[petsc-users] Problem with using make
    Matthew Knepley
    knepley at gmail.com
    Tue Nov  9 04:41:33 CST 2021
On Mon, Nov 8, 2021 at 9:57 PM Yaswanth Narayana <ynarayan at buffalo.edu>
wrote:
> Hello
> My name is Yaswanth Narayana. I am using PETSc as part of my course HPC1.
> When trying to use make I am getting the following error. What should I do?
> makefile:8: /lib/petsc/conf/rules: No such file or directory
> make: *** No rule to make target 'PETSC_DIR/lib/petsc/conf/rules'.  Stop.
You do not have PETSC_DIR defined in your environment. You can check this
using
  echo $PETSC_DIR
It should print a directory name.
     Prof. Knepley
> I have tried changing the directory name and changed to the directory
> containing files 'rules' and 'variables' but still receiving the same
> error. Please help in this regard.
> Thank you
> Yours sincerely
> Yaswanth
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211109/7d88f547/attachment.html>
