[petsc-users] DMPlex shared node indexing
    Matthew Knepley
    knepley at gmail.com
    Fri Nov 26 14:07:50 CST 2021
On Fri, Nov 26, 2021 at 12:49 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
> Dear PETSc-team,
> When the mesh is distributed, the vertices are renumbered and some
> vertices are shared by neighboring CPUs. My question is:
> 1. How to check which vertice is a ghost one?
It is present in the PetscSF describing the connections between local
meshes. So you would do
  DMGetPointSF(dm, &sf);
  PetscSFGetGraph(sf, NULL, &Nl, &leaves, NULL);
If your point in the list 'leaves' of length Nl, then it is a ghost.
> 2. Are those ghost vertices always at the end of vertices list? If not
No.
> 3. Are there simple ways to let those ghost vertices come after owned ones?
You can introduce a permutation of the points when numbering unknowns. This
is what Barry does in his branch.
     Matt
> Many thanks
> Yuan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211126/e7d13d7e/attachment.html>
