[petsc-users] How to compute the condition number of SchurComplementMat preconditioned with PCSHELL.
Vladislav Pimanov Vladislav.Pimanov at skoltech.ru
Wed Nov 10 08:09:35 CST 2021
Great thanks, Matt!
The second option is what I was looking for.
Best Regards,
Vlad
От: Matthew Knepley <knepley at gmail.com>
Отправлено: 10 ноября 2021 г. 16:45:00
Кому: Vladislav Pimanov
Копия: petsc-users at mcs.anl.gov
Тема: Re: [petsc-users] How to compute the condition number of SchurComplementMat preconditioned with PCSHELL.
On Wed, Nov 10, 2021 at 8:42 AM Vladislav Pimanov <Vladislav.Pimanov at skoltech.ru<mailto:Vladislav.Pimanov at skoltech.ru>> wrote:
Dear PETSc community,
I wonder if you could give me a hint on how to compute the condition number of a preconditioned matrix in a proper way.
I have a MatSchurComplement matrix S and a preconditioner P of the type PCSHELL (P is a diffusion matrix, which itself is inverted by KSPCG).
I tried to compute the condition number of P^{-1}S "for free" during the outer PCG procedure using KSPComputeExtremeSingularValues() routine.
Unfortunately, \sigma_min does not converge even if the solution is computed with very high precision.
I also looked at SLEPc interface, but did not realised how PC should be included.
You can do this at least two ways:
  1) Make a MatShell for P^{-1} S. This is easy, but you will not be able to use any factorization-type PC on that matrix.
  2) Solve instead the generalized EVP, S x = \lambda P x. Since you already have P^{-1}, this should work well.
     Matt
Thanks!
Sincerely,
Vladislav Pimanov
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211110/ffd3adc5/attachment.html>
