10
> >> 161 KSP unpreconditioned resid norm 1.182395864938e-08 true resid norm
> >> 1.182395868430e-08 ||r(i)||/||b|| 2.944966675550e-10
> >> 162 KSP unpreconditioned resid norm 1.070204481679e-08 true resid norm
> >> 1.070204466432e-08 ||r(i)||/||b|| 2.665534085342e-10
> >> 163 KSP unpreconditioned resid norm 9.969290307649e-09 true resid norm
> >> 9.969290432333e-09 ||r(i)||/||b|| 2.483028644297e-10
> >> 164 KSP unpreconditioned resid norm 9.134440883306e-09 true resid norm
> >> 9.134440980976e-09 ||r(i)||/||b|| 2.275094577628e-10
> >> 165 KSP unpreconditioned resid norm 8.593316427292e-09 true resid norm
> >> 8.593316413360e-09 ||r(i)||/||b|| 2.140317904139e-10
> >> 166 KSP unpreconditioned resid norm 8.042173048464e-09 true resid norm
> >> 8.042173332848e-09 ||r(i)||/||b|| 2.003045942277e-10
> >> 167 KSP unpreconditioned resid norm 7.655518522782e-09 true resid norm
> >> 7.655518879144e-09 ||r(i)||/||b|| 1.906742791064e-10
> >> 168 KSP unpreconditioned resid norm 7.210283391815e-09 true resid norm
> >> 7.210283220312e-09 ||r(i)||/||b|| 1.795848951442e-10
> >> 169 KSP unpreconditioned resid norm 6.793967416271e-09 true resid norm
> >> 6.793967448832e-09 ||r(i)||/||b|| 1.692158122825e-10
> >> 170 KSP unpreconditioned resid norm 6.249160304588e-09 true resid norm
> >> 6.249160382647e-09 ||r(i)||/||b|| 1.556464257736e-10
> >> 171 KSP unpreconditioned resid norm 5.794936438798e-09 true resid norm
> >> 5.794936332552e-09 ||r(i)||/||b|| 1.443331699811e-10
> >> 172 KSP unpreconditioned resid norm 5.222337397128e-09 true resid norm
> >> 5.222337443277e-09 ||r(i)||/||b|| 1.300715788135e-10
> >> 173 KSP unpreconditioned resid norm 4.755359110447e-09 true resid norm
> >> 4.755358888996e-09 ||r(i)||/||b|| 1.184406494668e-10
> >> 174 KSP unpreconditioned resid norm 4.317537007873e-09 true resid norm
> >> 4.317537267718e-09 ||r(i)||/||b|| 1.075359252630e-10
> >> 175 KSP unpreconditioned resid norm 3.924177535665e-09 true resid norm
> >> 3.924177629720e-09 ||r(i)||/||b|| 9.773860563138e-11
> >> 176 KSP unpreconditioned resid norm 3.502843065115e-09 true resid norm
> >> 3.502843126359e-09 ||r(i)||/||b|| 8.724452234855e-11
> >> 177 KSP unpreconditioned resid norm 3.083873232869e-09 true resid norm
> >> 3.083873352938e-09 ||r(i)||/||b|| 7.680933686007e-11
> >> 178 KSP unpreconditioned resid norm 2.758980676473e-09 true resid norm
> >> 2.758980618096e-09 ||r(i)||/||b|| 6.871730691658e-11
> >> 179 KSP unpreconditioned resid norm 2.510978240429e-09 true resid norm
> >> 2.510978327392e-09 ||r(i)||/||b|| 6.254036989334e-11
> >> 180 KSP unpreconditioned resid norm 2.323000193205e-09 true resid norm
> >> 2.323000193205e-09 ||r(i)||/||b|| 5.785844097519e-11
> >> 181 KSP unpreconditioned resid norm 2.167480159274e-09 true resid norm
> >> 2.167480113693e-09 ||r(i)||/||b|| 5.398493749153e-11
> >> 182 KSP unpreconditioned resid norm 1.983545827983e-09 true resid norm
> >> 1.983546404840e-09 ||r(i)||/||b|| 4.940374216139e-11
> >> 183 KSP unpreconditioned resid norm 1.794576286774e-09 true resid norm
> >> 1.794576224361e-09 ||r(i)||/||b|| 4.469710457036e-11
> >> 184 KSP unpreconditioned resid norm 1.583490590644e-09 true resid norm
> >> 1.583490380603e-09 ||r(i)||/||b|| 3.943963715064e-11
> >> 185 KSP unpreconditioned resid norm 1.412659866247e-09 true resid norm
> >> 1.412659832191e-09 ||r(i)||/||b|| 3.518479927722e-11
> >> 186 KSP unpreconditioned resid norm 1.285613344939e-09 true resid norm
> >> 1.285612984761e-09 ||r(i)||/||b|| 3.202047215205e-11
> >> 187 KSP unpreconditioned resid norm 1.168115133929e-09 true resid norm
> >> 1.168114766904e-09 ||r(i)||/||b|| 2.909397058634e-11
> >> 188 KSP unpreconditioned resid norm 1.063377926053e-09 true resid norm
> >> 1.063377647554e-09 ||r(i)||/||b|| 2.648530681802e-11
> >> 189 KSP unpreconditioned resid norm 9.548967728122e-10 true resid norm
> >> 9.548964523410e-10 ||r(i)||/||b|| 2.378339019807e-11
> >> KSP Object: 16 MPI processes
> >> type: fgmres
> >> restart=30, using Classical (unmodified) Gram-Schmidt
> >> Orthogonalization with no iterative refinement
> >> happy breakdown tolerance 1e-30
> >> maximum iterations=2000, initial guess is zero
> >> tolerances: relative=1e-20, absolute=1e-09, divergence=10000.
> >> right preconditioning
> >> using UNPRECONDITIONED norm type for convergence test
> >> PC Object: 16 MPI processes
> >> type: bjacobi
> >> number of blocks = 4
> >> Local solver information for first block is in the following KSP
> >> and PC objects on rank 0:
> >> Use -ksp_view ::ascii_info_detail to display information for all
> blocks
> >> KSP Object: (sub_) 4 MPI processes
> >> type: preonly
> >> maximum iterations=10000, initial guess is zero
> >> tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
> >> left preconditioning
> >> using NONE norm type for convergence test
> >> PC Object: (sub_) 4 MPI processes
> >> type: telescope
> >> petsc subcomm: parent comm size reduction factor = 4
> >> petsc subcomm: parent_size = 4 , subcomm_size = 1
> >> petsc subcomm type = contiguous
> >> linear system matrix = precond matrix:
> >> Mat Object: (sub_) 4 MPI processes
> >> type: mpiaij
> >> rows=40200, cols=40200
> >> total: nonzeros=199996, allocated nonzeros=203412
> >> total number of mallocs used during MatSetValues calls=0
> >> not using I-node (on process 0) routines
> >> setup type: default
> >> Parent DM object: NULL
> >> Sub DM object: NULL
> >> KSP Object: (sub_telescope_) 1 MPI processes
> >> type: preonly
> >> PC Object: (sub_telescope_) 1 MPI processes
> >> type: lu
> >> out-of-place factorization
> >> tolerance for zero pivot 2.22045e-14
> >> matrix ordering: external
> >> factor fill ratio given 0., needed 0.
> >> Factored matrix follows:
> >> Mat Object: 1 MPI processes
> >> type: mumps
> >> package used to perform factorization: mumps
> >> total: nonzeros=1849788, allocated nonzeros=1849788
> >> MUMPS run parameters:
> >> SYM (matrix type): 0
> >> PAR (host participation): 1
> >> ICNTL(1) (output for error): 6
> >> ICNTL(2) (output of diagnostic msg): 0
> >> ICNTL(3) (output for global info): 0
> >> ICNTL(4) (level of printing): 0
> >> ICNTL(5) (input mat struct): 0
> >> ICNTL(6) (matrix prescaling): 7
> >> ICNTL(7) (sequential matrix ordering):7
> >> ICNTL(8) (scaling strategy): 77
> >> ICNTL(10) (max num of refinements): 0
> >> ICNTL(11) (error analysis): 0
> >> ICNTL(12) (efficiency control): 1
> >> ICNTL(13) (sequential factorization of the root
> >> node): 0
> >> ICNTL(14) (percentage of estimated workspace
> >> increase): 20
> >> ICNTL(18) (input mat struct): 0
> >> ICNTL(19) (Schur complement info): 0
> >> ICNTL(20) (RHS sparse pattern): 0
> >> ICNTL(21) (solution struct): 0
> >> ICNTL(22) (in-core/out-of-core facility): 0
> >> ICNTL(23) (max size of memory can be allocated
> >> locally):0
> >> ICNTL(24) (detection of null pivot rows): 0
> >> ICNTL(25) (computation of a null space basis):
> >> 0
> >> ICNTL(26) (Schur options for RHS or solution):
> >> 0
> >> ICNTL(27) (blocking size for multiple RHS):
> >> -32
> >> ICNTL(28) (use parallel or sequential ordering):
> >> 1
> >> ICNTL(29) (parallel ordering): 0
> >> ICNTL(30) (user-specified set of entries in
> >> inv(A)): 0
> >> ICNTL(31) (factors is discarded in the solve
> >> phase): 0
> >> ICNTL(33) (compute determinant): 0
> >> ICNTL(35) (activate BLR based factorization):
> >> 0
> >> ICNTL(36) (choice of BLR factorization variant):
> >> 0
> >> ICNTL(38) (estimated compression rate of LU
> >> factors): 333
> >> CNTL(1) (relative pivoting threshold): 0.01
> >> CNTL(2) (stopping criterion of refinement):
> >> 1.49012e-08
> >> CNTL(3) (absolute pivoting threshold): 0.
> >> CNTL(4) (value of static pivoting): -1.
> >> CNTL(5) (fixation for null pivots): 0.
> >> CNTL(7) (dropping parameter for BLR): 0.
> >> RINFO(1) (local estimated flops for the
> >> elimination after analysis):
> >> [0] 1.45525e+08
> >> RINFO(2) (local estimated flops for the assembly
> >> after factorization):
> >> [0] 2.89397e+06
> >> RINFO(3) (local estimated flops for the
> >> elimination after factorization):
> >> [0] 1.45525e+08
> >> INFO(15) (estimated size of (in MB) MUMPS
> >> internal data for running numerical factorization):
> >> [0] 29
> >> INFO(16) (size of (in MB) MUMPS internal data
> >> used during numerical factorization):
> >> [0] 29
> >> INFO(23) (num of pivots eliminated on this
> >> processor after factorization):
> >> [0] 40200
> >> RINFOG(1) (global estimated flops for the
> >> elimination after analysis): 1.45525e+08
> >> RINFOG(2) (global estimated flops for the
> >> assembly after factorization): 2.89397e+06
> >> RINFOG(3) (global estimated flops for the
> >> elimination after factorization): 1.45525e+08
> >> (RINFOG(12) RINFOG(13))*2^INFOG(34)
> >> (determinant): (0.,0.)*(2^0)
> >> INFOG(3) (estimated real workspace for factors on
> >> all processors after analysis): 1849788
> >> INFOG(4) (estimated integer workspace for factors
> >> on all processors after analysis): 879986
> >> INFOG(5) (estimated maximum front size in the
> >> complete tree): 282
> >> INFOG(6) (number of nodes in the complete tree):
> >> 23709
> >> INFOG(7) (ordering option effectively used after
> >> analysis): 5
> >> INFOG(8) (structural symmetry in percent of the
> >> permuted matrix after analysis): 100
> >> INFOG(9) (total real/complex workspace to store
> >> the matrix factors after factorization): 1849788
> >> INFOG(10) (total integer space store the matrix
> >> factors after factorization): 879986
> >> INFOG(11) (order of largest frontal matrix after
> >> factorization): 282
> >> INFOG(12) (number of off-diagonal pivots): 0
> >> INFOG(13) (number of delayed pivots after
> >> factorization): 0
> >> INFOG(14) (number of memory compress after
> >> factorization): 0
> >> INFOG(15) (number of steps of iterative
> >> refinement after solution): 0
> >> INFOG(16) (estimated size (in MB) of all MUMPS
> >> internal data for factorization after analysis: value on the most
> >> memory consuming processor): 29
> >> INFOG(17) (estimated size of all MUMPS internal
> >> data for factorization after analysis: sum over all processors): 29
> >> INFOG(18) (size of all MUMPS internal data
> >> allocated during factorization: value on the most memory consuming
> >> processor): 29
> >> INFOG(19) (size of all MUMPS internal data
> >> allocated during factorization: sum over all processors): 29
> >> INFOG(20) (estimated number of entries in the
> >> factors): 1849788
> >> INFOG(21) (size in MB of memory effectively used
> >> during factorization - value on the most memory consuming processor): 26
> >> INFOG(22) (size in MB of memory effectively used
> >> during factorization - sum over all processors): 26
> >> INFOG(23) (after analysis: value of ICNTL(6)
> >> effectively used): 0
> >> INFOG(24) (after analysis: value of ICNTL(12)
> >> effectively used): 1
> >> INFOG(25) (after factorization: number of pivots
> >> modified by static pivoting): 0
> >> INFOG(28) (after factorization: number of null
> >> pivots encountered): 0
> >> INFOG(29) (after factorization: effective number
> >> of entries in the factors (sum over all processors)): 1849788
> >> INFOG(30, 31) (after solution: size in Mbytes of
> >> memory used during solution phase): 29, 29
> >> INFOG(32) (after analysis: type of analysis done):
> 1
> >> INFOG(33) (value used for ICNTL(8)): 7
> >> INFOG(34) (exponent of the determinant if
> >> determinant is requested): 0
> >> INFOG(35) (after factorization: number of entries
> >> taking into account BLR factor compression - sum over all processors):
> >> 1849788
> >> INFOG(36) (after analysis: estimated size of all
> >> MUMPS internal data for running BLR in-core - value on the most memory
> >> consuming processor): 0
> >> INFOG(37) (after analysis: estimated size of all
> >> MUMPS internal data for running BLR in-core - sum over all processors):
> 0
> >> INFOG(38) (after analysis: estimated size of all
> >> MUMPS internal data for running BLR out-of-core - value on the most
> >> memory consuming processor): 0
> >> INFOG(39) (after analysis: estimated size of all
> >> MUMPS internal data for running BLR out-of-core - sum over all
> >> processors): 0
> >> type: seqaijcusparse
> >> total: nonzeros=199996, allocated nonzeros=199996
> >> not using I-node routines
> >> Mat Object: 16 MPI processes
> >> type: mpiaijcusparse
> >> rows=160800, cols=160800
> >> total: nonzeros=802396, allocated nonzeros=1608000
> >> Norm of error 9.11684e-07 iterations 189
> >> Chang
> >> On 10/14/21 10:10 PM, Chang Liu wrote:
> >>> Hi Barry,
> >>> No problem. Here is the output. It seems that the resid norm
> >>> calculation is incorrect.
> >>> norm 4.014971979977e+01 ||r(i)||/||b|| 1.000000000000e+00
> >>> 1 KSP unpreconditioned resid norm 0.000000000000e+00 true resid
> >>> type: fgmres
> >>> type: bjacobi
> >>> blocks
> >>> type: preonly
> >>> type: telescope
> >>> type: mpiaij
> >>> setup type: default
> >>> Sub DM object: NULL
> >>> type: preonly
> divergence=10000.
> >>> type: lu
> >>> matrix ordering: nd
> >>> factor fill ratio given 5., needed 8.62558
> >>> package used to perform factorization: cusparse
> >>> total: nonzeros=1725082, allocated nonzeros=1725082
> >>> Norm of error 400.999 iterations 1
> >>> Chang
> >>> On 10/14/21 9:47 PM, Barry Smith wrote:
> >>>> Chang,
> >>>> Sorry I did not notice that one. Please run that with -ksp_view
> >>>> -ksp_monitor_true_residual so we can see exactly how options are
> >>>> interpreted and solver used. At a glance it looks ok but something
> >>>> must be wrong to get the wrong answer.
> >>>> Barry
> >>>>> On Oct 14, 2021, at 6:02 PM, Chang Liu <cliu at pppl.gov
> >>>>> Hi Barry,
> >>>>> That is exactly what I was doing in the second example, in which
> >>>>> the preconditioner works but the GMRES does not.
> >>>>> Chang
> >>>>> On 10/14/21 5:15 PM, Barry Smith wrote:
> >>>>>> You need to use the PCTELESCOPE inside the block Jacobi, not
> >>>>>> outside it. So something like -pc_type bjacobi -sub_pc_type
> >>>>>> telescope -sub_telescope_pc_type lu
> >>>>>>> On Oct 14, 2021, at 4:14 PM, Chang Liu <cliu at pppl.gov
> >>>>>>> Hi Pierre,
> >>>>>>> I wonder if the trick of PCTELESCOPE only works for
> >>>>>>> preconditioner and not for the solver. I have done some tests,
> >>>>>>> and find that for solving a small matrix using
> >>>>>>> -telescope_ksp_type preonly, it does work for GPU with multiple
> >>>>>>> MPI processes. However, for bjacobi and gmres, it does not work.
> >>>>>>> The command line options I used for small matrix is like
> >>>>>>> mpiexec -n 4 --oversubscribe ./ex7 -m 100 -ksp_monitor_short
> >>>>>>> -pc_type telescope -mat_type aijcusparse -telescope_pc_type lu
> >>>>>>> -telescope_pc_factor_mat_solver_type cusparse -telescope_ksp_type
> >>>>>>> preonly -pc_telescope_reduction_factor 4
> >>>>>>> which gives the correct output. For iterative solver, I tried
> >>>>>>> mpiexec -n 16 --oversubscribe ./ex7 -m 400 -ksp_monitor_short
> >>>>>>> -pc_type bjacobi -pc_bjacobi_blocks 4 -ksp_type fgmres -mat_type
> >>>>>>> aijcusparse -sub_pc_type telescope -sub_ksp_type preonly
> >>>>>>> -sub_telescope_ksp_type preonly -sub_telescope_pc_type lu
> >>>>>>> -sub_pc_telescope_reduction_factor 4 -ksp_max_it 2000 -ksp_rtol
> >>>>>>> 1.e-9 -ksp_atol 1.e-20
> >>>>>>> for large matrix. The output is like
> >>>>>>> 0 KSP Residual norm 40.1497
> >>>>>>> 1 KSP Residual norm < 1.e-11
> >>>>>>> So it seems to call a direct solver instead of an iterative one.
> >>>>>>> Can you please help check these options?
> >>>>>>> Chang
> >>>>>>> On 10/14/21 10:04 AM, Pierre Jolivet wrote:
> >>>>>>>>> On 14 Oct 2021, at 3:50 PM, Chang Liu <cliu at pppl.gov
> >>>>>>>>> Thank you Pierre. I was not aware of PCTELESCOPE before. This
> >>>>>>>>> sounds exactly what I need. I wonder if PCTELESCOPE can
> >>>>>>>>> transform a mpiaijcusparse to seqaircusparse? Or I have to do
> >>>>>>>>> it manually?
> >>>>>>>> PCTELESCOPE uses MatCreateMPIMatConcatenateSeqMat().
> >>>>>>>> 1) I’m not sure this is implemented for cuSparse matrices, but
> >>>>>>>> it should be;
> >>>>>>>> 2) at least for the implementations
> >>>>>>>> MatCreateMPIMatConcatenateSeqMat_MPIBAIJ() and
> >>>>>>>> MatCreateMPIMatConcatenateSeqMat_MPIAIJ(), the resulting MatType
> >>>>>>>> is MATBAIJ (resp. MATAIJ). Constructors are usually “smart”
> >>>>>>>> enough to detect if the MPI communicator on which the Mat lives
> >>>>>>>> is of size 1 (your case), and then the resulting Mat is of type
> >>>>>>>> MatSeqX instead of MatMPIX, so you would not need to worry about
> >>>>>>>> the transformation you are mentioning.
> >>>>>>>> If you try this out and this does not work, please provide the
> >>>>>>>> backtrace (probably something like “Operation XYZ not
> >>>>>>>> implemented for MatType ABC”), and hopefully someone can add the
> >>>>>>>> missing plumbing.
> >>>>>>>> I do not claim that this will be efficient, but I think this
> >>>>>>>> goes in the direction of what you want to achieve.
> >>>>>>>> Thanks,
> >>>>>>>> Pierre
> >>>>>>>>> Chang
> >>>>>>>>> On 10/14/21 1:35 AM, Pierre Jolivet wrote:
> >>>>>>>>>> Maybe I’m missing something, but can’t you use PCTELESCOPE as
> >>>>>>>>>> a subdomain solver, with a reduction factor equal to the
> >>>>>>>>>> number of MPI processes you have per block?
> >>>>>>>>>> -sub_pc_type telescope -sub_pc_telescope_reduction_factor X
> >>>>>>>>>> This does not work with MUMPS -mat_mumps_use_omp_threads
> >>>>>>>>>> because not only do the Mat needs to be redistributed, the
> >>>>>>>>>> secondary processes also need to be “converted” to OpenMP
> threads.
> >>>>>>>>>> Thus the need for specific code in mumps.c.
> >>>>>>>>>> Thanks,
> >>>>>>>>>> Pierre
> >>>>>>>>>>> On 14 Oct 2021, at 6:00 AM, Chang Liu via petsc-users
> >>>>>>>>>>> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
> wrote:
> >>>>>>>>>>> Hi Junchao,
> >>>>>>>>>>> Yes that is what I want.
> >>>>>>>>>>> Chang
> >>>>>>>>>>> On 10/13/21 11:42 PM, Junchao Zhang wrote:
> >>>>>>>>>>>> On Wed, Oct 13, 2021 at 8:58 PM Barry Smith
> >>>>>>>>>>>> <bsmith at petsc.dev <mailto:bsmith at petsc.dev>
> >>>>>>>>>>>> <mailto:bsmith at petsc.dev <mailto:bsmith at petsc.dev>>> wrote:
> >>>>>>>>>>>> Junchao,
> >>>>>>>>>>>> If I understand correctly Chang is using the block
> >>>>>>>>>>>> Jacobi
> >>>>>>>>>>>> method with a single block for a number of MPI ranks and
> >>>>>>>>>>>> a direct
> >>>>>>>>>>>> solver for each block so it uses
> >>>>>>>>>>>> PCSetUp_BJacobi_Multiproc() which
> >>>>>>>>>>>> is code Hong Zhang wrote a number of years ago for CPUs.
> >>>>>>>>>>>> For their
> >>>>>>>>>>>> particular problems this preconditioner works well, but
> >>>>>>>>>>>> using an
> >>>>>>>>>>>> iterative solver on the blocks does not work well.
> >>>>>>>>>>>> If we had complete MPI-GPU direct solvers he could
> >>>>>>>>>>>> just use
> >>>>>>>>>>>> the current code with MPIAIJCUSPARSE on each block but
> >>>>>>>>>>>> since we do
> >>>>>>>>>>>> not he would like to use a single GPU for each block,
> >>>>>>>>>>>> this means
> >>>>>>>>>>>> that diagonal blocks of the global parallel MPI matrix
> >>>>>>>>>>>> needs to be
> >>>>>>>>>>>> sent to a subset of the GPUs (one GPU per block, which
> >>>>>>>>>>>> has multiple
> >>>>>>>>>>>> MPI ranks associated with the blocks). Similarly for the
> >>>>>>>>>>>> triangular
> >>>>>>>>>>>> solves the blocks of the right hand side needs to be
> >>>>>>>>>>>> shipped to the
> >>>>>>>>>>>> appropriate GPU and the resulting solution shipped back
> >>>>>>>>>>>> to the
> >>>>>>>>>>>> multiple GPUs. So Chang is absolutely correct, this is
> >>>>>>>>>>>> somewhat like
> >>>>>>>>>>>> your code for MUMPS with OpenMP. OK, I now understand
> >>>>>>>>>>>> the background..
> >>>>>>>>>>>> One could use PCSetUp_BJacobi_Multiproc() and get the
> >>>>>>>>>>>> blocks on the
> >>>>>>>>>>>> MPI ranks and then shrink each block down to a single
> >>>>>>>>>>>> GPU but this
> >>>>>>>>>>>> would be pretty inefficient, ideally one would go
> >>>>>>>>>>>> directly from the
> >>>>>>>>>>>> big MPI matrix on all the GPUs to the sub matrices on
> >>>>>>>>>>>> the subset of
> >>>>>>>>>>>> GPUs. But this may be a large coding project.
> >>>>>>>>>>>> I don't understand these sentences. Why do you say "shrink"?
> >>>>>>>>>>>> In my mind, we just need to move each block (submatrix)
> >>>>>>>>>>>> living over multiple MPI ranks to one of them and solve
> >>>>>>>>>>>> directly there. In other words, we keep blocks' size, no
> >>>>>>>>>>>> shrinking or expanding.
> >>>>>>>>>>>> As mentioned before, cusparse does not provide LU
> >>>>>>>>>>>> factorization. So the LU factorization would be done on CPU,
> >>>>>>>>>>>> and the solve be done on GPU. I assume Chang wants to gain
> >>>>>>>>>>>> from the (potential) faster solve (instead of factorization)
> >>>>>>>>>>>> on GPU.
> >>>>>>>>>>>> Barry
> >>>>>>>>>>>> Since the matrices being factored and solved directly
> >>>>>>>>>>>> are relatively
> >>>>>>>>>>>> large it is possible that the cusparse code could be
> >>>>>>>>>>>> reasonably
> >>>>>>>>>>>> efficient (they are not the tiny problems one gets at
> >>>>>>>>>>>> the coarse
> >>>>>>>>>>>> level of multigrid). Of course, this is speculation, I
> don't
> >>>>>>>>>>>> actually know how much better the cusparse code would be
> >>>>>>>>>>>> on the
> >>>>>>>>>>>> direct solver than a good CPU direct sparse solver.
> >>>>>>>>>>>> > On Oct 13, 2021, at 9:32 PM, Chang Liu <cliu at pppl.gov
> >>>>>>>>>>>> <mailto:cliu at pppl.gov <mailto:cliu at pppl.gov>>> wrote:
> >>>>>>>>>>>> > Sorry I am not familiar with the details either. Can
> >>>>>>>>>>>> you please
> >>>>>>>>>>>> check the code in MatMumpsGatherNonzerosOnMaster in
> mumps.c?
> >>>>>>>>>>>> > Chang
> >>>>>>>>>>>> > On 10/13/21 9:24 PM, Junchao Zhang wrote:
> >>>>>>>>>>>> >> Hi Chang,
> >>>>>>>>>>>> >> I did the work in mumps. It is easy for me to
> >>>>>>>>>>>> understand
> >>>>>>>>>>>> gathering matrix rows to one process.
> >>>>>>>>>>>> >> But how to gather blocks (submatrices) to form a
> >>>>>>>>>>>> large block? Can you draw a picture of that?
> >>>>>>>>>>>> >> Thanks
> >>>>>>>>>>>> >> --Junchao Zhang
> >>>>>>>>>>>> >> On Wed, Oct 13, 2021 at 7:47 PM Chang Liu via
> >>>>>>>>>>>> petsc-users
> >>>>>>>>>>>> <mailto:petsc-users at mcs.anl.gov>>>>
> >>>>>>>>>>>> wrote:
> >>>>>>>>>>>> >> Hi Barry,
> >>>>>>>>>>>> >> I think mumps solver in petsc does support that.
> >>>>>>>>>>>> You can
> >>>>>>>>>>>> check the
> >>>>>>>>>>>> >> documentation on "-mat_mumps_use_omp_threads" at
> https://petsc.org/release/docs/manualpages/Mat/MATSOLVERMUMPS.html
> https://petsc.org/release/docs/manualpages/Mat/MATSOLVERMUMPS.html>
> https://petsc.org/release/docs/manualpages/Mat/MATSOLVERMUMPS.html>>
> https://petsc.org/release/docs/manualpages/Mat/MATSOLVERMUMPS.html>>>
> >>>>>>>>>>>> >> and the code enclosed by #if
> >>>>>>>>>>>> defined(PETSC_HAVE_OPENMP_SUPPORT) in
> >>>>>>>>>>>> >> functions MatMumpsSetUpDistRHSInfo and
> >>>>>>>>>>>> >> mumps.c
> >>>>>>>>>>>> >> 1. I understand it is ideal to do one MPI rank
> >>>>>>>>>>>> per GPU.
> >>>>>>>>>>>> However, I am
> >>>>>>>>>>>> >> working on an existing code that was developed
> >>>>>>>>>>>> based on MPI
> >>>>>>>>>>>> and the the
> >>>>>>>>>>>> >> # of mpi ranks is typically equal to # of cpu
> >>>>>>>>>>>> cores. We don't
> >>>>>>>>>>>> want to
> >>>>>>>>>>>> >> change the whole structure of the code.
> >>>>>>>>>>>> >> 2. What you have suggested has been coded in
> >>>>>>>>>>>> mumps.c. See
> >>>>>>>>>>>> function
> >>>>>>>>>>>> >> MatMumpsSetUpDistRHSInfo.
> >>>>>>>>>>>> >> Regards,
> >>>>>>>>>>>> >> Chang
> >>>>>>>>>>>> >> On 10/13/21 7:53 PM, Barry Smith wrote:
> >>>>>>>>>>>> >> >> On Oct 13, 2021, at 3:50 PM, Chang Liu
> >>>>>>>>>>>> <cliu at pppl.gov <mailto:cliu at pppl.gov>
> >>>>>>>>>>>> <mailto:cliu at pppl.gov <mailto:cliu at pppl.gov>>>> wrote:
> >>>>>>>>>>>> >> >> Hi Barry,
> >>>>>>>>>>>> >> >> That is exactly what I want.
> >>>>>>>>>>>> >> >> Back to my original question, I am looking
> >>>>>>>>>>>> for an approach to
> >>>>>>>>>>>> >> transfer
> >>>>>>>>>>>> >> >> matrix
> >>>>>>>>>>>> >> >> data from many MPI processes to "master" MPI
> >>>>>>>>>>>> >> >> processes, each of which taking care of one
> >>>>>>>>>>>> GPU, and then
> >>>>>>>>>>>> upload
> >>>>>>>>>>>> >> the data to GPU to
> >>>>>>>>>>>> >> >> solve.
> >>>>>>>>>>>> >> >> One can just grab some codes from mumps.c to
> >>>>>>>>>>>> aijcusparse.cu <http://aijcusparse.cu
> >>>>>>>>>>>> <http://aijcusparse.cu>>
> >>>>>>>>>>>> >> <http://aijcusparse.cu <http://aijcusparse.cu>
> >>>>>>>>>>>> <http://aijcusparse.cu <http://aijcusparse.cu>>>.
> >>>>>>>>>>>> >> > mumps.c doesn't actually do that. It never
> >>>>>>>>>>>> needs to
> >>>>>>>>>>>> copy the
> >>>>>>>>>>>> >> entire matrix to a single MPI rank.
> >>>>>>>>>>>> >> > It would be possible to write such a code
> >>>>>>>>>>>> that you
> >>>>>>>>>>>> suggest but
> >>>>>>>>>>>> >> it is not clear that it makes sense
> >>>>>>>>>>>> >> > 1) For normal PETSc GPU usage there is one
> >>>>>>>>>>>> GPU per MPI
> >>>>>>>>>>>> rank, so
> >>>>>>>>>>>> >> while your one GPU per big domain is solving its
> >>>>>>>>>>>> systems the
> >>>>>>>>>>>> other
> >>>>>>>>>>>> >> GPUs (with the other MPI ranks that share that
> >>>>>>>>>>>> domain) are doing
> >>>>>>>>>>>> >> nothing.
> >>>>>>>>>>>> >> > 2) For each triangular solve you would have to
> >>>>>>>>>>>> gather the
> >>>>>>>>>>>> right
> >>>>>>>>>>>> >> hand side from the multiple ranks to the single
> >>>>>>>>>>>> GPU to pass it to
> >>>>>>>>>>>> >> the GPU solver and then scatter the resulting
> >>>>>>>>>>>> solution back
> >>>>>>>>>>>> to all
> >>>>>>>>>>>> >> of its subdomain ranks.
> >>>>>>>>>>>> >> > What I was suggesting was assign an entire
> >>>>>>>>>>>> subdomain to a
> >>>>>>>>>>>> >> single MPI rank, thus it does everything on one
> >>>>>>>>>>>> GPU and can
> >>>>>>>>>>>> use the
> >>>>>>>>>>>> >> GPU solver directly. If all the major
> >>>>>>>>>>>> computations of a subdomain
> >>>>>>>>>>>> >> can fit and be done on a single GPU then you would
> be
> >>>>>>>>>>>> utilizing all
> >>>>>>>>>>>> >> the GPUs you are using effectively.
> >>>>>>>>>>>> >> > Barry
> >>>>>>>>>>>> >> >> Chang
> >>>>>>>>>>>> >> >> On 10/13/21 1:53 PM, Barry Smith wrote:
> >>>>>>>>>>>> >> >>> Chang,
> >>>>>>>>>>>> >> >>> You are correct there is no MPI + GPU
> >>>>>>>>>>>> direct
> >>>>>>>>>>>> solvers that
> >>>>>>>>>>>> >> currently do the triangular solves with MPI + GPU
> >>>>>>>>>>>> parallelism
> >>>>>>>>>>>> that I
> >>>>>>>>>>>> >> am aware of. You are limited that individual
> >>>>>>>>>>>> triangular solves be
> >>>>>>>>>>>> >> done on a single GPU. I can only suggest making
> >>>>>>>>>>>> each subdomain as
> >>>>>>>>>>>> >> big as possible to utilize each GPU as much as
> >>>>>>>>>>>> possible for the
> >>>>>>>>>>>> >> direct triangular solves.
> >>>>>>>>>>>> >> >>> Barry
> >>>>>>>>>>>> >> >>>> On Oct 13, 2021, at 12:16 PM, Chang Liu via
> >>>>>>>>>>>> petsc-users
> >>>>>>>>>>>> wrote:
> >>>>>>>>>>>> >> >>>> Hi Mark,
> >>>>>>>>>>>> >> >>>> '-mat_type aijcusparse' works with
> >>>>>>>>>>>> mpiaijcusparse with
> >>>>>>>>>>>> other
> >>>>>>>>>>>> >> solvers, but with -pc_factor_mat_solver_type
> >>>>>>>>>>>> cusparse, it
> >>>>>>>>>>>> will give
> >>>>>>>>>>>> >> an error.
> >>>>>>>>>>>> >> >>>> Yes what I want is to have mumps or superlu
> >>>>>>>>>>>> to do the
> >>>>>>>>>>>> >> factorization, and then do the rest, including
> >>>>>>>>>>>> GMRES solver,
> >>>>>>>>>>>> on gpu.
> >>>>>>>>>>>> >> Is that possible?
> >>>>>>>>>>>> >> >>>> I have tried to use aijcusparse with
> >>>>>>>>>>>> superlu_dist, it
> >>>>>>>>>>>> runs but
> >>>>>>>>>>>> >> the iterative solver is still running on CPUs. I
> have
> >>>>>>>>>>>> contacted the
> >>>>>>>>>>>> >> superlu group and they confirmed that is the case
> >>>>>>>>>>>> right now.
> >>>>>>>>>>>> But if
> >>>>>>>>>>>> >> I set -pc_factor_mat_solver_type cusparse, it
> >>>>>>>>>>>> seems that the
> >>>>>>>>>>>> >> iterative solver is running on GPU.
> >>>>>>>>>>>> >> >>>> Chang
> >>>>>>>>>>>> >> >>>> On 10/13/21 12:03 PM, Mark Adams wrote:
> >>>>>>>>>>>> >> >>>>> On Wed, Oct 13, 2021 at 11:10 AM Chang Liu
> >>>>>>>>>>>> <mailto:cliu at pppl.gov <mailto:cliu at pppl.gov>>>>> wrote:
> >>>>>>>>>>>> >> >>>>> Thank you Junchao for explaining this.
> >>>>>>>>>>>> I guess in
> >>>>>>>>>>>> my case
> >>>>>>>>>>>> >> the code is
> >>>>>>>>>>>> >> >>>>> just calling a seq solver like superlu
> >>>>>>>>>>>> to do
> >>>>>>>>>>>> >> factorization on GPUs.
> >>>>>>>>>>>> >> >>>>> My idea is that I want to have a
> >>>>>>>>>>>> traditional MPI
> >>>>>>>>>>>> code to
> >>>>>>>>>>>> >> utilize GPUs
> >>>>>>>>>>>> >> >>>>> with cusparse. Right now cusparse does
> >>>>>>>>>>>> not support
> >>>>>>>>>>>> mpiaij
> >>>>>>>>>>>> >> matrix, Sure it does: '-mat_type aijcusparse'
> >>>>>>>>>>>> will give you an
> >>>>>>>>>>>> >> mpiaijcusparse matrix with > 1 processes.
> >>>>>>>>>>>> >> >>>>> (-mat_type mpiaijcusparse might also work
> >>>>>>>>>>>> with >1 proc).
> >>>>>>>>>>>> >> >>>>> However, I see in grepping the repo that
> >>>>>>>>>>>> all the mumps and
> >>>>>>>>>>>> >> superlu tests use aij or sell matrix type.
> >>>>>>>>>>>> >> >>>>> MUMPS and SuperLU provide their own
> >>>>>>>>>>>> solves, I assume
> >>>>>>>>>>>> .... but
> >>>>>>>>>>>> >> you might want to do other matrix operations on
> >>>>>>>>>>>> the GPU. Is
> >>>>>>>>>>>> that the
> >>>>>>>>>>>> >> issue?
> >>>>>>>>>>>> >> >>>>> Did you try -mat_type aijcusparse with
> >>>>>>>>>>>> MUMPS and/or
> >>>>>>>>>>>> SuperLU
> >>>>>>>>>>>> >> have a problem? (no test with it so it probably
> >>>>>>>>>>>> does not work)
> >>>>>>>>>>>> >> >>>>> Thanks,
> >>>>>>>>>>>> >> >>>>> Mark
> >>>>>>>>>>>> >> >>>>> so I
> >>>>>>>>>>>> >> >>>>> want the code to have a mpiaij matrix
> >>>>>>>>>>>> when adding
> >>>>>>>>>>>> all the
> >>>>>>>>>>>> >> matrix terms,
> >>>>>>>>>>>> >> >>>>> and then transform the matrix to
> >>>>>>>>>>>> seqaij when doing the
> >>>>>>>>>>>> >> factorization
> >>>>>>>>>>>> >> >>>>> and
> >>>>>>>>>>>> >> >>>>> solve. This involves sending the data
> >>>>>>>>>>>> to the master
> >>>>>>>>>>>> >> process, and I
> >>>>>>>>>>>> >> >>>>> think
> >>>>>>>>>>>> >> >>>>> the petsc mumps solver have something
> >>>>>>>>>>>> similar already.
> >>>>>>>>>>>> >> >>>>> Chang
> >>>>>>>>>>>> >> >>>>> On 10/13/21 10:18 AM, Junchao Zhang
> wrote:
> >>>>>>>>>>>> >> >>>>> > On Tue, Oct 12, 2021 at 1:07 PM
> >>>>>>>>>>>> Mark Adams
> >>>>>>>>>>>> >> <mfadams at lbl.gov <mailto:mfadams at lbl.gov>
> >>>>>>>>>>>> <mailto:mfadams at lbl.gov <mailto:mfadams at lbl.gov>>
> >>>>>>>>>>>> <mailto:mfadams at lbl.gov <mailto:mfadams at lbl.gov>>>
> >>>>>>>>>>>> <mailto:mfadams at lbl.gov> <mailto:mfadams at lbl.gov
> >>>>>>>>>>>> <mailto:mfadams at lbl.gov <mailto:mfadams at lbl.gov>>>>
> >>>>>>>>>>>> <mailto:mfadams at lbl.gov <mailto:mfadams at lbl.gov>>>>>> wrote:
> >>>>>>>>>>>> >> >>>>> > On Tue, Oct 12, 2021 at 1:45 PM
> >>>>>>>>>>>> Chang Liu
> >>>>>>>>>>>> <mailto:cliu at pppl.gov> <mailto:cliu at pppl.gov
> >>>>>>>>>>>> <mailto:cliu at pppl.gov <mailto:cliu at pppl.gov>>>>>> wrote:
> >>>>>>>>>>>> >> >>>>> > Hi Mark,
> >>>>>>>>>>>> >> >>>>> > The option I use is like
> >>>>>>>>>>>> >> >>>>> > -pc_type bjacobi
> >>>>>>>>>>>> -pc_bjacobi_blocks 16
> >>>>>>>>>>>> >> -ksp_type fgmres
> >>>>>>>>>>>> >> >>>>> -mat_type
> >>>>>>>>>>>> >> >>>>> > aijcusparse
> >>>>>>>>>>>> *-sub_pc_factor_mat_solver_type
> >>>>>>>>>>>> >> cusparse
> >>>>>>>>>>>> >> >>>>> *-sub_ksp_type
> >>>>>>>>>>>> >> >>>>> > preonly *-sub_pc_type lu*
> >>>>>>>>>>>> -ksp_max_it 2000
> >>>>>>>>>>>> >> -ksp_rtol 1.e-300
> >>>>>>>>>>>> >> >>>>> > -ksp_atol 1.e-300
> >>>>>>>>>>>> >> >>>>> > Note, If you use -log_view the
> >>>>>>>>>>>> last column
> >>>>>>>>>>>> (rows
> >>>>>>>>>>>> >> are the
> >>>>>>>>>>>> >> >>>>> method like
> >>>>>>>>>>>> >> >>>>> > MatFactorNumeric) has the
> >>>>>>>>>>>> percent of work
> >>>>>>>>>>>> in the GPU.
> >>>>>>>>>>>> >> >>>>> > Junchao: *This* implies that we
> >>>>>>>>>>>> have a
> >>>>>>>>>>>> cuSparse LU
> >>>>>>>>>>>> >> >>>>> factorization. Is
> >>>>>>>>>>>> >> >>>>> > that correct? (I don't think we
> do)
> >>>>>>>>>>>> >> >>>>> > No, we don't have cuSparse LU
> >>>>>>>>>>>> factorization. If you check
> >>>>>>>>>>>> MatLUFactorSymbolic_SeqAIJCUSPARSE(),you will
> >>>>>>>>>>>> find it
> >>>>>>>>>>>> >> calls
> >>>>>>>>>>>> >> >>>>> > MatLUFactorSymbolic_SeqAIJ() instead.
> >>>>>>>>>>>> >> >>>>> > So I don't understand Chang's idea.
> >>>>>>>>>>>> Do you want to
> >>>>>>>>>>>> >> make bigger
> >>>>>>>>>>>> >> >>>>> blocks?
> >>>>>>>>>>>> >> >>>>> > I think this one do both
> >>>>>>>>>>>> factorization and
> >>>>>>>>>>>> >> solve on gpu.
> >>>>>>>>>>>> >> >>>>> > You can check the
> >>>>>>>>>>>> runex72_aijcusparse.sh file
> >>>>>>>>>>>> >> in petsc
> >>>>>>>>>>>> >> >>>>> install
> >>>>>>>>>>>> >> >>>>> > directory, and try it your
> >>>>>>>>>>>> self (this
> >>>>>>>>>>>> is only lu
> >>>>>>>>>>>> >> >>>>> factorization
> >>>>>>>>>>>> >> >>>>> > without
> >>>>>>>>>>>> >> >>>>> > iterative solve).
> >>>>>>>>>>>> >> >>>>> > Chang
> >>>>>>>>>>>> >> >>>>> > On 10/12/21 1:17 PM, Mark
> >>>>>>>>>>>> 11:19 AM
> >>>>>>>>>>>> Chang Liu
> >>>>>>>>>>>> <mailto:cliu at pppl.gov <mailto:cliu at pppl.gov>>>>>>> wrote:
> >>>>>>>>>>>> >> >>>>> > > Hi Junchao,
> >>>>>>>>>>>> >> >>>>> > > No I only needs it
> >>>>>>>>>>>> to be transferred
> >>>>>>>>>>>> >> within a
> >>>>>>>>>>>> >> >>>>> node. I use
> >>>>>>>>>>>> >> >>>>> > block-Jacobi
> >>>>>>>>>>>> >> >>>>> > > method and GMRES to
> >>>>>>>>>>>> solve the sparse
> >>>>>>>>>>>> >> matrix, so each
> >>>>>>>>>>>> >> >>>>> > direct solver will
> >>>>>>>>>>>> >> >>>>> > > take care of a
> >>>>>>>>>>>> sub-block of the
> >>>>>>>>>>>> whole
> >>>>>>>>>>>> >> matrix. In this
> >>>>>>>>>>>> >> >>>>> > way, I can use
> >>>>>>>>>>>> >> >>>>> > > one
> >>>>>>>>>>>> >> >>>>> > > GPU to solve one
> >>>>>>>>>>>> sub-block, which is
> >>>>>>>>>>>> >> stored within
> >>>>>>>>>>>> >> >>>>> one node.
> >>>>>>>>>>>> >> >>>>> > > It was stated in the
> >>>>>>>>>>>> documentation that
> >>>>>>>>>>>> >> cusparse
> >>>>>>>>>>>> >> >>>>> solver
> >>>>>>>>>>>> >> >>>>> > is slow.
> >>>>>>>>>>>> >> >>>>> > > However, in my test
> >>>>>>>>>>>> using
> >>>>>>>>>>>> ex72.c, the
> >>>>>>>>>>>> >> cusparse
> >>>>>>>>>>>> >> >>>>> solver is
> >>>>>>>>>>>> >> >>>>> > faster than
> >>>>>>>>>>>> >> >>>>> > > mumps or
> >>>>>>>>>>>> superlu_dist on CPUs.
> >>>>>>>>>>>> >> >>>>> > > Are we talking about the
> >>>>>>>>>>>> factorization, the
> >>>>>>>>>>>> >> solve, or
> >>>>>>>>>>>> >> >>>>> both?
> >>>>>>>>>>>> >> >>>>> > > We do not have an
> >>>>>>>>>>>> interface to
> >>>>>>>>>>>> cuSparse's LU
> >>>>>>>>>>>> >> >>>>> factorization (I
> >>>>>>>>>>>> >> >>>>> > just
> >>>>>>>>>>>> >> >>>>> > > learned that it exists a
> >>>>>>>>>>>> few weeks ago).
> >>>>>>>>>>>> >> >>>>> > > Perhaps your fast
> >>>>>>>>>>>> "cusparse solver" is
> >>>>>>>>>>>> >> '-pc_type lu
> >>>>>>>>>>>> >> >>>>> -mat_type
> >>>>>>>>>>>> >> >>>>> > > aijcusparse' ? This
> >>>>>>>>>>>> would be the CPU
> >>>>>>>>>>>> >> factorization,
> >>>>>>>>>>>> >> >>>>> which is the
> >>>>>>>>>>>> >> >>>>> > > dominant cost.
> >>>>>>>>>>>> >> >>>>> > > Chang
> >>>>>>>>>>>> >> >>>>> > > On 10/12/21 10:24
> >>>>>>>>>>>> AM, Junchao
> >>>>>>>>>>>> Zhang wrote:
> >>>>>>>>>>>> >> >>>>> > > > Hi, Chang,
> >>>>>>>>>>>> >> >>>>> > > > For the mumps
> >>>>>>>>>>>> solver, we
> >>>>>>>>>>>> usually
> >>>>>>>>>>>> >> transfers
> >>>>>>>>>>>> >> >>>>> matrix
> >>>>>>>>>>>> >> >>>>> > and vector
> >>>>>>>>>>>> >> >>>>> > > data
> >>>>>>>>>>>> >> >>>>> > > > within a compute
> >>>>>>>>>>>> node. For
> >>>>>>>>>>>> the idea you
> >>>>>>>>>>>> >> >>>>> propose, it
> >>>>>>>>>>>> >> >>>>> > looks like
> >>>>>>>>>>>> >> >>>>> > > we need
> >>>>>>>>>>>> >> >>>>> > > > to gather data
> within
> >>>>>>>>>>>> >> MPI_COMM_WORLD, right?
> >>>>>>>>>>>> >> >>>>> > > > Mark, I
> >>>>>>>>>>>> remember you said
> >>>>>>>>>>>> >> cusparse solve is
> >>>>>>>>>>>> >> >>>>> slow
> >>>>>>>>>>>> >> >>>>> > and you would
> >>>>>>>>>>>> >> >>>>> > > > rather do it on
> >>>>>>>>>>>> CPU. Is it right?
> >>>>>>>>>>>> >> >>>>> > > > --Junchao Zhang
> >>>>>>>>>>>> >> >>>>> > > > On Mon, Oct 11,
> >>>>>>>>>>>> 2021 at 10:25 PM
> >>>>>>>>>>>> >> Chang Liu via
> >>>>>>>>>>>> >> >>>>> petsc-users
> >>>>>>>>>>>> <mailto:petsc-users at mcs.anl.gov <mailto:
> >>>>>>>>>>>> <mailto:petsc-users at mcs.anl.gov>>>>>
> >>>>>>>>>>>> <mailto:petsc-users at mcs.anl.gov>>>>>>
> >>>>>>>>>>>> <mailto:petsc-users at mcs.anl.gov>>>>>>>>
> >>>>>>>>>>>> >> >>>>> > > wrote:
> >>>>>>>>>>>> >> >>>>> > > > Hi,
> >>>>>>>>>>>> >> >>>>> > > > Currently, it
> >>>>>>>>>>>> is possible
> >>>>>>>>>>>> to use
> >>>>>>>>>>>> >> mumps
> >>>>>>>>>>>> >> >>>>> solver in
> >>>>>>>>>>>> >> >>>>> > PETSC with
> >>>>>>>>>>>> >> option, so that
> >>>>>>>>>>>> >> >>>>> > multiple MPI
> >>>>>>>>>>>> >> >>>>> > > processes will
> >>>>>>>>>>>> >> >>>>> > > > transfer the
> >>>>>>>>>>>> matrix and
> >>>>>>>>>>>> rhs data
> >>>>>>>>>>>> >> to the master
> >>>>>>>>>>>> >> >>>>> > rank, and then
> >>>>>>>>>>>> >> >>>>> > > master
> >>>>>>>>>>>> >> >>>>> > > > rank will
> >>>>>>>>>>>> call mumps with
> >>>>>>>>>>>> OpenMP
> >>>>>>>>>>>> >> to solve
> >>>>>>>>>>>> >> >>>>> the matrix.
> >>>>>>>>>>>> >> >>>>> > > > I wonder if
> >>>>>>>>>>>> someone can
> >>>>>>>>>>>> develop
> >>>>>>>>>>>> >> similar
> >>>>>>>>>>>> >> >>>>> option for
> >>>>>>>>>>>> >> >>>>> > cusparse
> >>>>>>>>>>>> >> >>>>> > > solver.
> >>>>>>>>>>>> >> >>>>> > > > Right now,
> >>>>>>>>>>>> this solver
> >>>>>>>>>>>> does not
> >>>>>>>>>>>> >> work with
> >>>>>>>>>>>> >> >>>>> > mpiaijcusparse. I
> >>>>>>>>>>>> >> >>>>> > > think a
> >>>>>>>>>>>> >> >>>>> > > > possible
> >>>>>>>>>>>> workaround is to
> >>>>>>>>>>>> >> transfer all the
> >>>>>>>>>>>> >> >>>>> matrix
> >>>>>>>>>>>> >> >>>>> > data to one MPI
> >>>>>>>>>>>> >> >>>>> > > > process, and
> >>>>>>>>>>>> then upload the
> >>>>>>>>>>>> >> data to GPU to
> >>>>>>>>>>>> >> >>>>> solve.
> >>>>>>>>>>>> >> >>>>> > In this
> >>>>>>>>>>>> >> >>>>> > > way, one can
> >>>>>>>>>>>> >> >>>>> > > > use cusparse
> >>>>>>>>>>>> solver for a MPI
> >>>>>>>>>>>> >> program.
> >>>>>>>>>>>> >> >>>>> > > > Chang
> >>>>>>>>>>>> >> >>>>> > > > Chang Liu
> >>>>>>>>>>>> >> >>>>> > > > Staff
> >>>>>>>>>>>> Research Physicist
> >>>>>>>>>>>> >> >>>>> > > > +1 609 243 3438
> >>>>>>>>>>>> >> >>>>> > > > cliu at pppl.gov
> >>>>>>>>>>>> >> >>>>> > > > Princeton
> >>>>>>>>>>>> Plasma Physics
> >>>>>>>>>>>> Laboratory
> >>>>>>>>>>>> >> >>>>> > > > 100
> >>>>>>>>>>>> Stellarator Rd,
> >>>>>>>>>>>> Princeton NJ
> >>>>>>>>>>>> >> 08540, USA
> >>>>>>>>>>>> >> >>>>> > > Chang Liu
> >>>>>>>>>>>> >> >>>>> > > Staff Research
> Physicist
> >>>>>>>>>>>> >> >>>>> > > +1 609 243 3438
> >>>>>>>>>>>> >> >>>>> > > cliu at pppl.gov
> >>>>>>>>>>>> >> >>>>> > > Princeton Plasma
> >>>>>>>>>>>> Physics Laboratory
> >>>>>>>>>>>> >> >>>>> > > 100 Stellarator Rd,
> >>>>>>>>>>>> Princeton NJ
> >>>>>>>>>>>> 08540, USA
> >>>>>>>>>>>> >> >>>>> > Chang Liu
> >>>>>>>>>>>> >> >>>>> > Staff Research Physicist
> >>>>>>>>>>>> >> >>>>> > +1 609 243 3438
> >>>>>>>>>>>> >> >>>>> > cliu at pppl.gov
> >>>>>>>>>>>> >> >>>>> > Princeton Plasma Physics
> >>>>>>>>>>>> Laboratory
> >>>>>>>>>>>> >> >>>>> > 100 Stellarator Rd,
> >>>>>>>>>>>> Princeton NJ 08540, USA
> >>>>>>>>>>>> >> >>>>> -- Chang Liu
> >>>>>>>>>>>> >> >>>>> +1 609 243 3438
> >>>>>>>>>>>> >> >>>>> Princeton Plasma Physics Laboratory
> >>>>>>>>>>>> >> >>>>> 100 Stellarator Rd, Princeton NJ
> >>>>>>>>>>>> 08540, USA
> >>>>>>>>>>>> >> >>>> Chang Liu
> >>>>>>>>>>>> >> >>>> +1 609 243 3438
> >>>>>>>>>>>> >> >>>> 100 Stellarator Rd, Princeton NJ 08540, USA
> >>>>>>>>>>>> >> >> Chang Liu
> >>>>>>>>>>>> >> >> +1 609 243 3438
> >>>>>>>>>>>> >> -- Chang Liu
> >>>>>>>>>>>> >> +1 609 243 3438
> >>>>>>>>>>>> > Chang Liu
> >>>>>>>>>>>> > +1 609 243 3438
> >>>>>>>>>>> Chang Liu
> >>>>>>>>>>> +1 609 243 3438
> >>>>>>>>> Chang Liu
> >>>>>>>>> +1 609 243 3438
> >>>>>>> Chang Liu
> >>>>>>> +1 609 243 3438
> >>>>> Chang Liu
> >>>>> +1 609 243 3438
> >> Chang Liu
> >> +1 609 243 3438
> Chang Liu
> +1 609 243 3438
> cliu at pppl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211016/f130a982/attachment-0001.html>
