[petsc-users] How to apply boundary conditions when using TS?
zhfreewill
zhfreewill at gmail.com
Mon Nov 15 20:51:56 CST 2021
I'm new to PETSc. I have been confused about how to apply boundary
conditions (BCs) (e.g., the Dirichlet and the Neumann type) when using the
time-stepping (TS) object of PETSc.
I have read the example codes (
https://petsc.org/release/src/ts/tutorials/index.html) and vaguely found
that BCs seems to be set as follows:
1. when evaluating a matrix of the right hand side function g(x) (e.g.,
using a function like RHSMatrixHeat)
2. when evaluating a matrix of the Jacobian matrix of g'(x) (e.g., using a
function like FormJacobian)
For instance, in the ex1.4 (
https://petsc.org/release/src/ts/tutorials/ex4.c.html), with comments at
the beginning states
17: /*
19: This program solves the one-dimensional heat equation (also called
the
20: diffusion equation),
21: u_t = u_xx,
22: on the domain 0 <= x <= 1, with the boundary conditions
23: u(t,0) = 0, u(t,1) = 0,
24: and the initial condition
25: u(0,x) = sin(6*pi*x) + 3*sin(2*pi*x).
26: This is a linear, second-order, parabolic equation.
28: We discretize the right-hand side using finite differences with
29: uniform grid spacing h:
30: u_xx = (u_{i+1} - 2u_{i} + u_{i-1})/(h^2)
47:
and Dirichlet BCs, u(t,0) = 0 and u(t,1) = 0, are to set on the both side
of the discretized domain, the corresponding codes can be found on the
following lines in a function RHSMatrixHeat:
463: RHSMatrixHeat - User-provided routine to compute the right-hand-side
matrix for the heat equation. */
491: PetscErrorCode RHSMatrixHeat(TS ts,PetscReal t,Vec X,Mat AA,Mat
BB,void *ctx)
492: {
505: /* Set matrix rows corresponding to boundary data */
509: if (mstart == 0) { /* first processor only */
510: v[0] = 1.0;
511: MatSetValues(A,1,&mstart,1,&mstart,v,INSERT_VALUES);
512: mstart++;
513: }
515: if (mend == appctx->m) { /* last processor only */
516: mend--;
517: v[0] = 1.0;
518: MatSetValues(A,1,&mend,1,&mend,v,INSERT_VALUES);
519: }
521: /* Set matrix rows corresponding to interior data. We construct the
matrix one row at a time. */
525: v[0] = sone; v[1] = stwo; v[2] = sone;
526: for (i=mstart; i<mend; i++) {
527: idx[0] = i-1; idx[1] = i; idx[2] = i+1;
528: MatSetValues(A,1,&i,3,idx,v,INSERT_VALUES);
529: }
550: }
My questions are:
1. How do these lines of code embody the Dirichlet BCs u(t,0) = 0 and
u(t,1) = 0.
2. Similarly, if I want to apply a Neumann type BCs in these lines, How can
I do?
Any suggestions or documents?
Best,
Qw
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211116/7314bfa3/attachment.html>
