[petsc-users] Output data using ExodusIIViewer
David Andrs
andrsd at gmail.com
Tue Nov 30 18:31:33 CST 2021
I see. I added a "Cell Sets" label like so:
DMCreateLabel(dm, "Cell Sets");
DMLabel cs_label;
DMGetLabel(dm, "Cell Sets", &cs_label);
DMLabelAddStratum(cs_label, 0);
PetscInt idxs[] = { 1 };
IS is;
ISCreateGeneral(comm, 1, idxs, PETSC_COPY_VALUES, &is);
DMLabelSetStratumIS(cs_label, 0, is);
ISDestroy(&is);
Note, that I have only a single element (Quad4) in the mesh and I am just trying to get this working, so I understand what needs to happen for larger meshes.
This got me past the segfault, but now I see:
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: Number of vertices 1 in dimension 2 has no ExodusII type
So, I assume I need to do something more to make it work.
David
On Nov 30 2021, at 11:39 AM, Blaise Bourdin <bourdin at mcmaster.ca> wrote:
> It looks like your DM cannot be saved in exodus format as such. The exodus format requires that all cells be part of a single block (defined by ‘Cell Set’ labels), and that the cell sets consists of sequentially numbered cells.
> Can you see if that is enough? If not, I will go through your example
> Blaise
> > On Nov 30, 2021, at 9:50 AM, David Andrs <andrsd at gmail.com (mailto:andrsd at gmail.com)> wrote:
> > Hello!
> > I am trying to store data into an ExodusII file using the ExodusIIViewer, but running into a segfault inside PETSc. Attached is a minimal example showing the problem. It can very much be that I am missing something obvious. However, if I change the code to VTKViewer I get the desired output file.
> > Machine: MacBook Pro 2019
> > OS version/type: Darwin notak.local 21.1.0 Darwin Kernel Version 21.1.0: Wed Oct 13 17:33:23 PDT 2021; root:xnu-8019.41.5~1/RELEASE_X86_64 x86_64
> > PETSc: Petsc Release Version 3.16.1, Nov 01, 2021
> > MPI: MPICH 3.4.2
> > Compiler: clang-12
> > Call stack (not sure how relevant that is since it is from opt version):
> > * thread #1, queue = 'com.apple.main-thread', stop reason = EXC_BAD_ACCESS (code=1, address=0xc)
> > frame #0: 0x0000000102303ba9 libpetsc.3.16.dylib`DMView_PlexExodusII(dm=<unavailable>, viewer=<unavailable>) at plexexodusii.c:457:45 [opt]
> > 454 else if (degree == 2) nodes[cs] = nodesHexP2;
> > 455 }
> > 456 /* Compute the number of cells not in the connectivity table */
> > -> 457 cellsNotInConnectivity -= nodes[cs][3]*csSize;
> > 458
> > 459 ierr = ISRestoreIndices(stratumIS, &cells);CHKERRQ(ierr);
> > 460 ierr = ISDestroy(&stratumIS);CHKERRQ(ierr);
> > With regards,
> > David Andrs
> > <exo2.c>
> Professor, Department of Mathematics & Statistics
> Hamilton Hall room 409A, McMaster University
> 1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada
> Tel. +1 (905) 525 9140 ext. 27243
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211130/716cb39e/attachment-0001.html>
