[petsc-users] Eigenvalues always converge to zero when using slepc4py-complex
Yelyzaveta Velizhanina velizhaninae at gmail.com
Thu Oct 7 04:07:06 CDT 2021
Hello Lisandro,
I am testing EPS for a random non-Hermitian complex matrix in shift-invert mode and comparing with SciPy’s wrapper of Lapack – seems to be working perfectly. Thanks.
Yelyzaveta.
Date: Wednesday, 6 October 2021 at 20:52
To: Yelyzaveta Velizhanina <velizhaninae at gmail.com>
Cc: Jose E. Roman <jroman at dsic.upv.es>, petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Eigenvalues always converge to zero when using slepc4py-complex
The new builds are up. Jose added instructions in the SLEPc FAQ. Could you try again?
On Mon, 4 Oct 2021 at 16:13 Yelyzaveta Velizhanina <velizhaninae at gmail.com<mailto:velizhaninae at gmail.com>> wrote:
I see. Thanks, much appreciated.
Best regards,
Yelyzaveta Velizhanina.
From: Jose E. Roman <jroman at dsic.upv.es<mailto:jroman at dsic.upv.es>>
Date: Monday, 4 October 2021 at 15:10
To: Yelyzaveta Velizhanina <velizhaninae at gmail.com<mailto:velizhaninae at gmail.com>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>
Conda supports complex scalars for petsc4py. However, this is not implemented in slepc4py. Lisandro is trying to get this fixed, so if no issues arise this will be available in a couple of days, with slepc4py-3.16.0.
Jose
> El 3 oct 2021, a las 22:45, Yelyzaveta Velizhanina <velizhaninae at gmail.com<mailto:velizhaninae at gmail.com>> escribió:
> Dear all,
> I am having a problem to get EPS run properly with PETSc and SLEPc build with scalar_value=complex. I am using petsc4py and slepc4py. Installed everything, including PETSc and SLEPc, with conda. While real scalar value build works well, when using the complex one, all the eigenvalues always converge to 0 for any matrix and any solver. I’ve tried running examples given in this repo https://github.com/myousefi2016/slepc4py as well - same outcome, only zero eigenvalues. I am running MacOSX BigSur.
> Will appreciate any help,
> Best regards,
Lisandro Dalcin
Senior Research Scientist
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211007/03c61260/attachment.html>
