[petsc-users] SLEPc: smallest eigenvalues
Varun Hiremath varunhiremath at gmail.com
Tue Oct 5 01:04:19 CDT 2021
Hi Jose,
I have now gotten the quadratic problem working decently using the PEP
package with appropriate scaling and preconditioning, so thanks for all the
suggestions! For the case where K is a shell matrix, I used a scaling based
on an approximation of K, and that seems to be working well.
So now that both linear and quadratic problems are working, I wanted to get
your suggestions on solving a non-linear problem. In some of our cases, we
have a non-linear source term S(lambda) on the right-hand side of the
equation as follows:
    (K + lambda*C + lambda^2*M)*x = S(lambda)*x,
where the source can sometimes be simplified as S(lambda) =
exp(lambda*t)*A, where A is a constant matrix.
I am currently solving this non-linear problem iteratively. For each
eigenvalue, I compute the source and add it into the K matrix, and then
iterate until convergence. For this reason, I end up solving the system
multiple times which makes it very slow. I saw some examples of non-linear
problems included in the NEP package. I just wanted to get your thoughts if
I would benefit from using the NEP package for this particular problem?
Will I be able to use preconditioning and scaling as with the PEP package
to speed up the computation for the case where K is a shell matrix? Thanks
for your help.
Varun
On Thu, Sep 30, 2021 at 10:12 PM Varun Hiremath <varunhiremath at gmail.com>
wrote:
> Hi Jose,
> Thanks again for your valuable suggestions. I am still working on this but
> wanted to give you a quick update.
> For the linear problem, I tried different KSP solvers, and finally, I'm
> getting good convergence using CGS with LU (using MUMPS) inexact inverse.
> So thank you very much for your help!
> But for the quadratic problem, I'm still struggling. As you suggested, I
> have now started using the PEP solver. For the simple case where the K
> matrix is explicitly known, everything works fine. But for the case where K
> is a shell matrix, it struggles to converge. I am yet to try the scaling
> option and some other preconditioning options. I will get back to you on
> this if I have any questions. Appreciate your help!
> Thanks,
> Varun
> On Tue, Sep 28, 2021 at 8:09 AM Jose E. Roman <jroman at dsic.upv.es> wrote:
>> > El 28 sept 2021, a las 7:50, Varun Hiremath <varunhiremath at gmail.com>
>> escribió:
>> > Hi Jose,
>> > I implemented the LU factorized preconditioner and tested it using
>> PREONLY + LU, but that actually is converging to the wrong eigenvalues,
>> compared to just using BICGS + BJACOBI, or simply computing
>> EPS_SMALLEST_MAGNITUDE without any preconditioning. My preconditioning
>> matrix is only a 1st order approximation, and the off-diagonal terms are
>> not very accurate, so I'm guessing this is why the LU factorization doesn't
>> help much? Nonetheless, using BICGS + BJACOBI with slightly relaxed
>> tolerances seems to be working fine.
>> If your PCMAT is not an exact inverse, then you have to iterate, i.e. not
>> use KSPPREONLY but KSPBCGS or another.
>> > I now want to test the same preconditioning idea for a quadratic
>> problem. I am solving a quadratic equation similar to Eqn.(5.1) in the
>> SLEPc manual:
>> >       (K + lambda*C + lambda^2*M)*x = 0,
>> > I don't use the PEP package directly, but solve this by linearizing
>> similar to Eqn.(5.3) and calling EPS. Without explicitly forming the full
>> matrix, I just use the block matrix structure as explained in the below
>> example and that works nicely for my case:
>> > https://slepc.upv.es/documentation/current/src/eps/tutorials/ex9.c.html
>> Using PEP is generally recommended. The default solver TOAR is
>> memory-efficient and performs less computation than a trivial
>> linearization. In addition, PEP allows you to do scaling, which is often
>> very important to get accurate results in some problems, depending on
>> conditioning.
>> In your case K is a shell matrix, so things may not be trivial. If I am
>> not wrong, you should be able to use STSetPreconditionerMat() for a PEP,
>> where the preconditioner in this case should be built to approximate
>> Q(sigma), where Q(.) is the quadratic polynomial and sigma is the target.
>> > In my case, K is not explicitly known, and for linear problems, where C
>> = 0, I am using a 1st order approximation of K as the preconditioner. Now
>> could you please tell me if there is a way to conveniently set the
>> preconditioner for the quadratic problem, which will be of the form [-K 0;
>> 0 I]? Note that K is constructed in parallel (the rows are distributed), so
>> I wasn't sure how to construct this preconditioner matrix which will be
>> compatible with the shell matrix structure that I'm using to define the
>> MatMult function as in ex9.
>> The shell matrix of ex9.c interleaves the local parts of the first block
>> and the second block. In other words, a process' local part consists of the
>> local rows of the first block followed by the local rows of the second
>> block. In your case, the local rows of K followed by the local rows of the
>> identity (appropriately padded with zeros).
>> Jose
>> > Thanks,
>> > Varun
>> > On Fri, Sep 24, 2021 at 11:50 PM Varun Hiremath <
>> varunhiremath at gmail.com> wrote:
>> > Ok, great! I will give that a try, thanks for your help!
>> > On Fri, Sep 24, 2021 at 11:12 PM Jose E. Roman <jroman at dsic.upv.es>
>> wrote:
>> > Yes, you can use PCMAT
>> https://petsc.org/release/docs/manualpages/PC/PCMAT.html then pass a
>> preconditioner matrix that performs the inverse via a shell matrix.
>> > > El 25 sept 2021, a las 8:07, Varun Hiremath <varunhiremath at gmail.com>
>> escribió:
>> > > Hi Jose,
>> > > Thanks for checking my code and providing suggestions.
>> > > In my particular case, I don't know the matrix A explicitly, I
>> compute A*x in a matrix-free way within a shell matrix, so I can't use any
>> of the direct factorization methods. But just a question regarding your
>> suggestion to compute a (parallel) LU factorization. In our work, we do use
>> MUMPS to compute the parallel factorization. For solving the generalized
>> problem, A*x = lambda*B*x, we are computing inv(B)*A*x within a shell
>> matrix, where factorization of B is computed using MUMPS. (We don't call
>> MUMPS through SLEPc as we have our own MPI wrapper and other user settings
>> to handle.)
>> > > So for the preconditioning, instead of using the iterative solvers,
>> can I provide a shell matrix that computes inv(P)*x corrections (where P is
>> the preconditioner matrix) using MUMPS direct solver?
>> > > And yes, thanks, #define PETSC_USE_COMPLEX 1 is not needed, it works
>> without it.
>> > > Regards,
>> > > Varun
>> > > On Fri, Sep 24, 2021 at 9:14 AM Jose E. Roman <jroman at dsic.upv.es>
>> wrote:
>> > > If you do
>> > > $ ./acoustic_matrix_test.o -shell 0 -st_type sinvert -deflate 1
>> > > then it is using an LU factorization (the default), which is fast.
>> > > Use -eps_view to see which solver settings are you using.
>> > > BiCGStab with block Jacobi does not work for you matrix, it exceeds
>> the maximum 10000 iterations. So this is not viable unless you can find a
>> better preconditioner for your problem. If not, just using
>> EPS_SMALLEST_MAGNITUDE will be faster.
>> > > Computing smallest magnitude eigenvalues is a difficult task. The
>> most robust way is to compute a (parallel) LU factorization if you can
>> afford it.
>> > > A side note: don't add this to your source code
>> > > This define is taken from PETSc's include files, you should not mess
>> with it. Instead, you probably want to add something like this AFTER
>> #include <slepceps.h>:
>> > > #if !defined(PETSC_USE_COMPLEX)
>> > > #error "Requires complex scalars"
>> > > #endif
>> > > Jose
>> > > > El 22 sept 2021, a las 19:38, Varun Hiremath <
>> varunhiremath at gmail.com> escribió:
>> > > > Hi Jose,
>> > > > Thank you, that explains it and my example code works now without
>> specifying "-eps_target 0" in the command line.
>> > > > However, both the Krylov inexact shift-invert and JD solvers are
>> struggling to converge for some of my actual problems. The issue seems to
>> be related to non-symmetric general matrices. I have extracted one such
>> matrix attached here as MatA.gz (size 100k), and have also included a short
>> program that loads this matrix and then computes the smallest eigenvalues
>> as I described earlier.
>> > > > For this matrix, if I compute the eigenvalues directly (without
>> using the shell matrix) using shift-and-invert (as below) then it converges
>> in less than a minute.
>> > > > However, if I use the shell matrix and use any of the
>> preconditioned solvers JD or Krylov shift-invert (as shown below) with the
>> same matrix as the preconditioner, then they struggle to converge.
>> > > > $ ./acoustic_matrix_test.o -usejd 1 -deflate 1
>> > > > $ ./acoustic_matrix_test.o -sinvert 1 -deflate 1
>> > > > Could you please check the attached code and suggest any changes in
>> settings that might help with convergence for these kinds of matrices? I
>> appreciate your help!
>> > > > Thanks,
>> > > > Varun
>> > > > On Tue, Sep 21, 2021 at 11:14 AM Jose E. Roman <jroman at dsic.upv.es>
>> wrote:
>> > > > I will have a look at your code when I have more time. Meanwhile, I
>> am answering 3) below...
>> > > > > El 21 sept 2021, a las 0:23, Varun Hiremath <
>> > > > > Hi Jose,
>> > > > > Sorry, it took me a while to test these settings in the new
>> builds. I am getting good improvement in performance using the
>> preconditioned solvers, so thanks for the suggestions! But I have some
>> questions related to the usage.
>> > > > > We are using SLEPc to solve the acoustic modal eigenvalue
>> problem. Attached is a simple standalone program that computes acoustic
>> modes in a simple rectangular box. This program illustrates the general
>> setup I am using, though here the shell matrix and the preconditioner
>> matrix are the same, while in my actual program the shell matrix computes
>> A*x without explicitly forming A, and the preconditioner is a 0th order
>> approximation of A.
>> > > > > In the attached program I have tested both
>> > > > > 1) the Krylov-Schur with inexact shift-and-invert (implemented
>> under the option sinvert);
>> > > > > 2) the JD solver with preconditioner (implemented under the
>> option usejd)
>> > > > > Both the solvers seem to work decently, compared to no
>> preconditioning. This is how I run the two solvers (for a mesh size of
>> 1600x400):
>> > > > > $ ./acoustic_box_test.o -nx 1600 -ny 400 -usejd 1 -deflate 1
>> -eps_target 0
>> > > > > $ ./acoustic_box_test.o -nx 1600 -ny 400 -sinvert 1 -deflate 1
>> -eps_target 0
>> > > > > Both finish in about ~10 minutes on my system in serial. JD seems
>> to be slightly faster and more accurate (for the imaginary part of
>> eigenvalue).
>> > > > > The program also runs in parallel using mpiexec. I use complex
>> builds, as in my main program the matrix can be complex.
>> > > > > Now here are my questions:
>> > > > > 1) For this particular problem type, could you please check if
>> these are the best settings that one could use? I have tried different
>> combinations of KSP/PC types e.g. GMRES, GAMG, etc, but BCGSL + BJACOBI
>> seems to work the best in serial and parallel.
>> > > > > 2) When I tested these settings in my main program, for some
>> reason the JD solver was not converging. After further testing, I found the
>> issue was related to the setting of "-eps_target 0". I have included
>> "EPSSetTarget(eps,0.0);" in the program and I assumed this is equivalent to
>> passing "-eps_target 0" from the command line, but that doesn't seem to be
>> the case. For instance, if I run the attached program without "-eps_target
>> 0" in the command line then it doesn't converge.
>> -eps_target 0
>> > > > >  the above finishes in about 10 minutes
>> > > > >  the above doesn't converge even though "EPSSetTarget(eps,0.0);"
>> is included in the code
>> > > > > This only seems to affect the JD solver, not the Krylov
>> shift-and-invert (-sinvert 1) option. So is there any difference between
>> passing "-eps_target 0" from the command line vs using
>> "EPSSetTarget(eps,0.0);" in the code? I cannot pass any command line
>> arguments in my actual program, so need to set everything internally.
>> > > > > 3) Also, another minor related issue. While using the inexact
>> shift-and-invert option, I was running into the following error:
>> > > > > Missing or incorrect user input
>> > > > > Shift-and-invert requires a target 'which' (see
>> EPSSetWhichEigenpairs), for instance -st_type sinvert -eps_target 0
>> -eps_target_magnitude
>> > > > > I already have the below two lines in the code:
>> > > > > EPSSetWhichEigenpairs(eps,EPS_SMALLEST_MAGNITUDE);
>> > > > > so shouldn't these be enough? If I comment out the first line
>> "EPSSetWhichEigenpairs", then the code works fine.
>> > > > You should either do
>> > > > without shift-and-invert or
>> > > > EPSSetWhichEigenpairs(eps,EPS_TARGET_MAGNITUDE);
>> > > > with shift-and-invert. The latter can also be used without
>> shift-and-invert (e.g. in JD).
>> > > > I have to check, but a possible explanation why in your comment
>> above (2) the command-line option -eps_target 0 works differently is that
>> it also sets -eps_target_magnitude if omitted, so to be equivalent in
>> source code you have to call both
>> > > > Jose
>> > > > > I have some more questions regarding setting the preconditioner
>> for a quadratic eigenvalue problem, which I will ask in a follow-up email.
>> > > > > Thanks for your help!
>> > > > > -Varun
>> > > > > On Thu, Jul 1, 2021 at 5:01 AM Varun Hiremath <
>> > > > > Thank you very much for these suggestions! We are currently using
>> version 3.12, so I'll try to update to the latest version and try your
>> suggestions. Let me get back to you, thanks!
>> > > > > On Thu, Jul 1, 2021, 4:45 AM Jose E. Roman <jroman at dsic.upv.es>
>> wrote:
>> > > > > Then I would try Davidson methods https://doi.org/10.1145/2543696
>> > > > > You can also try Krylov-Schur with "inexact" shift-and-invert,
>> for instance, with preconditioned BiCGStab or GMRES, see section 3.4.1 of
>> the users manual.
>> > > > > In both cases, you have to pass matrix A in the call to
>> EPSSetOperators() and the preconditioner matrix via
>> STSetPreconditionerMat() - note this function was introduced in version
>> 3.15.
>> > > > > Jose
>> > > > > > El 1 jul 2021, a las 13:36, Varun Hiremath <
>> > > > > > Thanks. I actually do have a 1st order approximation of matrix
>> A, that I can explicitly compute and also invert. Can I use that matrix as
>> preconditioner to speed things up? Is there some example that explains how
>> to setup and call SLEPc for this scenario?
>> > > > > > On Thu, Jul 1, 2021, 4:29 AM Jose E. Roman <jroman at dsic.upv.es>
>> wrote:
>> > > > > > For smallest real parts one could adapt ex34.c, but it is going
>> to be costly
>> https://slepc.upv.es/documentation/current/src/eps/tutorials/ex36.c.html
>> > > > > > Also, if eigenvalues are clustered around the origin,
>> convergence may still be very slow.
>> > > > > > It is a tough problem, unless you are able to compute a good
>> preconditioner of A (no need to compute the exact inverse).
>> > > > > > Jose
>> > > > > > > El 1 jul 2021, a las 13:23, Varun Hiremath <
>> > > > > > > I'm solving for the smallest eigenvalues in magnitude. Though
>> is it cheaper to solve smallest in real part, as that might also work in my
>> case? Thanks for your help.
>> > > > > > > On Thu, Jul 1, 2021, 4:08 AM Jose E. Roman <
>> > > > > > > Smallest eigenvalue in magnitude or real part?
>> > > > > > > > El 1 jul 2021, a las 11:58, Varun Hiremath <
>> > > > > > > > Sorry, no both A and B are general sparse matrices
>> (non-hermitian). So is there anything else I could try?
>> > > > > > > > On Thu, Jul 1, 2021 at 2:43 AM Jose E. Roman <
>> > > > > > > > Is the problem symmetric (GHEP)? In that case, you can try
>> LOBPCG on the pair (A,B). But this will likely be slow as well, unless you
>> can provide a good preconditioner.
>> > > > > > > > Jose
>> > > > > > > > > El 1 jul 2021, a las 11:37, Varun Hiremath <
>> > > > > > > > > Hi All,
>> > > > > > > > > I am trying to compute the smallest eigenvalues of a
>> generalized system A*x= lambda*B*x. I don't explicitly know the matrix A
>> (so I am using a shell matrix with a custom matmult function) however, the
>> matrix B is explicitly known so I compute inv(B)*A within the shell matrix
>> and solve inv(B)*A*x = lambda*x.
>> > > > > > > > > To compute the smallest eigenvalues it is recommended to
>> solve the inverted system, but since matrix A is not explicitly known I
>> can't invert the system. Moreover, the size of the system can be really
>> big, and with the default Krylov solver, it is extremely slow. So is there
>> a better way for me to compute the smallest eigenvalues of this system?
>> > > > > > > > > Thanks,
>> > > > > > > > > Varun
>> > > > > <acoustic_box_test.cpp>
>> > > > <acoustic_matrix_test.cpp><MatA.gz>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211004/f4fd8a4b/attachment-0001.html>
