[petsc-users] Issues with log_view on windows
Milan Pelletier milan.pelletier at protonmail.com
Mon Nov 22 04:37:47 CST 2021
Dear PETSc team,
The way some options are passed to PETSc can be an issue on Windows, in particular regarding the "log_view" option.
Since the colon ':' character is used as a separator, I do not see how absolute paths should be provided on Windows (since the drive name includes a colon). Is there a trick / workaround to overcome this?
Besides, when I try to use the ascii_xml format, it crashes in file xmllogevent.c, on line 751:
illegalEvent = 1+nestedEvents[nNestedEvents-1].nstEvent;
(since nestedEvents is NULL).
I'm using PETSc version 3.16.1 (using `git checkout tags/v3.16.1`).
Thanks for your help,
Best regards,
Milan Pelletier
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211122/5a3bc343/attachment.html>
