[petsc-users] dmplex extrude in parallel
    Bhargav Subramanya
    bhargav.subramanya at kaust.edu.sa
    Thu Nov 11 12:17:21 CST 2021
Dear Matt,
I just realized that I used PETSC_COMM_SELF instead of PETSC_COMM_WORLD
while performing the above test. I am sorry for that. After fixing it, I
have the following 3 cases:
1. With the below command line options, where I simply create the spherical
surface mesh, everything is fine. The mesh gets distributed in parallel
with the check DMPlexIsDistributed.
/home/subrambm/petsc/arch-linux-c-debug/bin/mpiexec -n 2 ./cavity_flow.out
-dm_plex_dim 2 -dm_plex_simplex 1 -dm_plex_shape sphere
-dm_plex_sphere_radius 1.0 -dm_refine_pre 2 -dm_view vtk:mesh.vtk
-dm_distribute 1
2. This case also seems to work. However, the mesh file data is bad. Do you
think it's because of the vtk file format?
-dm_plex_shape sphere -dm_plex_dim 2 -dm_plex_simplex 1
-dm_plex_sphere_radius 1.0 -dm_refine_pre 3 -dm_extrude_layers 4
-dm_extrude_thickness 0.1 -dm_extrude_column_first 0 -dm_distribute 1
3. This is the case which I want: To distribute the mesh, refine it in
parallel and extrude it.
However, after distribution, the mesh does not seem to be refined as I get
the following error:
-dm_plex_sphere_radius 1.0 -dm_refine_pre 3 -dm_distribute 1 -dm_refine 1
Ignoring PCI device with non-16bit domain.
Pass --enable-32bits-pci-domain to configure to support such devices
(warning: it would break the library ABI, don't enable unless really
needed).
needed).
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Nonconforming object sizes
[1]PETSC ERROR: The output section point (0) closure size 9 != dual space
dimension 12 at height 0 in [0, 0]
[1]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.16.1, unknown
[1]PETSC ERROR: ./cavity_flow.out on a arch-linux-c-debug named kw60970 by
subrambm Thu Nov 11 21:13:27 2021
[1]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
--with-fc=gfortran --download-mpich --download-fblaslapack
--download-superlu_dist --download-hypre --download-fiat
--download-generator --download-triangle --download-tetgen --download-chaco
--download-make -download-boost --download-cmake --download-ml
--download-mumps --download-scalapack --download-parmetis --download-metis
--download-ptscotch --download-hdf5
[1]PETSC ERROR: #1 DMProjectLocal_Generic_Plex() at
/home/subrambm/petsc/src/dm/impls/plex/plexproject.c:762
[1]PETSC ERROR: #2 DMProjectFieldLocal_Plex() at
/home/subrambm/petsc/src/dm/impls/plex/plexproject.c:933
[1]PETSC ERROR: #3 DMProjectFieldLocal() at
/home/subrambm/petsc/src/dm/interface/dm.c:8863
[1]PETSC ERROR: #4 DMPlexRemapGeometry() at
/home/subrambm/petsc/src/dm/impls/plex/plexgeometry.c:3270
[1]PETSC ERROR: #5 DMSetFromOptions_Plex() at
/home/subrambm/petsc/src/dm/impls/plex/plexcreate.c:3064
[1]PETSC ERROR: #6 DMSetFromOptions() at
/home/subrambm/petsc/src/dm/interface/dm.c:902
[1]PETSC ERROR: #7 main() at meshtest.c:12
[1]PETSC ERROR: PETSc Option Table entries:
[1]PETSC ERROR: -dm_distribute 1
[1]PETSC ERROR: -dm_plex_dim 2
[1]PETSC ERROR: -dm_plex_shape sphere
[1]PETSC ERROR: -dm_plex_simplex 1
[1]PETSC ERROR: -dm_plex_sphere_radius 1.0
[1]PETSC ERROR: -dm_refine 1
[1]PETSC ERROR: -dm_refine_pre 3
[1]PETSC ERROR: ----------------End of Error Message -------send entire
error message to petsc-maint at mcs.anl.gov----------
application called MPI_Abort(MPI_COMM_WORLD, 60) - process 1
Bhargav
On Wed, Nov 10, 2021 at 4:33 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 10, 2021 at 8:26 AM Bhargav Subramanya <
> bhargav.subramanya at kaust.edu.sa> wrote:
>> Dear Matt,
>> Thanks a lot for the reply. I am now able to generate the prismatic mesh
>> properly.
> Cool.
>> In the case of mpiexec -n 2 ./meshtest -dm_plex_shape sphere
>> -dm_refine_pre 3 -dm_distribute -dm_refine 2 and DMExtrude(), where I am
>> ordering the extruded cells on the layers first; Is the mesh extruded in
>> parallel for this case?
> Yes.
>> The first time I distributed the mesh, it was only the spherical surface
>> mesh. After dmplex extrude, the mesh changes. Do I need to redistribute the
>> mesh again?
> Probably not. The balance factor will not change, meaning the relative
> sizes of the partitions. However, if you have a lot of layers, maybe you
> want to. It is easy,
> just call DMDistribute() again.
>   Thanks,
>      Matt
>> Thanks,
>> Bhargav
>> On Wed, Nov 10, 2021 at 12:56 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Tue, Nov 9, 2021 at 9:54 AM Bhargav Subramanya <
>>>> Dear All,
>>>> I want to generate a prismatic mesh from a base spherical surface mesh.
>>>> I first refine the base icosahedron sequential mesh to some extent,
>>>> distribute the mesh, continue the refinement in parallel, project the mesh
>>>> to a unit sphere, and then finally extrude the mesh. The following is the
>>>> code I am using. As the extrusion is performed in parallel, the extruded
>>>> mesh seems to be broken as shown in the attached figure. May I know how to
>>>> get an intact extruded mesh in parallel? Also, is it possible to make mesh
>>>> refinement respect the spherical surface geometry, without having to
>>>> project it using a function as shown below?
>>> I think you can do most of what you want from the command line. Here is
>>> a simple code:
>>> #include <petsc.h>
>>> int main(int argc, char **argv)
>>>   DM             dm;
>>>   PetscErrorCode ierr;
>>>   ierr = PetscInitialize(&argc, &argv, NULL, NULL);if (ierr) return ierr;
>>>   ierr = DMCreate(PETSC_COMM_WORLD, &dm);CHKERRQ(ierr);
>>>   ierr = DMSetType(dm, DMPLEX);CHKERRQ(ierr);
>>>   ierr = DMSetFromOptions(dm);CHKERRQ(ierr);
>>>   ierr = DMViewFromOptions(dm, NULL, "-dm_view");CHKERRQ(ierr);
>>>   ierr = DMDestroy(&dm);CHKERRQ(ierr);
>>>   ierr = PetscFinalize();
>>>   return ierr;
>>> that I run using
>>>   mpiexec -n 2 ./meshtest -dm_plex_shape sphere -dm_refine_pre 3
>>> -dm_extrude 5 -dm_plex_transform_extrude_thickness 0.1 -dm_distribute
>>> -dm_view hdf5:mesh.h5
>>> and get the attached picture. I am refining before distribution only
>>> here, since the after distribution refinement would refine the extrude
>>> thing, which is not what you want.
>>> If you want refinement after distribution, you could use this code to do
>>> and then call DMExtrude() by hand after that. Alternatively, I could
>>> make a pre-extrusion refinement option.
>>>   Thanks,
>>>      Matt
>>>> Thanks,
>>>> Bhargav
>>>> /* refine the sequential mesh first */
>>>> for (int r = 0; r < numRefinePre; ++r) {
>>>> DM rdm = NULL;
>>>> DMRefine(dm, MPI_COMM_WORLD, &rdm);
>>>> DMDestroy(&dm);
>>>> dm = rdm;
>>>> /* project to a unit sphere */
>>>> ierr = ProjectToUnitSphere(dm); CHKERRQ(ierr);
>>>> /* create and distribute DM */
>>>> ierr = DMPlexDistribute(dm, 0, NULL, &dmDist);CHKERRQ(ierr);
>>>> if (dmDist) {
>>>> DMDestroy(&dm);
>>>> dm   = dmDist;
>>>> /* refine the mesh in parallel */
>>>> for (int r = 0; r < numRefine; ++r) {
>>>> DM rdm = NULL;
>>>> DMDestroy(&dm);
>>>> dm = rdm;
>>>> ierr = DMPlexExtrude(dm, numLayers-1, radialThickness, PETSC_FALSE,
>>>> NULL, PETSC_TRUE, &dm3D);CHKERRQ(ierr);
>>>> if (dm3D) {
>>>> DMDestroy(&dm);
>>>> dm = dm3D;
>>>> This message and its contents, including attachments are intended
>>>> solely for the original recipient. If you are not the intended recipient or
>>>> have received this message in error, please notify me immediately and
>>>> delete this message from your computer system. Any unauthorized use or
>>>> distribution is prohibited. Please consider the environment before printing
>>>> this email.
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!Nmw4Hv0!lx1-mURFRmaF1Jo4rDYcZmLsnPsG8EO1HFWoGa2ukYZRt1fF4JLOpS3gHpaUHzL6_KersFjJlmA$>
>> This message and its contents, including attachments are intended solely
>> for the original recipient. If you are not the intended recipient or have
>> received this message in error, please notify me immediately and delete
>> this email.
> experiments lead.
> -- Norbert Wiener
> <https://urldefense.com/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!Nmw4Hv0!i2zXbyfKqyg5D1MzU0Kly__jzbsdtBbBFSsjjn7YY22imNeNSXw_Y4FZN5MzpIX6apvvV7rDhmg$>
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211111/8ba3b4f3/attachment.html>
