[petsc-users] Issues with log_view on windows
Milan Pelletier
milan.pelletier at protonmail.com
Mon Nov 22 10:29:53 CST 2021
I get a "Unable to open file" error:
"Cannot open PetscViewer file: \\cygdrive\\c\\some_path_that_exists\\petsc_log.txt".
My input to PETSc was "-log_view /cygdrive/c/some_path_that_exists/petsc_log.txt" so the path gets converted into windows "\\" separators.
I tried and looked for a way to avoid using a colon but could not find one.
Milan
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
Le lundi 22 novembre 2021 à 5:05 PM, Matthew Knepley <knepley at gmail.com> a écrit :
> On Mon, Nov 22, 2021 at 10:36 AM Milan Pelletier <milan.pelletier at protonmail.com> wrote:
>> Matt,
>> Thanks for the answer. I could fix my issue regarding unbalanced events - and so SNES ex5 does work well too.
>> By the way, such imbalance does not trigger errors when log_view is using plain ascii output, but it does fail when ascii_xml is used instead.
> Yes, we have a "failsafe" for the regular logging, but the XML is specifically hierarchical and we do not know how to close it. We could take another look at that.
>> Unfortunately, regarding absolute paths, I had also tried to use cygwin paths (`/cygdrive/c/...`) but that does not work either.
> Hmm, that should work I think. Satish, do we have a machine to login and test something like this?
> Thanks,
> Matt
>> Best,
>> Milan
>> Le lundi 22 novembre 2021 à 2:39 PM, Matthew Knepley <knepley at gmail.com> a écrit :
>>> On Mon, Nov 22, 2021 at 5:38 AM Milan Pelletier via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>>> Dear PETSc team,
>>>> The way some options are passed to PETSc can be an issue on Windows, in particular regarding the "log_view" option.
>>>> Since the colon ':' character is used as a separator, I do not see how absolute paths should be provided on Windows (since the drive name includes a colon). Is there a trick / workaround to overcome this?
>>> I thought we used Cygwin paths, but maybe one of the Windows people knows better.
>>>> Besides, when I try to use the ascii_xml format, it crashes in file xmllogevent.c, on line 751:
>>>> illegalEvent = 1+nestedEvents[nNestedEvents-1].nstEvent;
>>>> (since nestedEvents is NULL).
>>> This likely means that you have unbalanced events. I can run this on examples. For instance does SNES ex5 work for you?
>>> Thanks,
>>> Matt
>>>> I'm using PETSc version 3.16.1 (using `git checkout tags/v3.16.1`).
>>>> Thanks for your help,
>>>> Best regards,
>>>> Milan Pelletier
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> [https://www.cse.buffalo.edu/~knepley/](http://www.cse.buffalo.edu/~knepley/)
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211122/c9b0b5a2/attachment.html>
