[petsc-users] Doubt about BT and BASIC NEWTONLS
Barry Smith bsmith at petsc.dev
Tue Nov 16 11:38:33 CST 2021
  Perhaps this behavior is the result of a "scaling" issue in how various terms affect the residual? In particular perhaps the terms for enforcing boundary conditions are scaled differently than terms for the PDE enforcement?
> On Nov 16, 2021, at 11:19 AM, Francesc Levrero-Florencio <f.levrero-florencio at onscale.com> wrote:
> Dear PETSc team and users,
> We are running a simple cantilever beam bending, where the profile of the beam is I-shaped, where we apply a bending force on one end and fully constrained displacements on the other end. The formulation is a large strain formulation in Total Lagrangian form, where the material of the beam is a Saint Venant-Kirchhoff hyperelastic material that uses the same constants as steel (200E9 GPa Young’s modulus and 0.3 Poisson’s ratio).
> The simulation finishes in the requested number of time steps by using the “basic” type of line-search in the SNES (i.e. traditional Newton method without line-search) in a reasonable number of Newton iterations per time step (3 or 4 iterations). However, when using the “bt” (or “l2”, and in fact no type of line-search ends up yielding convergence) line-search type, the convergence never happens within the SNES default maximum number of iterations of 50.
> During solving with traditional Newton, the general behaviour of each time step is that the norm of the residual increases on the second call to the residual function, but then hugely decreases in the following one or two, up to the point where convergence is achieved. Using “bt” line-search, the line-search discards the step at lambda=1 immediately because the norm of the residual is higher than that produced in the first call to the residual function, cutting down the value of lambda to a value significantly lower than 1. The simulation then progresses in following Newton iterations in a similar fashion, the line-search step at lambda=1 is always discarded, and then smaller steps are taken but convergence never occurs, for even the first time step.
> Here are a few values of the relevant norms (using traditional Newton) in the first time step:
> BASIC NEWTON LS
> Norm of the internal forces is 0
> Norm of the external forces is 1374.49
> Norm of the residual is 1374.49
> Norm of the solution with Dirichlet BCs is 0
> Number of SNES iteration is 0
> Norm of the internal forces is 113498
> Norm of the residual is 105053
> Norm of the solution with Dirichlet BCs is 0.441466
> Norm of the internal forces is 42953.5
> Norm of the residual is 11.3734
> Norm of the solution with Dirichlet BCs is 0.441438
> Number of SNES iteration is 1
> Here are a few values of the relevant norms (using “bt” line-search) in the first time step:
> BT NEWTONLS
> (I assume this is the first try at lambda=1)
> Norm of the internal forces is 4422.12
> Norm of the residual is 1622.74
> Norm of the solution with Dirichlet BCs is 0.0441466
> Line search: gnorm after quadratic fit 1.622742343614e+03
> (I assume that in this line-search iteration 0.05 < lambda < 1, but the corresponding residual is not smaller than the one in the first call, 1622 > 1374)
> Norm of the internal forces is 2163.76
> Norm of the residual is 1331.88
> Norm of the solution with Dirichlet BCs is 0.0220733
> Line search: Cubically determined step, current gnorm 1.331884625811e+03 lambda=5.0000000000000003e-02
> (This is the accepted lambda for the current Newton iteration)
> Norm of the internal forces is 104020
> Norm of the residual is 94739
> Norm of the solution with Dirichlet BCs is 0.441323
> My question would be, any idea on how to deal with this situation? I would imagine a “hack” would be to bypass the first residual norm, and have the line-search use the following one as the “base norm” to check its reduction in further iterations, but we are open to any ideas.
> Thanks for your help in advance and please keep up the good work!
> Regards,
> Francesc.
