[petsc-users] How to construct DMPlex of cells with different topological dimension?
Wed Nov 3 07:12:36 CDT 2021
On Wed, Nov 3, 2021 at 8:06 AM TARDIEU Nicolas <nicolas.tardieu at edf.fr>
wrote:
> Dear Matt,
> Thank you for the additional information.
> I do agree that I will have to write code to describe the interpolation I
> need for a multi-model problem.
> Let me try to illustrate my point on the simple mesh I have attached to
> this email. It is done with Gmsh but other generators I use can do the same.
> The mesh is composed of :
> - a 3D part, volume_3d, where continuum mechanics equations will be
> assigned (displacement dof)
> - a 2D part, neumann_2d, which is a face of volume_3d and that will be
> used to integrate a Neumann condition assigned to volume_3d (it shares the
> displacement dof of volume_3d)
> - a 2D part, shell_2d, where shell equations will be assigned
> (displacement+rotation dof)
> - a 1D part, beam_1d, where beam equations will be assigned
> I can imagine that it is impossible, only from the knowledge of the mesh,
> to guess the interpolation. But I would be happy to try to write a small
> DMPlex test to try to describe such a model with a little help from you or
> another PETSc practitioner.
That is a good idea. I think we can use the pieces we have to build what
you want automatically. Cn you send me the *.msh for this.
I do not even have GMsh running on my machine, so I cannot process the .geo
:) When we read in GMah files, we mark the cell type.
However, I think we automatically try to find lower dimensional pieces in
the existing mesh (since that is what people usually want, like
your neumann section), so we would need a way to indicate that we are
specifying lower dimensional pieces that are not part of a
volumetric piece.
     Matt
> Regards,
> Nicolas
> *De :* knepley at gmail.com <knepley at gmail.com>
> *Envoyé :* mercredi 3 novembre 2021 12:14
> *À :* TARDIEU Nicolas <nicolas.tardieu at edf.fr>
> *Cc :* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Objet :* Re: [petsc-users] How to construct DMPlex of cells with
> On Wed, Nov 3, 2021 at 4:20 AM TARDIEU Nicolas via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Dear all,
> As a practitioner of structural mechanics, I modestly wish to support
> Yuan's argument. Model mixing, and consequently finite element dimension
> mixing, is (perhaps unfortunately) an inescapable practice of this
> engineering field. This has consequences not only on the nature of the
> meshes we use but also on the quasi-systematic recourse to linear relations
> (also named multipoints constraints, MPC) between the degrees of freedom of
> the different models (for example, linking a shell to a 3D part requires to
> write kinematic connections between displacements and rotations).
> DMPlex handling such meshes would be a really great contribution for the
> structural mechanics community.
> Nicolas,
> From my point of view, this is supported, so it would be good to
> understand what you do not think is supported:
> 1) Multiple models
>      This is supported in the sense that you can use any data layout, and
> assemble any system you want into it. You can use
>      beams along edges and shells on faces if you want. I have examples of
> different equations in different pieces of the domain.
> 2) Mesh with pieces hanging off
>      This is supported in the sense that you can input such a mesh. You
> have to describe it completely, but it can be input and iterated over.
> 3) Mesh Interpolation
>      If you only want to input vertices _and_ you want to input different
> dimensional objects, you will have to write code. There is no way to guess
>      what you mean from a collection of vertices. You could
>      a) Directly  call GetRawFaces() to do the interpolation per cell
> before input (seems easier)
>      b) Rewrite the interpolation loop to check whether cell types have
> been set and just call the appropriate interpolation if they have
> I guess you are arguing that I should add the code for 3). Most people I
> have interacted with use a mesh generator to make the meshes, so
> I concentrated on importing those formats. Can meshes like these be made
> with those generators?
>   Thanks,
>      Matt
> Best regards,
> Nicolas
> Ce message et toutes les pièces jointes (ci-après le 'Message') sont
> établis à l'intention exclusive des destinataires et les informations qui y
> figurent sont strictement confidentielles. Toute utilisation de ce Message
> non conforme à sa destination, toute diffusion ou toute publication totale
> ou partielle, est interdite sauf autorisation expresse.
> Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de
> le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou
> partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de
> votre système, ainsi que toutes ses copies, et de n'en garder aucune trace
> sur quelque support que ce soit. Nous vous remercions également d'en
> avertir immédiatement l'expéditeur par retour du message.
> Il est impossible de garantir que les communications par messagerie
> électronique arrivent en temps utile, sont sécurisées ou dénuées de toute
> erreur ou virus.
> ____________________________________________________
> This message and any attachments (the 'Message') are intended solely for
> the addressees. The information contained in this Message is confidential.
> Any use of information contained in this Message not in accord with its
> purpose, any dissemination or disclosure, either whole or partial, is
> prohibited except formal approval.
> If you are not the addressee, you may not copy, forward, disclose or use
> any part of it. If you have received this message in error, please delete
> it and all copies from your system and notify the sender immediately by
> return message.
> E-mail communication cannot be guaranteed to be timely secure, error or
> virus-free.
> experiments lead.
> -- Norbert Wiener
> <https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=04%7C01%7Cnicolas.tardieu%40edf.fr%7C6a1cf9718d7e4f604e1e08d99ebb4487%7Ce242425b70fc44dc9ddfc21e304e6c80%7C1%7C0%7C637715349457899987%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&sdata=MWEk6JRYK%2BmzqFqNfagjb8zLEGqmsHx%2BgQ6gjjuI5tw%3D&reserved=0>
> erreur ou virus.
> return message.
> virus-free.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211103/8d649d7b/attachment-0001.html>
