[petsc-users] Disconnected domains and Poisson equation
    Marco Cisternino
    marco.cisternino at optimad.it
    Wed Oct  6 12:20:29 CDT 2021
Hello Barry.
I tried to force the solver to start from an initial guess which is not the solution of the problem. For sake of completeness, the solution has to be a constant field.
With this initial condition, the solver iterates to a solution which is constant in the 2 sub-domains but
  *   the constants have not the same value
  *   they are not close to zero  (minimal norm solution)
  *   they  are not opposite (zero-average solution over the whole domain, like 3 and -3)
After 20 CFD iterations my pressure is 32 in one sub-domain and 2.2 in the other one. And their norm is increasing.
How can I force the solver to give me minimal norm solution, or in other words the zero constant?
I can do it by myself, anchoring domain-by-domain the solution removing its local average, but I was wondering if the solver can do this for me.
In some way, giving a null space made of 2 vectors (1 on dofs living in the sub-domain and zero elsewhere), I would expect a solution with zero average in the 2 sub-domains, separately, but I’m wrong, probably.
Finally, which is the closure of the problem defining the value of the constant? Zero-average condition, minimal norm condition, or none of them?
Thanks!
Bests,
Marco Cisternino, PhD
marco.cisternino at optimad.it<mailto:marco.cisternino at optimad.it>
______________________
Optimad Engineering Srl
Via Bligny 5, Torino, Italia.
+3901119719782
www.optimad.it<http://www.optimad.it/>
Sent: venerdì 1 ottobre 2021 16:56
To: Marco Cisternino <marco.cisternino at optimad.it>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Disconnected domains and Poisson equation
On Oct 1, 2021, at 6:38 AM, Marco Cisternino <marco.cisternino at optimad.it<mailto:marco.cisternino at optimad.it>> wrote:
Thank you Barry.
I added a custom atoll = 1.0e-12 and this makes the CFD stable with all the linear solver types. CFD solution is good and pressure is a good “zero” field at every CFD iteration.
I did the same test using ASM+ILU+FGMRES(BCGS and GMRES) and the behaviour is the same.
During some CFD iteration the residual of linear system starts slightly higher than atol and the linear solver makes some iteration (2/3 iterations) before it stops because of atol.
The pressure is still different in the 2 sub-domains (order 1.0e-14 because of those few linear solver iterations), therefore no symmetry of the solution In the 2 sub-domains.
I think it is a matter of round-off, do you agree on this? Or do I need to take care of this difference as a symptom of something wrong?
  Yes, if the differences in the two solutions are order 1.e-14 that is very good, one cannot expect them to be identical.
Thank you for your support.
Marco Cisternino
From: Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>>
Sent: giovedì 30 settembre 2021 16:39
To: Marco Cisternino <marco.cisternino at optimad.it<mailto:marco.cisternino at optimad.it>>
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
   It looks like the initial solution (guess) is to round-off the solution to the linear system 9.010260489109e-14
0 KSP unpreconditioned resid norm 9.010260489109e-14 true resid norm 9.010260489109e-14 ||r(i)||/||b|| 2.021559024868e+00
  0 KSP Residual norm 9.010260489109e-14 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  1 KSP unpreconditioned resid norm 4.918108339808e-15 true resid norm 4.918171792537e-15 ||r(i)||/||b|| 1.103450292594e-01
  1 KSP Residual norm 4.918108339808e-15 % max 9.566256813737e-01 min 9.566256813737e-01 max/min 1.000000000000e+00
  2 KSP unpreconditioned resid norm 1.443599554690e-15 true resid norm 1.444867143493e-15 ||r(i)||/||b|| 3.241731154382e-02
  2 KSP Residual norm 1.443599554690e-15 % max 9.614019380614e-01 min 7.360950481750e-01 max/min 1.306083963538e+00
Thus the Krylov solver will not be able to improve the solution, it then gets stuck trying to improve the solution but cannot because of round off.
In other words the algorithm has converged (even at the initial solution (guess) and should stop immediately.
You can use -ksp_atol 1.e-12 to get it to stop immediately without iterating if the initial residual is less than 1e-12.
Barry
On Sep 30, 2021, at 4:16 AM, Marco Cisternino <marco.cisternino at optimad.it<mailto:marco.cisternino at optimad.it>> wrote:
Hello Barry.
This is the output of ksp_view using fgmres and gamg. It has to be said that the solution of the linear system should be a zero values field. As you can see both unpreconditioned residual and r/b converge at this iteration of the CFD solver. During the time integration of the CFD, I can observe pressure linear solver residuals behaving in a different way: unpreconditioned residual stil converges but r/b stalls. After the output of ksp_view I add the output of ksp_monitor_true_residual for one of these iteration where r/b stalls.
KSP Object: 1 MPI processes
  type: fgmres
    restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    happy breakdown tolerance 1e-30
  maximum iterations=100, nonzero initial guess
  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
  right preconditioning
  using UNPRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
  type: gamg
    type is MULTIPLICATIVE, levels=4 cycles=v
      Cycles per PCApply=1
      Using externally compute Galerkin coarse grid matrices
      GAMG specific options
        Threshold for dropping small values in graph on each level =   0.02   0.02
        Threshold scaling factor for each level not specified = 1.
        AGG specific options
          Symmetric graph true
          Number of levels to square graph 1
          Number smoothing steps 0
  Coarse grid solver -- level -------------------------------
    KSP Object: (mg_coarse_) 1 MPI processes
      type: preonly
      maximum iterations=10000, initial guess is zero
      left preconditioning
      using NONE norm type for convergence test
    PC Object: (mg_coarse_) 1 MPI processes
      type: bjacobi
        number of blocks = 1
        Local solve is same for all blocks, in the following KSP and PC objects:
        KSP Object: (mg_coarse_sub_) 1 MPI processes
          type: preonly
          maximum iterations=1, initial guess is zero
          using DEFAULT norm type for convergence test
        PC Object: (mg_coarse_sub_) 1 MPI processes
          type: lu
          PC has not been set up so information may be incomplete
            out-of-place factorization
            tolerance for zero pivot 2.22045e-14
            using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
            matrix ordering: nd
          linear system matrix = precond matrix:
          Mat Object: 1 MPI processes
            type: seqaij
            rows=18, cols=18
            total: nonzeros=104, allocated nonzeros=104
            total number of mallocs used during MatSetValues calls =0
              not using I-node routines
        type: seqaij
        rows=18, cols=18
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object: (mg_levels_1_) 1 MPI processes
      type: chebyshev
        eigenvalue estimates used:  min = 0., max = 0.
        eigenvalues estimate via gmres min 0., max 0.
        eigenvalues estimated using gmres with translations  [0. 0.1; 0. 1.1]
        KSP Object: (mg_levels_1_esteig_) 1 MPI processes
          type: gmres
          maximum iterations=10, initial guess is zero
          tolerances:  relative=1e-12, absolute=1e-50, divergence=10000.
        estimating eigenvalues using noisy right hand side
      maximum iterations=2, nonzero initial guess
    PC Object: (mg_levels_1_) 1 MPI processes
      type: sor
        type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.
        type: seqaij
        rows=67, cols=67
        total: nonzeros=675, allocated nonzeros=675
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object: (mg_levels_2_) 1 MPI processes
      type: chebyshev
        KSP Object: (mg_levels_2_esteig_) 1 MPI processes
          type: gmres
    PC Object: (mg_levels_2_) 1 MPI processes
      type: sor
        type: seqaij
        rows=348, cols=348
        total: nonzeros=3928, allocated nonzeros=3928
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object: (mg_levels_3_) 1 MPI processes
      type: chebyshev
        KSP Object: (mg_levels_3_esteig_) 1 MPI processes
          type: gmres
    PC Object: (mg_levels_3_) 1 MPI processes
      type: sor
        type: seqaij
        rows=3584, cols=3584
        total: nonzeros=23616, allocated nonzeros=23616
          has attached null space
    type: seqaij
  Pressure system has reached convergence in 0 iterations with reason 3.
  0 KSP unpreconditioned resid norm 4.798763170703e-16 true resid norm 4.798763170703e-16 ||r(i)||/||b|| 1.000000000000e+00
  0 KSP Residual norm 4.798763170703e-16 % max 1.000000000000e+00 min 1.000000000000e+00 max/min 1.000000000000e+00
  1 KSP unpreconditioned resid norm 1.648749109132e-17 true resid norm 1.648749109132e-17 ||r(i)||/||b|| 3.435779284125e-02
  1 KSP Residual norm 1.648749109132e-17 % max 9.561792537103e-01 min 9.561792537103e-01 max/min 1.000000000000e+00
  2 KSP unpreconditioned resid norm 4.737880600040e-19 true resid norm 4.737880600040e-19 ||r(i)||/||b|| 9.873128619820e-04
  2 KSP Residual norm 4.737880600040e-19 % max 9.828636644296e-01 min 9.293131521763e-01 max/min 1.057623753767e+00
  3 KSP unpreconditioned resid norm 2.542212716830e-20 true resid norm 2.542212716830e-20 ||r(i)||/||b|| 5.297641551371e-05
  3 KSP Residual norm 2.542212716830e-20 % max 9.933572357920e-01 min 9.158303248850e-01 max/min 1.084652046127e+00
  4 KSP unpreconditioned resid norm 6.614510286263e-21 true resid norm 6.614510286269e-21 ||r(i)||/||b|| 1.378378146822e-05
  4 KSP Residual norm 6.614510286263e-21 % max 9.950912550705e-01 min 6.296575800237e-01 max/min 1.580368896747e+00
  5 KSP unpreconditioned resid norm 1.981505525281e-22 true resid norm 1.981505525272e-22 ||r(i)||/||b|| 4.129200493513e-07
  5 KSP Residual norm 1.981505525281e-22 % max 9.984097962703e-01 min 5.316259535293e-01 max/min 1.878030577029e+00
Linear solve converged due to CONVERGED_RTOL iterations 5
Ksp_monitor_true_residual output for stalling r/b CFD iteration
  3 KSP unpreconditioned resid norm 6.623206616803e-16 true resid norm 6.654132553541e-16 ||r(i)||/||b|| 1.492933720678e-02
  3 KSP Residual norm 6.623206616803e-16 % max 9.764112945239e-01 min 4.911485418014e-01 max/min 1.988016274960e+00
  4 KSP unpreconditioned resid norm 6.551896936698e-16 true resid norm 6.646157296305e-16 ||r(i)||/||b|| 1.491144376933e-02
  4 KSP Residual norm 6.551896936698e-16 % max 9.883425885532e-01 min 1.461270778833e-01 max/min 6.763582786091e+00
  5 KSP unpreconditioned resid norm 6.222297644887e-16 true resid norm 1.720560536914e-15 ||r(i)||/||b|| 3.860282047823e-02
  5 KSP Residual norm 6.222297644887e-16 % max 1.000409371755e+00 min 4.989767363560e-03 max/min 2.004921870829e+02
  6 KSP unpreconditioned resid norm 6.496945794974e-17 true resid norm 2.031914800253e-14 ||r(i)||/||b|| 4.558842341106e-01
  6 KSP Residual norm 6.496945794974e-17 % max 1.004914985753e+00 min 1.459258738706e-03 max/min 6.886475709192e+02
  7 KSP unpreconditioned resid norm 1.965237342540e-17 true resid norm 1.684522207337e-14 ||r(i)||/||b|| 3.779425772373e-01
  7 KSP Residual norm 1.965237342540e-17 % max 1.005737762541e+00 min 1.452603803766e-03 max/min 6.923689446035e+02
  8 KSP unpreconditioned resid norm 1.627718951285e-17 true resid norm 1.958642967520e-14 ||r(i)||/||b|| 4.394448276241e-01
  8 KSP Residual norm 1.627718951285e-17 % max 1.006364278765e+00 min 1.452081813014e-03 max/min 6.930492963590e+02
  9 KSP unpreconditioned resid norm 1.616577677764e-17 true resid norm 2.019110946644e-14 ||r(i)||/||b|| 4.530115373837e-01
  9 KSP Residual norm 1.616577677764e-17 % max 1.006648747131e+00 min 1.452031376577e-03 max/min 6.932692801059e+02
10 KSP unpreconditioned resid norm 1.285788988203e-17 true resid norm 2.065082694477e-14 ||r(i)||/||b|| 4.633258453698e-01
10 KSP Residual norm 1.285788988203e-17 % max 1.007469033514e+00 min 1.433291867068e-03 max/min 7.029057072477e+02
11 KSP unpreconditioned resid norm 5.490854431580e-19 true resid norm 1.798071628891e-14 ||r(i)||/||b|| 4.034187394623e-01
11 KSP Residual norm 5.490854431580e-19 % max 1.008058905554e+00 min 1.369401685301e-03 max/min 7.361309076612e+02
12 KSP unpreconditioned resid norm 1.371754802104e-20 true resid norm 1.965688920064e-14 ||r(i)||/||b|| 4.410256708163e-01
12 KSP Residual norm 1.371754802104e-20 % max 1.008409402214e+00 min 1.369243011779e-03 max/min 7.364721919624e+02
Linear solve converged due to CONVERGED_RTOL iterations 12
Marco Cisternino
Sent: mercoledì 29 settembre 2021 18:34
On Sep 29, 2021, at 11:59 AM, Marco Cisternino <marco.cisternino at optimad.it<mailto:marco.cisternino at optimad.it>> wrote:
For sake of completeness, explicitly building the null space using a vector per sub-domain make s the CFD runs using BCGS and GMRES more stable, but still slower than FGMRES.
  Something is strange. Please run with -ksp_view and send the output on the solver details.
I had divergence using BCGS and GMRES setting the null space with only one constant.
Thanks
Marco Cisternino
Sent: mercoledì 29 settembre 2021 17:54
To: Barry Smith <bsmith at petsc.dev<mailto:bsmith at petsc.dev>>
Subject: RE: [petsc-users] Disconnected domains and Poisson equation
Thank you Barry for the quick reply.
About the null space: I already tried what you suggest, building 2 Vec (constants) with 0 and 1 chosen by sub-domain, normalizing them and setting the null space like this
MatNullSpaceCreate(PETSC_COMM_WORLD,PETSC_FALSE,nconstants,constants,&nullspace);
The solution is slightly different in values but it is still different in the two sub-domains.
About the solver: I tried BCGS, GMRES and FGMRES. The linear system is a pressure system in a navier-stokes solver and only solving with FGMRES makes the CFD stable, with BCGS and GMRES the CFD solution diverges. Moreover, in the same case but with a single domain, CFD solution is stable using all the solvers, but FGMRES converges in much less iterations than the others.
Marco Cisternino
Sent: mercoledì 29 settembre 2021 15:59
  The problem actually has a two dimensional null space; constant on each domain but possibly different constants. I think you need to build the MatNullSpace by explicitly constructing two vectors, one with 0 on one domain and constant value on the other and one with 0 on the other domain and constant on the first.
   Separate note: why use FGMRES instead of just GMRES? If the problem is linear and the preconditioner is linear (no GMRES inside the smoother) then you can just use GMRES and it will save a little space/work and be conceptually clearer.
  Barry
On Sep 29, 2021, at 8:46 AM, Marco Cisternino <marco.cisternino at optimad.it<mailto:marco.cisternino at optimad.it>> wrote:
Good morning,
I want to solve the Poisson equation on a 3D domain with 2 non-connected sub-domains.
I am using FGMRES+GAMG and I have no problem if the two sub-domains see a Dirichlet boundary condition each.
On the same domain I would like to solve the Poisson equation imposing periodic boundary condition in one direction and homogenous Neumann boundary conditions in the other two directions. The two sub-domains are symmetric with respect to the separation between them and the operator discretization and the right hand side are symmetric as well. It would be nice to have the same solution in both the sub-domains.
Setting the null space to the constant, the solver converges to a solution having the same gradients in both sub-domains but different values.
Am I doing some wrong with the null space? I’m not setting a block matrix (one block for each sub-domain), should I?
I tested the null space against the matrix using MatNullSpaceTest and the answer is true. Can I do something more to have a symmetric solution as outcome of the solver?
Thank you in advance for any comments and hints.
Best regards,
Marco Cisternino
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211006/c192d5ca/attachment-0001.html>
