[petsc-users] dmplex extruded layers
    Bhargav Subramanya
    bhargav.subramanya at kaust.edu.sa
    Wed Nov 24 16:45:19 CST 2021
On Wed, Nov 24, 2021 at 8:59 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 24, 2021 at 12:27 PM Bhargav Subramanya <
> bhargav.subramanya at kaust.edu.sa> wrote:
>> Dear Matt and Mark,
>> Thank you very much for your reply. Your inputs are very useful to me.
>> On Mon, Nov 22, 2021 at 9:38 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Mon, Nov 22, 2021 at 12:10 PM Bhargav Subramanya <
>>>> Dear All,
>>>> I have a prismatic mesh generated by extruding a base icosahedron
>>>> spherical surface mesh. The mesh is distributed on 2 processes after
>>>> extrusion. The dof for my problem are defined only on the simplices of the
>>>> spherical layers.
>>>> 1. For a given spherical layer, I want to get points, which are
>>>> basically simplices, lying on that layer only. DMPlexGetHeightStratum
>>>> returns the points on all the spherical Layers. I can probably use
>>>> DMPlexFindVertices (based on the radius of the spherical layer) and
>>>> DMPlexGetSimplexOrBoxCells. Could you suggest if there is a better way to
>>>> retrieve the points (which are simplices) on a given spherical layer in the
>>>> extruded mesh?
>>> DMPlexGetHeightStratum() refers to height in the Hasse Diagram, which is
>>> a DAG, not in the mesh. For example, height 0 points are the cells, height
>>> 1 are the faces, etc.
>>> I believe the default numbering for extrusion (in the main branch), is
>>> that all vertices produced from a given vertex be in order. This would mean
>>> that if v were the vertex point number, then
>>>   (v - vStart) % Nl == l
>>> where Nl is the number of layers and l is the layer of that vertex. It
>>> is also the same for triangles. So if you want to segregate each shell,
>>> after extrusion, make a label that gives triangles this marker, and then
>>> use DMPlexLabelComplete(). Then after refinement you will still have the
>>> shells labeled correctly.
>>> I would be happy to help you make an example that does this. It seems
>>> cool.
>> ----- Sure, I am interested to make an example of it. And, I really
>> appreciate your help.
>>>> 2. I am able to visualize the entire mesh using dm_view. Is there a way
>>>> to get the mesh file for the local dm from a specific process?
>>> You can use -dm_partition_view which outputs a field with the process
>>> number. Then use Clip inside Paraview and clip to the process number you
>>> want,
>>> or just view that field so each process has a different color.
>>>> 3. One of my previous emails might have got lost as I mistakenly
>>>> attached a large mesh file and sent it. So I am repeating the question
>>>> here. DMPlexExtrude gives the following error after distributing the base
>>>> 2D spherical mesh. Both refinement or/and extrusion after dm distribution
>>>> does not work for me. In fact, I tried
>>>> with src/dm/impls/plex/tutorials/ex10.c also. Although the mesh is
>>>> distributed after the extrusion in ex10.c (which is working fine for me), I
>>>> tried to distribute before extrusion, and I get the following error. Could
>>>> you please suggest where I might be making a mistake?
>>> So you want to distribute the mesh before extruding. For that small
>>> example (using the main branch), I run
>>>   mpiexec -n 3 ./meshtest -dm_plex_shape sphere -dm_refine_pre 2
>>> -dm_distribute -dm_partition_view -dm_view hdf5:mesh.h5 -dm_extrude 3
>> ----- I pulled the code from the main branch and configured my petsc
>> again. I am now finally able to reproduce the mesh that you have attached.
>> I am able to do parallel mesh refinement, followed by extrusion, and use
>> the following code to check that. However, I still have one problem.
>> Attached are the extruded mesh files.
>> 1. Mesh doesn't seem to be refined properly near interfaces between the
>> processes. I then used -init_dm_distribute_overlap of 1 and that fixed the
>> problem. I hope this is the way to do that.
> Hmm, something is wrong here. We should track this down and fix it. I do
> not see this. Could you tell me how to reproduce the problem?
----- I mainly wanted to check if the mesh was distributed or not before
the extrusion. I do this by specifying different prefix options as shown in
the code below. I think using different prefix options is probably causing
the problem.
 #include <petsc.h>
int main(int argc, char **argv)
DM             dm;
PetscBool distributed;
PetscErrorCode ierr;
ierr = PetscInitialize(&argc, &argv, NULL, NULL);if (ierr) return ierr;
ierr = DMCreate(PETSC_COMM_WORLD, &dm);CHKERRQ(ierr);
ierr = DMSetType(dm, DMPLEX);CHKERRQ(ierr);
ierr = PetscObjectSetOptionsPrefix((PetscObject) dm, "init_");CHKERRQ(ierr);
ierr = DMSetFromOptions(dm);CHKERRQ(ierr);
ierr = DMPlexIsDistributed(dm, &distributed);
ierr = PetscSynchronizedPrintf(PETSC_COMM_WORLD, "%d \n", distributed);
CHKERRQ(ierr);
ierr = PetscSynchronizedFlush(PETSC_COMM_WORLD,PETSC_STDOUT);
ierr = PetscObjectSetOptionsPrefix((PetscObject) dm, NULL);CHKERRQ(ierr);
ierr = DMViewFromOptions(dm, NULL, "-dm_view");CHKERRQ(ierr);
ierr = DMDestroy(&dm);CHKERRQ(ierr);
ierr = PetscFinalize();
return ierr;
The command line options are:  mpiexec -n 3 ./cavity_flow.out
-init_dm_plex_shape sphere -init_dm_plex_sphere_radius 1.0
-init_dm_refine_pre 2 -init_dm_distribute -dm_refine 2 -dm_extrude 3
2. The parallel mesh refinement doesn't seem to take care of the spherical
>> geometry (shown in the attached mesh file). Could you please suggest how to
>> fix it?
> Okay, this is more subtle. Let me explain how things work inside.
> 1) When you refine, it inserts new cells/faces/edges/vertices. When we
> insert a new vertex, we ask what the coordinates should be. If no special
> information is there, we
>      just average the surrounding vertices.
> 2) Then we allow a second step that processed all coordinates in the mesh
> after refinement
> For the sphere, we use 2) to make all points stick to the implicit surface
> (radius R). We cannot do this for the extruded mesh, so we turn it off.
---- thanks for this explanation.
> What makes the most sense to me is to do
> 1) Serial mesh refinement to get enough cells to distribute evenly
> 2) Mesh distribution
> 3) Mesh refinement
> 4) Extrusion
> This should preserve the geometry and scale well. Does that sound right?
-- Yes, this sounds right, and this must preserve the geometry. In fact, I
was under the assumption that I was doing the exact same thing by using
these options:
mpiexec -n 3 ./cavity_flow.out -init_dm_plex_shape sphere
-init_dm_plex_sphere_radius 1.0 -init_dm_refine_pre 2 -init_dm_distribute
-dm_refine 2 -dm_extrude 3 -dm_partition_view -dm_view hdf5:mesh.h5
Do you think these options are not doing the things in the order of 1,2,3
and 4 as you specified?  If not, could you suggest the options that I need
to use to get in the order of 1,2,3 and 4?
>   Thanks,
>      Matt
>> command line options:
>> -init_dm_refine_pre 2 -init_dm_distribute -dm_refine 2 -dm_partition_view
>> CHKERRQ(ierr);
>>> and I get the attached picture.
>>>   Thanks,
>>>     Matt
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Object is in wrong state
>>>> [0]PETSC ERROR: This DMPlex is distributed but its PointSF has no graph
>>>> set
>>>> [0]PETSC ERROR: See https://petsc.org/release/faq/
>>>> <https://urldefense.com/v3/__https://petsc.org/release/faq/__;!!Nmw4Hv0!hb2EaePjZqAA4Ns2bFzuHqtjvdZrySmfJcO-7YL5Twmqdh_n0Ym4CneeBI7x1Z5UiaOW2dk_COg$>
>>>> for trouble shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.16.1, unknown
>>>> [0]PETSC ERROR: ./cavity_flow.out on a arch-darwin-c-debug named
>>>> kl-21859 by subrambm Mon Nov 22 19:47:14 2021
>>>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>>>> --with-fc=gfortran --download-mpich --download-fblaslapack
>>>> --download-superlu_dist --download-hypre --download-fiat
>>>> --download-generator --download-triangle --download-tetgen --download-chaco
>>>> --download-make -download-boost --download-cmake --download-ml
>>>> --download-mumps=https://bitbucket.org/petsc/pkg-mumps.git
>>>> <https://urldefense.com/v3/__https://bitbucket.org/petsc/pkg-mumps.git__;!!Nmw4Hv0!hb2EaePjZqAA4Ns2bFzuHqtjvdZrySmfJcO-7YL5Twmqdh_n0Ym4CneeBI7x1Z5UiaOW414fjd0$>
>>>> --download-mumps-commit=v5.4.1-p1 --download-scalapack --download-ptscotch
>>>> --download-hdf5 --force
>>>> [0]PETSC ERROR: #1 DMPlexCheckPointSF() at
>>>> /Users/subrambm/petsc/src/dm/impls/plex/plex.c:8554
>>>> [0]PETSC ERROR: #2 DMPlexOrientInterface_Internal() at
>>>> /Users/subrambm/petsc/src/dm/impls/plex/plexinterpolate.c:595
>>>> [0]PETSC ERROR: #3 DMPlexInterpolate() at
>>>> /Users/subrambm/petsc/src/dm/impls/plex/plexinterpolate.c:1357
>>>> [0]PETSC ERROR: #4 DMPlexExtrude() at
>>>> /Users/subrambm/petsc/src/dm/impls/plex/plexcreate.c:1543
>>>> [0]PETSC ERROR: #5 CreateMesh() at ex10.c:161
>>>> [0]PETSC ERROR: #6 main() at ex10.c:180
>>>> [0]PETSC ERROR: PETSc Option Table entries:
>>>> [0]PETSC ERROR: -dm_plex_extrude_layers 3
>>>> [0]PETSC ERROR: -dm_view vtk:mesh.vtk
>>>> [0]PETSC ERROR: -init_dm_plex_dim 2
>>>> [0]PETSC ERROR: -petscpartitioner_type simple
>>>> [0]PETSC ERROR: -srf_dm_distribute
>>>> [0]PETSC ERROR: -srf_dm_refine 0
>>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>>> error message to petsc-maint at mcs.anl.gov----------
>>>> Thanks,
>>>> Bhargav
>>>> This message and its contents, including attachments are intended
>>>> solely for the original recipient. If you are not the intended recipient or
>>>> have received this message in error, please notify me immediately and
>>>> delete this message from your computer system. Any unauthorized use or
>>>> distribution is prohibited. Please consider the environment before printing
>>>> this email.
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!Nmw4Hv0!hb2EaePjZqAA4Ns2bFzuHqtjvdZrySmfJcO-7YL5Twmqdh_n0Ym4CneeBI7x1Z5UiaOWdEg9at8$>
>> This message and its contents, including attachments are intended solely
>> for the original recipient. If you are not the intended recipient or have
>> received this message in error, please notify me immediately and delete
>> this email.
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!Nmw4Hv0!jtcvFDJFDmYH37N1wm6apnWSZeA9Tu6jsXTTbAqZ7w6gvNxKzNSfHoeVDIUfLDjsDO1vgciyMAw$>
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211125/e2612529/attachment.html>
