[petsc-users] Error "Attempting to use an MPI routine before initializing MPICH" after compiling PETSc with Intel MPI and GCC
Roland Richter roland.richter at ntnu.no
Wed Oct 13 05:43:48 CDT 2021
Shouldn't I see a mixture of MPI-libraries when calling ldd if I mix
versions of MPI?
I also removed all calls to armadillo, and accordingly all references to
it in the compilation, but the behavior is still unchanged.
Roland
Am 13.10.21 um 12:36 schrieb Matthew Knepley:
> On Wed, Oct 13, 2021 at 6:32 AM Roland Richter
> <roland.richter at ntnu.no> wrote:
>     Yes, the first part (which works) consists out of a compilation
>     line and a linking line, while the second command is a combination
>     of compile- and linking line.
> The link line in the first does not tell us anything because MPI is
> not even present. It is being pulled in I presume from libarmadillo,
> which we cannot see. It still
> seems most likely, as Stefano said, that you are mixing versions of MPI.
>   Thanks,
>      Matt
>     Am 13.10.21 um 12:26 schrieb Matthew Knepley:
>>     On Wed, Oct 13, 2021 at 5:53 AM Roland Richter
>>         Hei,
>>         I noticed a difference in when the program is running, and
>>         when not. The code works fine if I compile it via a
>>         CMake-file and load PETSc there. If I use the compilation
>>         line which is included in the Makefiles, then the code will
>>         fail with the mentioned error. The cmake-generated
>>         compilation line (including armadillo, because my test sample
>>         contained armadillo-code) is
>>     One of these is a compile command and the other is a link command.
>>        Matt
>>         //opt/intel/oneapi/mpi/2021.4.0/bin/mpicxx -D__INSDIR__=""
>>         -I/include -I/opt/petsc/include -I/opt/armadillo/include
>>         -std=c++0x -g -MD -MT CMakeFiles/main.dir/source/main.cpp.o
>>         -MF CMakeFiles/main.dir/source/main.cpp.o.d -o
>>         CMakeFiles/main.dir/source/main.cpp.o -c source/main.cpp//
>>         ///opt/intel/oneapi/mpi/2021.4.0/bin/mpicxx -rdynamic
>>         CMakeFiles/main.dir/source/main.cpp.o -o main_short
>>         -Wl,-rpath,/opt/petsc/lib:/opt/armadillo/lib64
>>         /opt/petsc/lib/libpetsc.so /opt/armadillo/lib64/libarmadillo.so /
>>         Meanwhile, the original compilation line from PETSc is
>>         /mpicxx -mavx2 -march=native -O3 -fPIC -fopenmp
>>         -I/opt/intel/oneapi/mkl/latest/include -I/opt/fftw3/include
>>         -I/opt/hdf5/include -I/opt/boost/include source/main.cpp
>>         -Wl,-rpath,/opt/petsc/lib -L/opt/petsc/lib
>>         -L/opt/intel/oneapi/mkl/latest/lib/intel64
>>         -Wl,-rpath,/opt/fftw3/lib64 -L/opt/fftw3/lib64
>>         -Wl,-rpath,/opt/armadillo/lib64 -L/opt/armadillo/lib64
>>         -Wl,-rpath,/opt/intel/oneapi/mkl/latest/lib/intel64
>>         -Wl,-rpath,/opt/hdf5/lib -L/opt/hdf5/lib
>>         -Wl,-rpath,/opt/intel/oneapi/mpi/2021.4.0/lib/release
>>         -L/opt/intel/oneapi/mpi/2021.4.0/lib/release
>>         -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/11
>>         -L/usr/lib64/gcc/x86_64-suse-linux/11
>>         -Wl,-rpath,/opt/intel/oneapi/vpl/2021.6.0/lib
>>         -L/opt/intel/oneapi/vpl/2021.6.0/lib
>>         -Wl,-rpath,/opt/intel/oneapi/tbb/2021.4.0/lib/intel64/gcc4.8
>>         -L/opt/intel/oneapi/tbb/2021.4.0/lib/intel64/gcc4.8
>>         -Wl,-rpath,/opt/intel/oneapi/mpi/2021.4.0/libfabric/lib
>>         -L/opt/intel/oneapi/mpi/2021.4.0/libfabric/lib
>>         -Wl,-rpath,/opt/intel/oneapi/mkl/2021.4.0/lib/intel64
>>         -L/opt/intel/oneapi/mkl/2021.4.0/lib/intel64
>>         -Wl,-rpath,/opt/intel/oneapi/ipp/2021.4.0/lib/intel64
>>         -L/opt/intel/oneapi/ipp/2021.4.0/lib/intel64
>>         -Wl,-rpath,/opt/intel/oneapi/ippcp/2021.4.0/lib/intel64
>>         -L/opt/intel/oneapi/ippcp/2021.4.0/lib/intel64
>>         -Wl,-rpath,/opt/intel/oneapi/dnnl/2021.4.0/cpu_dpcpp_gpu_dpcpp/lib
>>         -L/opt/intel/oneapi/dnnl/2021.4.0/cpu_dpcpp_gpu_dpcpp/lib
>>         -Wl,-rpath,/opt/intel/oneapi/dal/2021.4.0/lib/intel64
>>         -L/opt/intel/oneapi/dal/2021.4.0/lib/intel64
>>         -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/linux/compiler/lib/intel64_lin
>>         -L/opt/intel/oneapi/compiler/2021.4.0/linux/compiler/lib/intel64_lin
>>         -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/linux/lib
>>         -L/opt/intel/oneapi/compiler/2021.4.0/linux/lib
>>         -Wl,-rpath,/opt/intel/oneapi/clck/2021.4.0/lib/intel64
>>         -L/opt/intel/oneapi/clck/2021.4.0/lib/intel64
>>         -Wl,-rpath,/opt/intel/oneapi/ccl/2021.4.0/lib/cpu_gpu_dpcpp
>>         -L/opt/intel/oneapi/ccl/2021.4.0/lib/cpu_gpu_dpcpp
>>         -Wl,-rpath,/usr/x86_64-suse-linux/lib
>>         -L/usr/x86_64-suse-linux/lib -larmadillo -lpetsc -lHYPRE
>>         -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord
>>         -lmkl_scalapack_lp64 -lmkl_blacs_intelmpi_lp64 -lspqr
>>         -lumfpack -lklu -lcholmod -lbtf -lccolamd -lcolamd -lcamd
>>         -lamd -lsuitesparseconfig -lsuperlu -lsuperlu_dist -lEl
>>         -lElSuiteSparse -lpmrrr -lfftw3_mpi -lfftw3 -lp4est -lsc
>>         -lmkl_intel_lp64 -lmkl_core -lmkl_intel_thread -liomp5 -ldl
>>         -lpthread -lptesmumps -lptscotchparmetis -lptscotch
>>         -lptscotcherr -lesmumps -lscotch -lscotcherr -lhdf5_hl -lhdf5
>>         -lparmetis -lmetis -lm -lz -lmuparser -lX11 -lstdc++ -ldl
>>         -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -lgfortran -lm
>>         -lgcc_s -lquadmath -lrt -lquadmath -lstdc++ -ldl -o main_long/
>>         Both executables have the same libraries linked to them, but
>>         in a different order when comparing them with ldd.
>>         Does that explain the observed behavior?
>>         Thanks,
>>         regards,
>>         Roland
>>         Am 11.10.21 um 15:13 schrieb Roland Richter:
>>>         Hei,
>>>         the following code works fine:
>>>         #include <iostream>
>>>         #include <petsc.h>
>>>         static char help[] = "Solves 2D Poisson equation using
>>>         multigrid.\n\n";
>>>         int main(int argc,char **argv) {
>>>             PetscInitialize(&argc,&argv,(char*)0,help);
>>>             std::cout << "Hello World\n";
>>>             PetscFinalize();
>>>             return 0;
>>>         Regards,
>>>         Roland
>>>         Am 11.10.21 um 14:34 schrieb Stefano Zampini:
>>>>         Can you try with a simple call that only calls
>>>>         PetscInitialize/Finalize?
>>>>>         On Oct 11, 2021, at 3:30 PM, Roland Richter
>>>>>         At least according to configure.log mpiexec was defined as
>>>>>         Checking for program
>>>>>         /opt/intel/oneapi/mpi/2021.4.0//bin/mpiexec...found
>>>>>                           Defined make macro "MPIEXECEXECUTABLE"
>>>>>         to "/opt/intel/oneapi/mpi/2021.4.0/bin/mpiexec"
>>>>>         When running ex19 with this mpiexec it fails with the
>>>>>         usual error, even though all configuration steps worked
>>>>>         fine. I attached the configuration log.
>>>>>         Regards,
>>>>>         Roland
>>>>>         Am 11.10.21 um 14:24 schrieb Stefano Zampini:
>>>>>>         You are most probably using a different mpiexec then the
>>>>>>         one used to compile petsc.
>>>>>>>         On Oct 11, 2021, at 3:23 PM, Roland Richter
>>>>>>>         I tried either /./ex19/ (SNES-example), /mpirun ./ex19/
>>>>>>>         or /mpirun -n 1 ./ex19/, all with the same result.
>>>>>>>         Regards,
>>>>>>>         Roland
>>>>>>>         Am 11.10.21 um 14:22 schrieb Matthew Knepley:
>>>>>>>>         On Mon, Oct 11, 2021 at 8:07 AM Roland Richter
>>>>>>>>             Hei,
>>>>>>>>             at least in gdb it fails with
>>>>>>>>             initializing MPICH
>>>>>>>>             [Inferior 1 (process 7854) exited with code 01]
>>>>>>>>             (gdb) backtrace
>>>>>>>>             No stack.
>>>>>>>>         What were you running? If it never makes it into PETSc
>>>>>>>>         code, I am not sure what we are
>>>>>>>>         doing to cause this.
>>>>>>>>           Thanks,
>>>>>>>>              Matt
>>>>>>>>             Regards,
>>>>>>>>             Roland
>>>>>>>>             Am 11.10.21 um 13:57 schrieb Matthew Knepley:
>>>>>>>>>             On Mon, Oct 11, 2021 at 5:24 AM Roland Richter
>>>>>>>>>                 Hei,
>>>>>>>>>                 I compiled PETSc with Intel MPI (MPICH) and
>>>>>>>>>                 GCC as compiler (i.e. using
>>>>>>>>>                 Intel OneAPI together with the supplied
>>>>>>>>>                 mpicxx-compiler). Compilation
>>>>>>>>>                 and installation worked fine, but running the
>>>>>>>>>                 tests resulted in the
>>>>>>>>>                 error "Attempting to use an MPI routine before
>>>>>>>>>                 initializing MPICH". A
>>>>>>>>>                 simple test program (attached) worked fine
>>>>>>>>>                 with the same combination.
>>>>>>>>>                 What could be the reason for that?
>>>>>>>>>             Hi Roland,
>>>>>>>>>             Can you get a stack trace for this error using the
>>>>>>>>>             debugger?
>>>>>>>>>               Thanks,
>>>>>>>>>                  Matt
>>>>>>>>>                 Thanks!
>>>>>>>>>                 Regards,
>>>>>>>>>                 Roland Richter
>>>>>>>>>             What most experimenters take for granted before
>>>>>>>>>             they begin their experiments is infinitely more
>>>>>>>>>             interesting than any results to which their
>>>>>>>>>             experiments lead.
>>>>>>>>>             -- Norbert Wiener
>>>>>>>>>             https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>             <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>         What most experimenters take for granted before they
>>>>>>>>         begin their experiments is infinitely more interesting
>>>>>>>>         than any results to which their experiments lead.
>>>>>>>>         -- Norbert Wiener
>>>>>         <configure.log>
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211013/d7ff54a1/attachment-0001.html>
