[petsc-users] [External] Re: request to add an option similar to use_omp_threads for mumps to cusparse solver
Mark Adams
mfadams at lbl.gov
Wed Oct 13 20:25:17 CDT 2021
On Wed, Oct 13, 2021 at 9:04 PM Chang Liu <cliu at pppl.gov> wrote:
> Hi Mark,
> Thank you for sharing this. I totally agree that factorization and
> triangular solve can be slow on GPUs.
Note, factorizations have much more potential on a GPU because there is
much more work and arithmetic intensity (BLAS3 vs BLAS2 (or 1)) than the
forward and backward solve (the solve) phases.
The work complexity of a PDE sparse factorization is about O(N^2) and
O(N^3/2) for the solve. That is a big difference.
> However, I also find that other
> operations such as matrix matrix multiplication can be very fast on GPU,
> so some iterative solver may perform well on GPUs, depending on the
> density and structure of matrix.
> In my tests, I found that sometimes GPU can gives 2-3 speedup for GMRES.
> Also, I think the SuperLU group has made significant progress on porting
> their code to GPU recently, and impressive speedup (not published yet).
> Chang
> On 10/13/21 8:29 PM, Mark Adams wrote:
> > On Wed, Oct 13, 2021 at 1:53 PM Barry Smith <bsmith at petsc.dev
> > <mailto:bsmith at petsc.dev>> wrote:
> > Chang,
> > You are correct there is no MPI + GPU direct solvers that
> > currently do the triangular solves with MPI + GPU parallelism that I
> > am aware of.
> > So SuperLU and MUMPS do MPI solves on the CPU. That is reasonable. I
> > have not been able to get decent performance with GPU solves. Complex
> > code and low AI is not a good fit for GPUs. No work and all latency.
> > Chang, you would find that GPU solves suck and, anyway, machines these
> > days are configured with significant (high quality) CPU resources. I
> > think you would find that you can't get GPU solves to beat CPU solves,
> > except if you have enormous problems to solve, perhaps.
> > You are limited that individual triangular solves be done on a
> > single GPU. I can only suggest making each subdomain as big as
> > possible to utilize each GPU as much as possible for the direct
> > triangular solves.
> > Barry
> > > On Oct 13, 2021, at 12:16 PM, Chang Liu via petsc-users
> > <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> > > Hi Mark,
> > > '-mat_type aijcusparse' works with mpiaijcusparse with other
> > solvers, but with -pc_factor_mat_solver_type cusparse, it will give
> > an error.
> > > Yes what I want is to have mumps or superlu to do the
> > factorization, and then do the rest, including GMRES solver, on gpu.
> > Is that possible?
> > > I have tried to use aijcusparse with superlu_dist, it runs but
> > the iterative solver is still running on CPUs. I have contacted the
> > superlu group and they confirmed that is the case right now. But if
> > I set -pc_factor_mat_solver_type cusparse, it seems that the
> > iterative solver is running on GPU.
> > > Chang
> > > On 10/13/21 12:03 PM, Mark Adams wrote:
> > >> On Wed, Oct 13, 2021 at 11:10 AM Chang Liu <cliu at pppl.gov
> > <mailto:cliu at pppl.gov> <mailto:cliu at pppl.gov
> > <mailto:cliu at pppl.gov>>> wrote:
> > >> Thank you Junchao for explaining this. I guess in my case the
> > code is
> > >> just calling a seq solver like superlu to do factorization on
> > GPUs.
> > >> My idea is that I want to have a traditional MPI code to
> > utilize GPUs
> > >> with cusparse. Right now cusparse does not support mpiaij
> > matrix, Sure it does: '-mat_type aijcusparse' will give you an
> > mpiaijcusparse matrix with > 1 processes.
> > >> (-mat_type mpiaijcusparse might also work with >1 proc).
> > >> However, I see in grepping the repo that all the mumps and
> > superlu tests use aij or sell matrix type.
> > >> MUMPS and SuperLU provide their own solves, I assume .... but
> > you might want to do other matrix operations on the GPU. Is that the
> > issue?
> > >> Did you try -mat_type aijcusparse with MUMPS and/or SuperLU have
> > a problem? (no test with it so it probably does not work)
> > >> Thanks,
> > >> Mark
> > >> so I
> > >> want the code to have a mpiaij matrix when adding all the
> > matrix terms,
> > >> and then transform the matrix to seqaij when doing the
> > factorization
> > >> and
> > >> solve. This involves sending the data to the master process,
> > and I
> > >> think
> > >> the petsc mumps solver have something similar already.
> > >> Chang
> > >> On 10/13/21 10:18 AM, Junchao Zhang wrote:
> > >> > On Tue, Oct 12, 2021 at 1:07 PM Mark Adams
> > <mfadams at lbl.gov <mailto:mfadams at lbl.gov>
> > >> <mailto:mfadams at lbl.gov <mailto:mfadams at lbl.gov>>
> > <mailto:mfadams at lbl.gov <mailto:mfadams at lbl.gov>>>> wrote:
> > >> > On Tue, Oct 12, 2021 at 1:45 PM Chang Liu
> > <cliu at pppl.gov <mailto:cliu at pppl.gov>
> > >> <mailto:cliu at pppl.gov <mailto:cliu at pppl.gov>>
> > <mailto:cliu at pppl.gov <mailto:cliu at pppl.gov>>>> wrote:
> > >> > Hi Mark,
> > >> > The option I use is like
> > >> > -pc_type bjacobi -pc_bjacobi_blocks 16 -ksp_type
> > fgmres
> > >> -mat_type
> > >> > aijcusparse *-sub_pc_factor_mat_solver_type
> cusparse
> > >> *-sub_ksp_type
> > >> > preonly *-sub_pc_type lu* -ksp_max_it 2000
> > -ksp_rtol 1.e-300
> > >> > -ksp_atol 1.e-300
> > >> > Note, If you use -log_view the last column (rows are
> the
> > >> method like
> > >> > MatFactorNumeric) has the percent of work in the GPU.
> > >> > Junchao: *This* implies that we have a cuSparse LU
> > >> factorization. Is
> > >> > that correct? (I don't think we do)
> > >> > No, we don't have cuSparse LU factorization. If you check
> > >> > MatLUFactorSymbolic_SeqAIJCUSPARSE(),you will find it calls
> > >> > MatLUFactorSymbolic_SeqAIJ() instead.
> > >> > So I don't understand Chang's idea. Do you want to make
> bigger
> > >> blocks?
> > >> > I think this one do both factorization and solve
> > on gpu.
> > >> > You can check the runex72_aijcusparse.sh file in
> petsc
> > >> install
> > >> > directory, and try it your self (this is only lu
> > >> factorization
> > >> > without
> > >> > iterative solve).
> > >> > Chang
> > >> > On 10/12/21 1:17 PM, Mark Adams wrote:
> > >> > > On Tue, Oct 12, 2021 at 11:19 AM Chang Liu
> > >> <cliu at pppl.gov <mailto:cliu at pppl.gov> <mailto:cliu at pppl.gov
> > <mailto:cliu at pppl.gov <mailto:cliu at pppl.gov>>>>> wrote:
> > >> > > Hi Junchao,
> > >> > > No I only needs it to be transferred within
> a
> > >> node. I use
> > >> > block-Jacobi
> > >> > > method and GMRES to solve the sparse
> > matrix, so each
> > >> > direct solver will
> > >> > > take care of a sub-block of the whole
> > matrix. In this
> > >> > way, I can use
> > >> > > one
> > >> > > GPU to solve one sub-block, which is stored
> > within
> > >> one node.
> > >> > > It was stated in the documentation that
> > cusparse
> > >> solver
> > >> > is slow.
> > >> > > However, in my test using ex72.c, the
> cusparse
> > >> solver is
> > >> > faster than
> > >> > > mumps or superlu_dist on CPUs.
> > >> > > Are we talking about the factorization, the
> > solve, or
> > >> both?
> > >> > > We do not have an interface to cuSparse's LU
> > >> factorization (I
> > >> > just
> > >> > > learned that it exists a few weeks ago).
> > >> > > Perhaps your fast "cusparse solver" is
> '-pc_type lu
> > >> -mat_type
> > >> > > aijcusparse' ? This would be the CPU
> factorization,
> > >> which is the
> > >> > > dominant cost.
> > >> > > Chang
> > >> > > On 10/12/21 10:24 AM, Junchao Zhang wrote:
> > >> > > > Hi, Chang,
> > >> > > > For the mumps solver, we usually
> > transfers
> > >> matrix
> > >> > and vector
> > >> > > data
> > >> > > > within a compute node. For the idea you
> > >> propose, it
> > >> > looks like
> > >> > > we need
> > >> > > > to gather data within MPI_COMM_WORLD,
> right?
> > >> > > > Mark, I remember you said cusparse
> > solve is
> > >> slow
> > >> > and you would
> > >> > > > rather do it on CPU. Is it right?
> > >> > > > --Junchao Zhang
> > >> > > > On Mon, Oct 11, 2021 at 10:25 PM Chang
> > Liu via
> > >> petsc-users
> > >> <mailto:petsc-users at mcs.anl.gov <mailto:
> > <mailto:petsc-users at mcs.anl.gov>>> <mailto:petsc-users at mcs.anl.gov
> > <mailto:petsc-users at mcs.anl.gov>>>>
> > <mailto:petsc-users at mcs.anl.gov>>>>>>
> > >> > > wrote:
> > >> > > > Hi,
> > >> > > > Currently, it is possible to use
> mumps
> > >> solver in
> > >> > PETSC with
> > >> > > > -mat_mumps_use_omp_threads option,
> > so that
> > >> > multiple MPI
> > >> > > processes will
> > >> > > > transfer the matrix and rhs data to
> > the master
> > >> > rank, and then
> > >> > > master
> > >> > > > rank will call mumps with OpenMP to
> > solve
> > >> the matrix.
> > >> > > > I wonder if someone can develop
> similar
> > >> option for
> > >> > cusparse
> > >> > > solver.
> > >> > > > Right now, this solver does not work
> > with
> > >> > mpiaijcusparse. I
> > >> > > think a
> > >> > > > possible workaround is to transfer
> > all the
> > >> matrix
> > >> > data to one MPI
> > >> > > > process, and then upload the data to
> > GPU to
> > >> solve.
> > >> > In this
> > >> > > way, one can
> > >> > > > use cusparse solver for a MPI
> program.
> > >> > > > Chang
> > >> > > > Chang Liu
> > >> > > > Staff Research Physicist
> > >> > > > +1 609 243 3438
> > <mailto:cliu at pppl.gov> <mailto:cliu at pppl.gov <mailto:cliu at pppl.gov>>
> > >> > > > Princeton Plasma Physics Laboratory
> > >> > > > 100 Stellarator Rd, Princeton NJ
> > 08540, USA
> > >> > > Chang Liu
> > >> > > +1 609 243 3438
> > <mailto:cliu at pppl.gov <mailto:cliu at pppl.gov>>> <mailto:cliu at pppl.gov
> > >> > > 100 Stellarator Rd, Princeton NJ 08540, USA
> > >> > Chang Liu
> > >> > +1 609 243 3438
> > <mailto:cliu at pppl.gov>> <mailto:cliu at pppl.gov <mailto:cliu at pppl.gov>
> > >> -- Chang Liu
> > >> +1 609 243 3438
> > > Chang Liu
> > > +1 609 243 3438
> Chang Liu
> +1 609 243 3438
> cliu at pppl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211013/40a3cbd3/attachment-0001.html>
