[petsc-users] Error "Attempting to use an MPI routine before initializing MPICH" after compiling PETSc with Intel MPI and GCC
Roland Richter roland.richter at ntnu.no
Wed Oct 13 05:32:44 CDT 2021
Yes, the first part (which works) consists out of a compilation line and
a linking line, while the second command is a combination of compile-
and linking line.
Am 13.10.21 um 12:26 schrieb Matthew Knepley:
> On Wed, Oct 13, 2021 at 5:53 AM Roland Richter
> <roland.richter at ntnu.no> wrote:
>     Hei,
>     I noticed a difference in when the program is running, and when
>     not. The code works fine if I compile it via a CMake-file and load
>     PETSc there. If I use the compilation line which is included in
>     the Makefiles, then the code will fail with the mentioned error.
>     The cmake-generated compilation line (including armadillo, because
>     my test sample contained armadillo-code) is
> One of these is a compile command and the other is a link command.
>    Matt
>     //opt/intel/oneapi/mpi/2021.4.0/bin/mpicxx -D__INSDIR__=""
>     -I/include -I/opt/petsc/include -I/opt/armadillo/include
>     -std=c++0x -g -MD -MT CMakeFiles/main.dir/source/main.cpp.o -MF
>     CMakeFiles/main.dir/source/main.cpp.o.d -o
>     CMakeFiles/main.dir/source/main.cpp.o -c source/main.cpp//
>     ///opt/intel/oneapi/mpi/2021.4.0/bin/mpicxx -rdynamic
>     CMakeFiles/main.dir/source/main.cpp.o -o main_short
>     -Wl,-rpath,/opt/petsc/lib:/opt/armadillo/lib64
>     /opt/petsc/lib/libpetsc.so /opt/armadillo/lib64/libarmadillo.so /
>     Meanwhile, the original compilation line from PETSc is
>     /mpicxx -mavx2 -march=native -O3 -fPIC -fopenmp
>     -I/opt/intel/oneapi/mkl/latest/include -I/opt/fftw3/include
>     -I/opt/hdf5/include -I/opt/boost/include source/main.cpp
>     -Wl,-rpath,/opt/petsc/lib -L/opt/petsc/lib
>     -L/opt/intel/oneapi/mkl/latest/lib/intel64
>     -Wl,-rpath,/opt/fftw3/lib64 -L/opt/fftw3/lib64
>     -Wl,-rpath,/opt/armadillo/lib64 -L/opt/armadillo/lib64
>     -Wl,-rpath,/opt/intel/oneapi/mkl/latest/lib/intel64
>     -Wl,-rpath,/opt/hdf5/lib -L/opt/hdf5/lib
>     -Wl,-rpath,/opt/intel/oneapi/mpi/2021.4.0/lib/release
>     -L/opt/intel/oneapi/mpi/2021.4.0/lib/release
>     -Wl,-rpath,/usr/lib64/gcc/x86_64-suse-linux/11
>     -L/usr/lib64/gcc/x86_64-suse-linux/11
>     -Wl,-rpath,/opt/intel/oneapi/vpl/2021.6.0/lib
>     -L/opt/intel/oneapi/vpl/2021.6.0/lib
>     -Wl,-rpath,/opt/intel/oneapi/tbb/2021.4.0/lib/intel64/gcc4.8
>     -L/opt/intel/oneapi/tbb/2021.4.0/lib/intel64/gcc4.8
>     -Wl,-rpath,/opt/intel/oneapi/mpi/2021.4.0/libfabric/lib
>     -L/opt/intel/oneapi/mpi/2021.4.0/libfabric/lib
>     -Wl,-rpath,/opt/intel/oneapi/mkl/2021.4.0/lib/intel64
>     -L/opt/intel/oneapi/mkl/2021.4.0/lib/intel64
>     -Wl,-rpath,/opt/intel/oneapi/ipp/2021.4.0/lib/intel64
>     -L/opt/intel/oneapi/ipp/2021.4.0/lib/intel64
>     -Wl,-rpath,/opt/intel/oneapi/ippcp/2021.4.0/lib/intel64
>     -L/opt/intel/oneapi/ippcp/2021.4.0/lib/intel64
>     -Wl,-rpath,/opt/intel/oneapi/dnnl/2021.4.0/cpu_dpcpp_gpu_dpcpp/lib
>     -L/opt/intel/oneapi/dnnl/2021.4.0/cpu_dpcpp_gpu_dpcpp/lib
>     -Wl,-rpath,/opt/intel/oneapi/dal/2021.4.0/lib/intel64
>     -L/opt/intel/oneapi/dal/2021.4.0/lib/intel64
>     -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/linux/compiler/lib/intel64_lin
>     -L/opt/intel/oneapi/compiler/2021.4.0/linux/compiler/lib/intel64_lin
>     -Wl,-rpath,/opt/intel/oneapi/compiler/2021.4.0/linux/lib
>     -L/opt/intel/oneapi/compiler/2021.4.0/linux/lib
>     -Wl,-rpath,/opt/intel/oneapi/clck/2021.4.0/lib/intel64
>     -L/opt/intel/oneapi/clck/2021.4.0/lib/intel64
>     -Wl,-rpath,/opt/intel/oneapi/ccl/2021.4.0/lib/cpu_gpu_dpcpp
>     -L/opt/intel/oneapi/ccl/2021.4.0/lib/cpu_gpu_dpcpp
>     -Wl,-rpath,/usr/x86_64-suse-linux/lib -L/usr/x86_64-suse-linux/lib
>     -larmadillo -lpetsc -lHYPRE -lcmumps -ldmumps -lsmumps -lzmumps
>     -lmumps_common -lpord -lmkl_scalapack_lp64
>     -lmkl_blacs_intelmpi_lp64 -lspqr -lumfpack -lklu -lcholmod -lbtf
>     -lccolamd -lcolamd -lcamd -lamd -lsuitesparseconfig -lsuperlu
>     -lsuperlu_dist -lEl -lElSuiteSparse -lpmrrr -lfftw3_mpi -lfftw3
>     -lp4est -lsc -lmkl_intel_lp64 -lmkl_core -lmkl_intel_thread
>     -liomp5 -ldl -lpthread -lptesmumps -lptscotchparmetis -lptscotch
>     -lptscotcherr -lesmumps -lscotch -lscotcherr -lhdf5_hl -lhdf5
>     -lparmetis -lmetis -lm -lz -lmuparser -lX11 -lstdc++ -ldl
>     -lmpifort -lmpi -lrt -lpthread -lgfortran -lm -lgfortran -lm
>     -lgcc_s -lquadmath -lrt -lquadmath -lstdc++ -ldl -o main_long/
>     Both executables have the same libraries linked to them, but in a
>     different order when comparing them with ldd.
>     Does that explain the observed behavior?
>     Thanks,
>     regards,
>     Roland
>     Am 11.10.21 um 15:13 schrieb Roland Richter:
>>     Hei,
>>     the following code works fine:
>>     #include <iostream>
>>     #include <petsc.h>
>>     static char help[] = "Solves 2D Poisson equation using
>>     multigrid.\n\n";
>>     int main(int argc,char **argv) {
>>         PetscInitialize(&argc,&argv,(char*)0,help);
>>         std::cout << "Hello World\n";
>>         PetscFinalize();
>>         return 0;
>>     Regards,
>>     Roland
>>     Am 11.10.21 um 14:34 schrieb Stefano Zampini:
>>>     Can you try with a simple call that only calls
>>>     PetscInitialize/Finalize?
>>>>     On Oct 11, 2021, at 3:30 PM, Roland Richter
>>>>     At least according to configure.log mpiexec was defined as
>>>>     Checking for program
>>>>     /opt/intel/oneapi/mpi/2021.4.0//bin/mpiexec...found
>>>>                       Defined make macro "MPIEXECEXECUTABLE" to
>>>>     "/opt/intel/oneapi/mpi/2021.4.0/bin/mpiexec"
>>>>     When running ex19 with this mpiexec it fails with the usual
>>>>     error, even though all configuration steps worked fine. I
>>>>     attached the configuration log.
>>>>     Regards,
>>>>     Roland
>>>>     Am 11.10.21 um 14:24 schrieb Stefano Zampini:
>>>>>     You are most probably using a different mpiexec then the one
>>>>>     used to compile petsc.
>>>>>>     On Oct 11, 2021, at 3:23 PM, Roland Richter
>>>>>>     I tried either /./ex19/ (SNES-example), /mpirun ./ex19/ or
>>>>>>     /mpirun -n 1 ./ex19/, all with the same result.
>>>>>>     Regards,
>>>>>>     Roland
>>>>>>     Am 11.10.21 um 14:22 schrieb Matthew Knepley:
>>>>>>>     On Mon, Oct 11, 2021 at 8:07 AM Roland Richter
>>>>>>>         Hei,
>>>>>>>         at least in gdb it fails with
>>>>>>>         [Inferior 1 (process 7854) exited with code 01]
>>>>>>>         (gdb) backtrace
>>>>>>>         No stack.
>>>>>>>     What were you running? If it never makes it into PETSc code,
>>>>>>>     I am not sure what we are
>>>>>>>     doing to cause this.
>>>>>>>       Thanks,
>>>>>>>          Matt
>>>>>>>         Regards,
>>>>>>>         Roland
>>>>>>>         Am 11.10.21 um 13:57 schrieb Matthew Knepley:
>>>>>>>>         On Mon, Oct 11, 2021 at 5:24 AM Roland Richter
>>>>>>>>             Hei,
>>>>>>>>             I compiled PETSc with Intel MPI (MPICH) and GCC as
>>>>>>>>             compiler (i.e. using
>>>>>>>>             Intel OneAPI together with the supplied
>>>>>>>>             mpicxx-compiler). Compilation
>>>>>>>>             and installation worked fine, but running the tests
>>>>>>>>             resulted in the
>>>>>>>>             error "Attempting to use an MPI routine before
>>>>>>>>             initializing MPICH". A
>>>>>>>>             simple test program (attached) worked fine with the
>>>>>>>>             same combination.
>>>>>>>>             What could be the reason for that?
>>>>>>>>         Hi Roland,
>>>>>>>>         Can you get a stack trace for this error using the
>>>>>>>>         debugger?
>>>>>>>>           Thanks,
>>>>>>>>              Matt
>>>>>>>>             Thanks!
>>>>>>>>             Regards,
>>>>>>>>             Roland Richter
>>>>>>>>         What most experimenters take for granted before they
>>>>>>>>         begin their experiments is infinitely more interesting
>>>>>>>>         than any results to which their experiments lead.
>>>>>>>>         -- Norbert Wiener
>>>>>>>>         https://www.cse.buffalo.edu/~knepley/
>>>>>>>>         <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>     What most experimenters take for granted before they begin
>>>>>>>     their experiments is infinitely more interesting than any
>>>>>>>     -- Norbert Wiener
>>>>     <configure.log>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211013/6485438a/attachment-0001.html>
