[petsc-users] Issues with log_view on windows
Barry Smith
bsmith at petsc.dev
Mon Nov 22 10:57:34 CST 2021
What does Windows use for a path separator?
> On Nov 22, 2021, at 11:19 AM, Satish Balay via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Well our build tools use cygwin - but the library is built with MS/Intel compilers - they use paths in windows notation.
> I'm not sure if there is a way to get windows PATHs without ':'
> Satish
> On Mon, 22 Nov 2021, Matthew Knepley wrote:
>> On Mon, Nov 22, 2021 at 10:36 AM Milan Pelletier <
>> milan.pelletier at protonmail.com> wrote:
>>> Matt,
>>> Thanks for the answer. I could fix my issue regarding unbalanced events -
>>> and so SNES ex5 does work well too.
>>> By the way, such imbalance does not trigger errors when log_view is using
>>> plain ascii output, but it does fail when ascii_xml is used instead.
>> Yes, we have a "failsafe" for the regular logging, but the XML is
>> specifically hierarchical and we do not know how to close it. We could take
>> another look at that.
>>> Unfortunately, regarding absolute paths, I had also tried to use cygwin
>>> paths (`/cygdrive/c/...`) but that does not work either.
>> Hmm, that should work I think. Satish, do we have a machine to login and
>> test something like this?
>> Thanks,
>> Matt
>>> Best,
>>> Milan
>>> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
>>> Le lundi 22 novembre 2021 à 2:39 PM, Matthew Knepley <knepley at gmail.com>
>>> a écrit :
>>> On Mon, Nov 22, 2021 at 5:38 AM Milan Pelletier via petsc-users <
>>>> Dear PETSc team,
>>>> The way some options are passed to PETSc can be an issue on Windows, in
>>>> particular regarding the "log_view" option.
>>>> Since the colon ':' character is used as a separator, I do not see how
>>>> absolute paths should be provided on Windows (since the drive name includes
>>>> a colon). Is there a trick / workaround to overcome this?
>>> I thought we used Cygwin paths, but maybe one of the Windows people knows
>>> better.
>>>> Besides, when I try to use the ascii_xml format, it crashes in file
>>>> xmllogevent.c, on line 751:
>>>> illegalEvent = 1+nestedEvents[nNestedEvents-1].nstEvent;
>>>> (since nestedEvents is NULL).
>>> This likely means that you have unbalanced events. I can run this on
>>> examples. For instance does SNES ex5 work for you?
>>> Thanks,
>>> Matt
>>>> I'm using PETSc version 3.16.1 (using `git checkout tags/v3.16.1`).
>>>> Thanks for your help,
>>>> Best regards,
>>>> Milan Pelletier
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211122/21126a15/attachment.html>
