[petsc-users] How to construct DMPlex of cells with different topological dimension?
袁煕 yuanxi at advancesoft.jp
Mon Nov 1 22:20:04 CDT 2021
Dear Matthew,
I built a test problem using the strategy you suggested. It works! It is
enough for me right now. Thank you very much.
!       9----------8----------13
!   6---------7---------12  |
!   |   5------|---4-------|--11--------17------16
!   2-- ------3---------10--------14-------15
      coneSize = (/ 8,8,8,8, 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 /)
      cones = (/ 2,5,4,3,6,7,8,9,  3,4,11,10,7,12,13,8,  &
           10,14,17,11, 10,14,17,11, 14,15,16,17, 14,15,16,17 /)
There is still a problem left, however, that is how to build a 3D cell from
a 2 vertex segment. I think I could construct a virtual tetrahedron.
Finally, It can't be denied that this approach needs additional effort in
mesh construction (and It is something strange to construct a 3D object
from a one dimensional segment). In fact, structures with different
topological dimensions are not that rare. Parachute, for example, may be
composed with two dimensional parafoil and one dimensional cord. FRP(Fiber
reinforced plastics) may be modelled by one dimensional reinforcement and
three dimensional plastics. It is therefore, I am wondering, if PETSc would
take into consider of such cases by, for example
-   Enable a face, DM_POLYTOPE_SEGMENT2D, defined by one edge. And
-   Eable cells, such
as DM_POLYTOPE_QUADRILATERAL3D, DM_POLYTOPE_TRIANGLE3D and
DM_POLYTOPE_SEGMENT3D, with one face.
Sorry for a newbie in PETSc to provide such a suggestion. But if it could
be accomplished, it would help mech structural engineering, civil
engineering, and solid mechanics applicationers.
Best regards,
Yuan
2021年11月1日(月) 18:32 Matthew Knepley <knepley at gmail.com>:
> On Sun, Oct 31, 2021 at 12:21 PM 袁煕 <yuanxi at advancesoft.jp> wrote:
>> Dear Matt
>> Thank you for your detailed explanation.
>> First, I would like to answer your question about my application where
>> low dimensional features are not embedded in the larger volume. It is quite
>> general in structural engineering. For example, buildings are generally
>> modelled as shells and beams, which are two and one dimension respectively.
>> While  building foundation is modelled by solid elements, which is three
>> dimension, at the same time.
> I think I see what you want now. Let me make a suggestion (along the lines
> of what Mark said), and attempt to justify it by answering some questions.
> Suggestion: I think you should consider using a volumetric mesh for your
> problem
> Q1: Can I get the same algebraic system this way?
> Yes. You would only assign unknowns to faces and edges of the mesh where
> you have shell and beam elements.
> Q2: What are the advantages?
> You would get topological connectivity of all parts of the structure,
> automatic coupling of the different formulations,
> and you could separately solve the different structures using block
> preconditioners, while still forming a unified
> residual so that you can guarantee a consistent solution.
> Q3: Wouldn't this be expensive?
> No. For the shells and beams, you would still need the vertices, edges,
> and faces. First, by the Euler relation, these would
> outnumbers the additional cells. Second, since no unknowns would be
> associated with the cells, only additional memory in
> the mesh would be used, not the system solves. Memory and time are
> dominated by the solve, so this should be in the noise.
>   What do you think?
>      Thanks,
>         Matt
>> Secondly, It is regrettably to find that DMComposite is not available for
>> me, because all my solid, shell, and beam elements are connected each other.
>> At last, I have build a simple program to see if DMPlexSetCellType()
>> works for me, following the suggestion of functions in PETSc like
>> DMPlexCreateCGNS. But it failed when it tried to do DMPlexInterpolate
>> !       9----------8---------13
>> !   |   5------|---4-------|-11--------17--------16
>> !   2---------3---------10--------14-------15
>> The calculation result are follows. It seems that the cell type are set
>> correctly but depth is still 2.
>> DM Object: TestMesh 2 MPI processes
>>   type: plex
>> TestMesh in 3 dimensions:
>>   0-cells: 16 0
>>   3-cells: 20 (18) 0
>> Labels:
>>   celltype: 3 strata with value/size (7 (2), 4 (2), 0 (16))
>>   depth: 2 strata with value/size (0 (16), 1 (20))
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Object is in wrong state
>> [0]PETSC ERROR: Array was not checked out
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.16.0-351-g743e004674
>>  GIT Date: 2021-10-29 09:32:23 -0500
>> [0]PETSC ERROR: ./ex3f90 on a arch-linux-c-debug named DESKTOP-9ITFSBM by
>> hillyuan Mon Nov  1 00:26:39 2021
>> [0]PETSC ERROR: Configure options --with-cc=mpiicc --with-cxx=mpiicpc
>> --with-fc=mpiifort --with-fortran-bindings=1
>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.3.0
>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.3.0
>> [0]PETSC ERROR: #1 DMRestoreWorkArray() at
>> /home/hillyuan/programs/petsc/src/dm/interface/dm.c:1580
>> [0]PETSC ERROR: #2 DMPlexRestoreRawFaces_Internal() at
>> /home/hillyuan/programs/petsc/src/dm/impls/plex/plexinterpolate.c:323
>> [0]PETSC ERROR: #3 DMPlexInterpolateFaces_Internal() at
>> /home/hillyuan/programs/petsc/src/dm/impls/plex/plexinterpolate.c:375
>> [0]PETSC ERROR: #4 DMPlexInterpolate() at
>> /home/hillyuan/programs/petsc/src/dm/impls/plex/plexinterpolate.c:1340
>> I attached my test program in this mail. It is much appreciated that you
>> could provide any suggestion.
>> Best regards,
>> Yuan
>> 2021年10月31日(日) 21:16 Matthew Knepley <knepley at gmail.com>:
>>> On Thu, Oct 28, 2021 at 10:48 PM 袁煕 <yuanxi at advancesoft.jp> wrote:
>>>> Dear Matt,
>>>>     My mesh is something like the following figure, which is composed
>>>> of three elements : one hexahedron(solid element), one quadrilateral (shell
>>>> element), and one line (beam element). I found the function "TestEmptyStrata"
>>>> in file \dm\impls\plex\tests\ex11.c would be a good example to read in such
>>>> a kind of mesh by using DMPlexSetCone. But a problem is that you should
>>>> declare all faces and edges of hexahedron element, all edges in
>>>> quadrilateral  element by DMPlexSetCone, otherwise PETsc could not do
>>>> topological interpolation afterwards. Am I right here?
>>>>    As general in FEM mesh, my mesh does not contain any information
>>>> about faces or edges of solid elements. That's why I consider using
>>>> DMCOMPOSITE. That is
>>>> -   Put hexahedron, quadrilateral, and line elements into different
>>>> DM structures.
>>>> -   do topological interpolation in those DMs separately.
>>>> -   composite them.
>>>>    Is there anything wrong in my above consideration?  Any suggestions?
>>>>      / |           /  |  cell 0: Hex
>>>>    |   |         |   |   cell 1: Quad
>>>>                                   cell 2: line
>>>> Much thanks for your help.
>>> If you are solving something where everything is embedded in a
>>> volumetric mesh, then there is no problem. However, if you really have
>>> the mesh above, where lower dimensional pieces are sticking out of the
>>> mesh, then Plex can represent the mesh, but automatic interpolation
>>> (creation of edges and faces) will not work. Why is this? We use depth
>>> in the DAG as a proxy for cell dimension, but this will no longer work
>>> if faces are not part of a volume.
>>> Will DMCOMPOSITE do what you want? It depends. It will be able to lay
>>> out a vector, but it will not know about any topological connectivity
>>> between the meshes and will not preallocate a Jacobian with any
>>> interaction. If the meshes are truly separate, this is fine. If not, it is
>>> not that
>>> useful.
>>> Could you modify the existing code to support this? Yes, it would not be
>>> terribly difficult. When you load the mesh, you must know what kind
>>> of cell you are loading. You could explicitly set this using
>>> DMPlexSetCellType(). Then, instead of taking a certain height stratum of
>>> the DAG
>>> to loop over, you would instead use all cells marked with a certain cell
>>> type. The rest of the interpolation code should work fine.
>>> What kind of physics do you have where low dimensional features are not
>>> embedded in the larger volume?
>>>   Thanks,
>>>      Matt
>>>> Yuan
>>>> 2021年10月28日(木) 22:05 Matthew Knepley <knepley at gmail.com>:
>>>>> On Thu, Oct 28, 2021 at 4:59 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
>>>>>> Dear Matt,
>>>>>> Thank you for your quick response.
>>>>>> I think what you mean is to build DAG from my mesh at first and then
>>>>>> call DMPlexCreateFromDAG
>>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexCreateFromDAG.html#DMPlexCreateFromDAG>()
>>>>>> to construct DMPlex.
>>>>> No, I do not mean that.
>>>>>> A new problem is,  as I know, the function DMPlexInterpolate would
>>>>>> generate points with different depth. What's the difference  between those
>>>>>> faces and segment elements generated by  DMPlexInterpolate  with that
>>>>>> defined by the original mesh, or should we not use DMPlexInterpolate in
>>>>>> such a case?
>>>>>> On the other hand, can DMComposite be used in this case by defining
>>>>>> DMPlex with different topological dimensions at first and then composite
>>>>>> them?
>>>>> You do not need that. I am obviously not understanding your question.
>>>>> My short answer is that Plex _already_ handles cells of different
>>>>> dimension automatically without anything extra.
>>>>> Maybe it would help if you defined a specific problem you have.
>>>>>   Thanks,
>>>>>       Matt
>>>>>> Thanks in advance.
>>>>>> Yuan
>>>>>> 2021年10月27日(水) 19:27 Matthew Knepley <knepley at gmail.com>:
>>>>>>> On Wed, Oct 27, 2021 at 4:50 AM 袁煕 <yuanxi at advancesoft.jp> wrote:
>>>>>>>> Hi,
>>>>>>>> I am trying to parallelize my serial FEM program using PETSc. This
>>>>>>>> program calculates structure deformation by using various types of elements
>>>>>>>> such as solid, shell, beam, and truss. At the very beginning, I found it
>>>>>>>> was hard for me to put such kinds of elements into DMPlex. Because solid
>>>>>>>> elements are topologically three dimensional, shell element two, and beam
>>>>>>>> or truss are topologically one-dimensional elements. After reading chapter
>>>>>>>> 2.10: "DMPlex: Unstructured Grids in PETSc" of users manual carefully,  I
>>>>>>>> found the provided functions, such as DMPlexSetCone, cannot declare those
>>>>>>>> topological differences.
>>>>>>>> My question is : Is it possible and how to define all those
>>>>>>>> topologically different elements into a DMPlex struct?
>>>>>>> Yes. The idea is to program in a dimension-independent way, so that
>>>>>>> the code can handle cells of any dimension.
>>>>>>> What you probably want is the "depth" in the DAG representation,
>>>>>>> which you can think of as the dimension of a cell.
>>>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetPointDepth.html#DMPlexGetPointDepth
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> Thanks in advance!
>>>>>>>> Best regards,
>>>>>>>> Yuan.
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211102/70bb6f24/attachment-0001.html>
