[petsc-users] Periodic boundary conditions in DMPlex
    Pierre Seize
    pierre.seize at onera.fr
    Fri Oct 15 06:31:06 CDT 2021
It makes sense, thank you. In fact, both ways seems better than my way.
The first one looks the most straightforward. Unfortunately I do not
know how to implement either of them. Could you please direct me to the
corresponding PETSc functions ?
Pierre
On 15/10/21 13:25, Matthew Knepley wrote:
> On Fri, Oct 15, 2021 at 7:08 AM Pierre Seize <pierre.seize at onera.fr
> <mailto:pierre.seize at onera.fr>> wrote:
>     Hi,
>     I'm writing a code using PETSc to solve NS equations with FV on an
>     unstructured mesh. Therefore I use DMPlex.
>     Regarding periodicity, I manage to implement it this way:
>        - for each couple of boundaries that is linked with periodicity, I
>     create a buffer vector with an ISLocalToGlobalMapping
>        - then, when I need to fill the ghost cells corresponding to the
>     periodicity, the i "true" cell of the local vector fills the buffer
>     vector on location i with VecSetValuesBlockedLocal, then
>     VecAssemblyBegin/VecAssemblyEnd ensure each value is send to the
>     correct
>     location thanks to the mapping, then the i "ghost" cell of the local
>     vector reads the vector on location i to get it's value.
>     It works, but it seems to me there is a better way, with maybe
>     PetscSF,
>     VecScatter, or something I don't know yet. Does anyone have any
>     advice ?
> There are at least two other ways to handle this. First, the method
> that is advocated in
> Plex is to actually make a periodic geometry, meaning connect the
> cells that are meant
> to be connected. Then, if you partition with overlap = 1,
> PetscGlobalToLocal() will fill in
> these cell values automatically.
> Second, you could use a non-periodic geometry, but alter the
> LocalToGlobal map such
> that the cells gets filled in anyway. Many codes use this scheme and
> it is straightforward
> with Plex just by augmenting the map it makes automatically.
> Does this make sense?
>   Thanks,
>      Matt
>     Pierre Seize
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/%7Eknepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211015/104ba230/attachment.html>
