[petsc-users] On QN + Fieldsplit
Matthew Knepley
knepley at gmail.com
Tue Oct 12 09:23:18 CDT 2021
I looked over every place we use that error code. I do not think it is
coming from PETSc, but rather from petsc4py. However, something
is eating the error message, and I think Stefano indicated. My first step
would be to get the FEniCS folks to display the error message.
Another option is to just run it in Firedrake since I think we can see the
stack properly there.
Matt
On Tue, Oct 12, 2021 at 8:37 AM Nicolás Barnafi <nabw91 at gmail.com> wrote:
> Thank you Stefano for the help. I added the lines you indicated, but the
> error remains the same, here goes snes.view() + error
> > SNES Object: 1 MPI processes
> > type: qn
> > SNES has not been set up so information may be incomplete
> > type is BROYDEN, restart type is DEFAULT, scale type is JACOBIAN
> > Stored subspace size: 10
> > Using the single reduction variant.
> > maximum iterations=10000, maximum function evaluations=30000
> > tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
> > total number of function evaluations=0
> > norm schedule ALWAYS
> > SNESLineSearch Object: 1 MPI processes
> > type: basic
> > maxstep=1.000000e+08, minlambda=1.000000e-12
> > tolerances: relative=1.000000e-08, absolute=1.000000e-15,
> lambda=1.000000e-08
> > Traceback (most recent call last):
> > File "Twist.py", line 234, in <module>
> > snes.setUp()
> > File "PETSc/SNES.pyx", line 530, in petsc4py.PETSc.SNES.setUp
> > petsc4py.PETSc.Error: error code 83
> On Tue, Oct 12, 2021 at 2:07 PM Stefano Zampini <stefano.zampini at gmail.com>
> wrote:
>> Il giorno mar 12 ott 2021 alle ore 13:56 Nicolás Barnafi <
>> nabw91 at gmail.com> ha scritto:
>>> Hello PETSc users,
>>> first email sent!
>>> I am creating a SNES solver using fenics, my example runs smoothly with
>>> 'newtonls', but gives a strange missing function error (error 83):
>> Dolphin swallows any useful error information returned from PETSc. You
>> can try using the below code snippet at the beginning of your script
>> from petsc4py import PETSc
>> from dolfin import *
>> # Remove the dolfin error handler
>> PETSc.Sys.pushErrorHandler('python')
>>> these are the relevant lines of code where I setup the solver:
>>> > problem = SNESProblem(Res, sol, bcs)
>>> > b = PETScVector() # same as b = PETSc.Vec()
>>> > J_mat = PETScMatrix()
>>> > snes = PETSc.SNES().create(MPI.COMM_WORLD)
>>> > snes.setFunction(problem.F, b.vec())
>>> > snes.setJacobian(problem.J, J_mat.mat())
>>> > # Set up fieldsplit
>>> > ksp = snes.ksp
>>> > ksp.setOperators(J_mat.mat())
>>> > pc = ksp.pc
>>> > pc.setType('fieldsplit')
>>> > dofmap_s = V.sub(0).dofmap().dofs()
>>> > dofmap_p = V.sub(1).dofmap().dofs()
>>> > is_s = PETSc.IS().createGeneral(dofmap_s)
>>> > is_p = PETSc.IS().createGeneral(dofmap_p)
>>> > pc.setFieldSplitIS((None, is_s), (None, is_p))
>>> > pc.setFromOptions()
>>> > snes.setFromOptions()
>>> > snes.setUp()
>> If it can be useful, this are the outputs of snes.view(), ksp.view() and
>>> pc.view():
>>> > type: qn
>>> > SNESLineSearch Object: 4 MPI processes
>>> > type: basic
>>> lambda=1.000000e-08
>>> > KSP Object: 4 MPI processes
>>> > type: gmres
>>> > restart=1000, using Modified Gram-Schmidt Orthogonalization
>>> > happy breakdown tolerance 1e-30
>>> > maximum iterations=1000, initial guess is zero
>>> > tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
>>> > left preconditioning
>>> > using UNPRECONDITIONED norm type for convergence test
>>> > PC Object: 4 MPI processes
>>> > type: fieldsplit
>>> > PC has not been set up so information may be incomplete
>>> > FieldSplit with Schur preconditioner, factorization FULL
>>> I know that PC is not setup, but if I do it before setting up the SNES,
>>> the error persists. Thanks in advance for your help.
>>> Best,
>>> Nicolas
>>> Nicolás Alejandro Barnafi Wittwer
>> Stefano
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211012/76b0ae57/attachment.html>
