[petsc-users] How to compute the condition number of SchurComplementMat preconditioned with PCSHELL.
Vladislav Pimanov Vladislav.Pimanov at skoltech.ru
Thu Nov 11 03:39:47 CST 2021
Dear Barry,
Let S = B A^{-1} B^T be the Schur complement, and \hat{S} = B diag(A)^{-1} B^T denotes the preconditioner.
I also tried KSPComputeExtremeSingularValues for rtol(A) = rtol(\hat{S}) = 1e-14 as you suggested. However, the results did not change much compared to rtol(A) = rtol(S) = rtol(\hat{S}).
Additionally, I checked the identity preconditioner instead of \hat{S}. In this case, the method firstly seems to converge when reaching rtol(S)=1e-6, but then, with a further decrease of rtol(S), it begins to diverge slightly though.
I will try generalised EVP.
Vlad
От: Barry Smith <bsmith at petsc.dev>
Отправлено: 10 ноября 2021 г. 17:45:55
Кому: Vladislav Pimanov
Копия: petsc-users at mcs.anl.gov
Тема: Re: [petsc-users] How to compute the condition number of SchurComplementMat preconditioned with PCSHELL.
P is a diffusion matrix, which itself is inverted by KSPCG)
This worries me. Unless solved to full precision the action of solving with CG is not a linear operator in the input variable b, this means that the action of your Schur complement is not a linear operator and so iterative eigenvalue algorithms may not work correctly (even if the linear system seems to be converging).
I suggest you try a KSP tolerance of 10^-14 for the inner KSP solve when you attempt the eigenvalue computation.
Barry
On Nov 10, 2021, at 9:09 AM, Vladislav Pimanov <Vladislav.Pimanov at skoltech.ru<mailto:Vladislav.Pimanov at skoltech.ru>> wrote:
Great thanks, Matt!
The second option is what I was looking for.
Best Regards,
Vlad
От: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Отправлено: 10 ноября 2021 г. 16:45:00
Копия: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>
On Wed, Nov 10, 2021 at 8:42 AM Vladislav Pimanov <Vladislav.Pimanov at skoltech.ru<mailto:Vladislav.Pimanov at skoltech.ru>> wrote:
Dear PETSc community,
I wonder if you could give me a hint on how to compute the condition number of a preconditioned matrix in a proper way.
I have a MatSchurComplement matrix S and a preconditioner P of the type PCSHELL (P is a diffusion matrix, which itself is inverted by KSPCG).
I tried to compute the condition number of P^{-1}S "for free" during the outer PCG procedure using KSPComputeExtremeSingularValues() routine.
Unfortunately, \sigma_min does not converge even if the solution is computed with very high precision.
I also looked at SLEPc interface, but did not realised how PC should be included.
You can do this at least two ways:
  1) Make a MatShell for P^{-1} S. This is easy, but you will not be able to use any factorization-type PC on that matrix.
  2) Solve instead the generalized EVP, S x = \lambda P x. Since you already have P^{-1}, this should work well.
     Matt
Thanks!
Sincerely,
Vladislav Pimanov
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211111/7d43d12d/attachment-0001.html>
