[petsc-users] Skipping data when reading from binary file
Mon Oct 4 08:37:08 CDT 2021
On Mon, Oct 4, 2021 at 9:26 AM Peder Jørgensgaard Olesen via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hello
> I have a binary file in which a mix of different objects is stored (Vecs,
> Mats, PetscInts). I can read each element just fine using VecLoad, MatLoad,
> and PetscIntView, provided they're read in the order in which they were put
> in the binary. What I would like to do is to skip the reading of any
> unneeded element, instead proceeding directly to the next one. I tried
> using PetscBinarySeek() for this, as shown in the attached code. This
> produces segmentation faults, suggesting that the file pointer isn't going
> where I want it to.
There is header information you also have to skip for each object.
We can go over the sizes  for that (it is best just to look at the code),
but that is fragile. A more robust way to achieve this random
access is to use HDF5 and name the objects.
     Matt
> Any suggestions as to what I'm doing wrong here?
> Best regards,
> Peder
> PhD student
> Department of Mechanical Engineering
> pjool at mek.dtu.dk
> Koppels Allé
> Building 403, room 105
> 2800 Kgs. Lyngby
> www.dtu.dk/english
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211004/6203cf97/attachment.html>
