[petsc-users] PCSHELL does not support getting factor matrix
    Jose E. Roman
    jroman at dsic.upv.es
    Fri Nov 19 03:41:15 CST 2021
It is trying to call PCFactorGetMatrix() on your PC, but this operation is not supported by PCSHELL and it is not possible to set it via PetscObjectComposeFunction(). PCSHELL uses the PCShellSet* interface, that is restricted to a limited number of operations.
Jose
> El 19 nov 2021, a las 6:30, Sam Guo <sam.guo at cd-adapco.com> escribió:
> Dear PETSc dev team,
>    I am implementing SLEPc interval option using shell matrix as follows:
> EPSGetST(eps, &st);
> STSetType(st, STSINVERT);
> STGetKSP(st, &ksp);
> KSPSetOperators(ksp, A, A);
> KSPSetType(ksp, KSPPREONLY);
> KSPGetPC(ksp, &pc);
> KSPGetPC(ksp, &pc)
> MatSetOption(A, MAT_SPD, PETSC_TRUE);
> PCSetType(pc, PCSHELL);
> PCShellSetContext(pc, &appCtx);
> PCShellSetApply(pc, applyPreconditioner);
> PetscObjectComposeFunction((PetscObject)pc,"PCFactorGetZeroPivot_C",PCFactorGetZeroPivot_C);
>  When I run it, I get the following error.  Any idea what I did wrong? Thanks a lot for your help.
> [0]PETSC ERROR: No support for this operation for this object type
> [0]PETSC ERROR: PC type does not support getting factor matrix
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.11.3, Jun, 26, 2019
> [0]PETSC ERROR: Unknown Name on a arch-starccmplus_serial_real named pl2usbvu0037pc.net.plm.eds.com by cd4hhv Thu Nov 18 21:11:45 2021
> Number of iterations of the method: 0
> [0]PETSC ERROR: Configure options --with-x=0 --with-fc=0 --with-debugging=1 --with-blaslapack-dir=/u/cd4hhv/dev2/mkl/2017.2-cda-001/linux/lib/intel64/../.. --with-mpi=0 -CFLAGS=-g -CXXFLAGS=-g --with-clean=1 --force --with-scalar-type=real
> [0]PETSC ERROR: #1 PCFactorGetMatrix() line 1332 in ../../../petsc/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: #2 EPSSliceGetInertia() line 340 in ../../../slepc/src/eps/impls/krylov/krylovschur/ks-slice.c
> [0]PETSC ERROR: #3 EPSSetUp_KrylovSchur_Slice() line 467 in ../../../slepc/src/eps/impls/krylov/krylovschur/ks-slice.c
> [0]PETSC ERROR: #4 EPSSetUp_KrylovSchur() line 146 in ../../../slepc/src/eps/impls/krylov/krylovschur/krylovschur.c
> [0]PETSC ERROR: #5 EPSSetUp() line 173 in ../../../slepc/src/eps/interface/epssetup.c
> Solution method: krylovschur
> [0]PETSC ERROR: #6 EPSSliceGetEPS() line 306 in ../../../slepc/src/eps/impls/krylov/krylovschur/ks-slice.c
> [0]PETSC ERROR: #7 EPSSetUp_KrylovSchur_Slice() line 416 in ../../../slepc/src/eps/impls/krylov/krylovschur/ks-slice.c
> [0]PETSC ERROR: #8 EPSSetUp_KrylovSchur() line 146 in ../../../slepc/src/eps/impls/krylov/krylovschur/krylovschur.c
> [0]PETSC ERROR: #9 EPSSetUp() line 173 in ../../../slepc/src/eps/interface/epssetup.c
