[petsc-users] Error "Attempting to use an MPI routine before initializing MPICH" after compiling PETSc with Intel MPI and GCC
Roland Richter
roland.richter at ntnu.no
Mon Oct 11 08:13:38 CDT 2021
Hei,
the following code works fine:
#include <iostream>
#include <petsc.h>
static char help[] = "Solves 2D Poisson equation using multigrid.\n\n";
int main(int argc,char **argv) {
PetscInitialize(&argc,&argv,(char*)0,help);
std::cout << "Hello World\n";
PetscFinalize();
return 0;
Roland
Am 11.10.21 um 14:34 schrieb Stefano Zampini:
> Can you try with a simple call that only calls PetscInitialize/Finalize?
>> On Oct 11, 2021, at 3:30 PM, Roland Richter <roland.richter at ntnu.no>
>> wrote:
>> At least according to configure.log mpiexec was defined as
>> Checking for program /opt/intel/oneapi/mpi/2021.4.0//bin/mpiexec...found
>> Defined make macro "MPIEXECEXECUTABLE" to
>> "/opt/intel/oneapi/mpi/2021.4.0/bin/mpiexec"
>> When running ex19 with this mpiexec it fails with the usual error,
>> even though all configuration steps worked fine. I attached the
>> configuration log.
>> Regards,
>> Roland
>> Am 11.10.21 um 14:24 schrieb Stefano Zampini:
>>> You are most probably using a different mpiexec then the one used to
>>> compile petsc.
>>>> On Oct 11, 2021, at 3:23 PM, Roland Richter
>>>> <roland.richter at ntnu.no> wrote:
>>>> I tried either /./ex19/ (SNES-example), /mpirun ./ex19/ or /mpirun
>>>> -n 1 ./ex19/, all with the same result.
>>>> Regards,
>>>> Roland
>>>> Am 11.10.21 um 14:22 schrieb Matthew Knepley:
>>>>> On Mon, Oct 11, 2021 at 8:07 AM Roland Richter
>>>>> Hei,
>>>>> at least in gdb it fails with
>>>>> [Inferior 1 (process 7854) exited with code 01]
>>>>> (gdb) backtrace
>>>>> No stack.
>>>>> What were you running? If it never makes it into PETSc code, I am
>>>>> not sure what we are
>>>>> doing to cause this.
>>>>> Thanks,
>>>>> Matt
>>>>> Regards,
>>>>> Roland
>>>>> Am 11.10.21 um 13:57 schrieb Matthew Knepley:
>>>>>> On Mon, Oct 11, 2021 at 5:24 AM Roland Richter
>>>>>> Hei,
>>>>>> I compiled PETSc with Intel MPI (MPICH) and GCC as
>>>>>> compiler (i.e. using
>>>>>> Intel OneAPI together with the supplied mpicxx-compiler).
>>>>>> Compilation
>>>>>> and installation worked fine, but running the tests
>>>>>> resulted in the
>>>>>> error "Attempting to use an MPI routine before
>>>>>> initializing MPICH". A
>>>>>> simple test program (attached) worked fine with the same
>>>>>> combination.
>>>>>> What could be the reason for that?
>>>>>> Hi Roland,
>>>>>> Can you get a stack trace for this error using the debugger?
>>>>>> Thanks,
>>>>>> Matt
>>>>>> Thanks!
>>>>>> Regards,
>>>>>> Roland Richter
>>>>>> What most experimenters take for granted before they begin
>>>>>> their experiments is infinitely more interesting than any
>>>>>> results to which their experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to
>>>>> -- Norbert Wiener
>> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211011/124c073e/attachment-0001.html>
