[petsc-users] Fwd: SNES with Fieldsplit + MatNest in parallel
Nicolas Barnafi
nicolas.barnafi at e.email
Tue Nov 9 03:24:43 CST 2021
> I am not adept enough at FEniCS to look at the code and debug. However,
> I would make a very small problem for 2 processes, say two cells on each,
> and then print out is_0 and is_1. That should tell you if you have the
> right
> unknowns in each block. If so, then it seems like something is not
> correct in
> your assembly routine, which is probably better debugged on the FEniCS
> list.
> However, if they are not right, we can help get them right.
> THanks,
> Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Thank Matthew, I had been testing the indexes and they looked fine. In fact:
Rank-0, is_0: [0 1 2] [633 634 635]
Rank-0, is_1 [636 637 638] [729 730 731]
Rank-1, is_0: [732 733 734] [1368 1369 1370]
Rank-1, is_1 [1371 1372 1373] [1464 1465 1466]
where is_1 should be much smaller, and it is indeed the case.
Thanks!
NB
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211109/d8ef70b1/attachment-0001.html>
