[petsc-users] hypre on gpus
Karthikeyan Chockalingam - STFC UKRI
karthikeyan.chockalingam at stfc.ac.uk
Fri Oct 8 12:35:55 CDT 2021
Yes, I used it for both cpu and gpu. Is that not okay?
For gpu: -dm_mat_type hypre -dm_vec_type mpicuda
For cpu: -dm_mat_type hypre -dm_vec_type mpi
Date: Friday, 8 October 2021 at 18:28
To: "Chockalingam, Karthikeyan (STFC,DL,HC)" <karthikeyan.chockalingam at stfc.ac.uk>
Cc: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] hypre on gpus
Did you use -dm_mat_type hypre on the GPU case ?
On Fri, Oct 8, 2021 at 12:19 PM Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
I tried a different exercise ran the same problem on two cpu cores and on two gpu:
On gpu
PCApply 6 1.0 6.0335e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+00 15 0 0 0 1 15 0 0 0 1 0 0 0 0.00e+00 5 9.65e+01 0
and on cpu
PCApply 6 1.0 5.6348e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 16 0 0 0 0 16 0 0 0 0 0
timings again are close but gpu version did a reduction 6.0e+00 but the cpu version did not 0.0e+00.
I am not sure if that is any indication if hypre ran on gpus?
Karthik.
From: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
Date: Friday, 8 October 2021 at 16:36
To: "Chockalingam, Karthikeyan (STFC,DL,HC)" <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>>
Cc: "petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>" <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
On Fri, Oct 8, 2021 at 10:29 AM Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
The PCApply timing on
gpu
PCApply 6 1.0 1.0235e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 39 0 0 0 0 39 0 0 0 0 0 0 0 0.00e+00 0 0.00e+00 0
and cpu
PCApply 6 1.0 1.0242e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 41 0 0 0 0 41 0 0 0 0 0
You don't have GPUs. probably.
Use -dm_mat_type hypre.
are close. It is hard for me tell if hypre on gpu is on or not.
Best,
Karthik.
From: "Chockalingam, Karthikeyan (STFC,DL,HC)" <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>>
Date: Friday, 8 October 2021 at 14:55
To: Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>>
Thanks Mark, I will try your recommendations.
Should I also change -dm_vec_type to hypre currently I have it as mpicuda?
Karthik.
Date: Friday, 8 October 2021 at 14:33
Hypre does not record its flops with PETSc's timers.
Configure with and without CUDA and see if the timings change in PCApply.
Hypre does not dynamically switch between CUDA and CPU solves at this time, but you want to use -dm_mat_type hypre.
On Fri, Oct 8, 2021 at 6:59 AM Karthikeyan Chockalingam - STFC UKRI <karthikeyan.chockalingam at stfc.ac.uk<mailto:karthikeyan.chockalingam at stfc.ac.uk>> wrote:
Hello,
I am trying to run ex45 (in KSP tutorial) using hypre on gpus. I have attached the python configuration file and -log_view output from running the below command options
mpirun -n 2 ./ex45 -log_view -da_grid_x 169 -da_grid_y 169 -da_grid_z 169 -dm_mat_type mpiaijcusparse -dm_vec_type mpicuda -ksp_type gmres -pc_type hypre -pc_hypre_type boomeramg -ksp_gmres_restart 31 -pc_hypre_boomeramg_strong_threshold 0.7 -ksp_monitor
The problem was solved and converged but from the output file I suspect hypre is not running on gpus as PCApply and DMCreate does not record any gpu Mflop/s. However, some events such KSPSolve, MatMult etc are running on gpus.
Can you please let me know if I need to add any extra flag to the attached arch-ci-linux-cuda11-double-xx.py script file to get hypre working on gpus?
Karthik.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211008/d9ae5b07/attachment-0001.html>
