[petsc-users] Issue on Block Jacobi Preconditioner Reuse
王一甲
wangyijia at lsec.cc.ac.cn
Thu Oct 14 22:47:44 CDT 2021
Hi!Everyone:
Glad to join the mailing list.Recently I 've been working on a program using block jacobi preconditioner for a sequence solve of two linear system A_1x_1=b_1,A_2x_2=b_2.
Since A1 and A2 have same nonzero pattern and their element values are quite close, we hope to reuse the preconditoners constructed when solving A_1x_1=b_1 ,
however after calling KSPSetReusePreconditioner, though the iteration number of second ksp solve is very small but the time used did not decrease much, these are my code:
ierr = KSPSetUp(ksp);CHKERRQ(ierr);
ierr = PCBJacobiGetSubKSP(pc, &num_local, &idx_first_local, &subksp);CHKERRQ(ierr);
for (i=0; i<num_local; i++)
ierr = KSPGetPC(subksp[i], &subpc);CHKERRQ(ierr);
if (i==0)
ierr = KSPSetType(subksp[i],"gmres");CHKERRQ(ierr);
ierr = PCSetType(subpc, PCLU);CHKERRQ(ierr);
ierr = PCFactorSetMatSolverType(subpc, "mkl_pardiso");CHKERRQ(ierr);
ierr = KSPSetOptionsPrefix(subksp[i], "Blk0_");CHKERRQ(ierr);
ierr = KSPSetReusePreconditioner(subksp[i],PETSC_TRUE);CHKERRQ(ierr);
ierr = KSPSetFromOptions(subksp[i]);CHKERRQ(ierr);
if (i==1)
ierr = PCSetType(subpc, PCHYPRE);CHKERRQ(ierr);
ierr = PCHYPRESetType(pc, "boomeramg");CHKERRQ(ierr);
ierr = KSPSetOptionsPrefix(subksp[i], "Blk1_");CHKERRQ(ierr);
}//nlocal
}//isbjacobi
//Solve the Linear System
ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
t0 = MPI_Wtime();
ierr = KSPSolve(ksp, b1, x1);CHKERRQ(ierr);
t0 = MPI_Wtime()-t0;
ierr = PetscPrintf(PETSC_COMM_SELF,"First KSP Solve time: %g s\n",t0);CHKERRQ(ierr);
//Preconditioner Reuse
ierr = KSPSetReusePreconditioner(ksp, PETSC_TRUE);CHKERRQ(ierr);
ierr = KSPSetOperators(ksp,A2,A1);CHKERRQ(ierr);
t0 = MPI_Wtime();
ierr = KSPSolve(ksp,b2,x2);CHKERRQ(ierr);
ierr = PetscPrintf(PETSC_COMM_SELF,"Second KSP Solve time: %g s\n",t0);CHKERRQ(ierr);
The total block number is 2, and the first block is solved using direct method and the second block is solved using hypre's boomeramg, so I hope to reuse the factor of the first block and the set up phase of boomeramg as preconditioner of the next solve, is there anything wrong with the reuse code?
Best Wishes
WANG Yijia
2021/10/15
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211015/312357ff/attachment.html>
